查看: 723|回复: 3
350出台cpu中奖ie区加拿大ks-le-e
发表于 2024-12-17 22:00:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CPU升级1650v4,内存四通道DDR4 2400
21号到期,350出
站内私信或者tg@zackct1,tg会看的快一些
Basic System Information:
Uptime     : 0 days, 0 hours, 51 minutes
Processor  : Intel(R) Xeon(R) CPU E5-1650 v4 @ 3.60GHz
CPU cores  : 12 @ 1200.000 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 62.7 GiB
Swap       : 0.0 KiB
Disk       : 20.5 GiB
Distro     : Debian GNU/Linux 12 (bookworm)
Kernel     : 6.1.0-27-amd64
VM Type    : NONE
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH Hosting, Inc
Country    : Canada
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
Read       | 118.53 MB/s  (29.6k) | 180.61 MB/s   (2.8k)
Write      | 118.84 MB/s  (29.7k) | 181.56 MB/s   (2.8k)
Total      | 237.38 MB/s  (59.3k) | 362.17 MB/s   (5.6k)
Read       | 169.15 MB/s    (330) | 185.80 MB/s    (181)
Write      | 178.14 MB/s    (347) | 198.18 MB/s    (193)
Total      | 347.29 MB/s    (677) | 383.98 MB/s    (374)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 270 Mbits/sec   | 847 Mbits/sec   | 80.8 ms
Eranium         | Amsterdam, NL (100G)      | 273 Mbits/sec   | 886 Mbits/sec   | 87.1 ms
Uztelecom       | Tashkent, UZ (10G)        | 246 Mbits/sec   | 576 Mbits/sec   | 192 ms
Leaseweb        | Singapore, SG (10G)       | 222 Mbits/sec   | 459 Mbits/sec   | 243 ms
Clouvider       | Los Angeles, CA, US (10G) | 276 Mbits/sec   | 869 Mbits/sec   | 68.5 ms
Leaseweb        | NYC, NY, US (10G)         | 290 Mbits/sec   | 932 Mbits/sec   | 9.91 ms
Edgoo           | Sao Paulo, BR (1G)        | 262 Mbits/sec   | 560 Mbits/sec   | 119 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 269 Mbits/sec   | 830 Mbits/sec   | 80.8 ms
Eranium         | Amsterdam, NL (100G)      | 270 Mbits/sec   | 870 Mbits/sec   | 87.0 ms
Uztelecom       | Tashkent, UZ (10G)        | 245 Mbits/sec   | 487 Mbits/sec   | 192 ms
Leaseweb        | Singapore, SG (10G)       | 214 Mbits/sec   | 615 Mbits/sec   | 243 ms
Clouvider       | Los Angeles, CA, US (10G) | 272 Mbits/sec   | 828 Mbits/sec   | 68.4 ms
Leaseweb        | NYC, NY, US (10G)         | 286 Mbits/sec   | 925 Mbits/sec   | 10.0 ms
Edgoo           | Sao Paulo, BR (1G)        | 259 Mbits/sec   | 806 Mbits/sec   | 119 ms
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 1099
Multi Core      | 6577
Full Test       | https://browser.geekbench.com/v5/cpu/23084669
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 1311
Multi Core      | 6379
Full Test       | https://browser.geekbench.com/v6/cpu/8997606
YABS completed in 16 min 16 sec
Handle 0x002A, DMI type 16, 23 bytes
Physical Memory Array
        Use: System Memory
        Error Correction Type: Multi-bit ECC
        Maximum Capacity: 512 GB
        Error Information Handle: Not Provided
        Number Of Devices: 8
Handle 0x002B, DMI type 17, 40 bytes
Memory Device
        Array Handle: 0x002A
        Total Width: 72 bits
        Data Width: 64 bits
        Form Factor: DIMM
        Set: None
        Locator: DIMMA1
        Bank Locator: P0_Node0_Channel0_Dimm0
        Type: DDR4
        Type Detail: Synchronous
        Speed: 2400 MT/s
        Manufacturer: Micron
        Serial Number: 1376490F
        Asset Tag: DIMMA1_AssetTag (date:16/31)
        Part Number: 18ASF2G72PDZ-2G3B1
        Rank: 2
        Configured Memory Speed: 2400 MT/s
        Minimum Voltage: Unknown
        Maximum Voltage: Unknown
        Configured Voltage: Unknown
发表于 2024-12-18 13:34:57 | 只看该作者
就一个cpu小奖 溢价350
发表于 2024-12-18 12:31:11 | 只看该作者
Disk       : 20.5 GiB?
 楼主| 发表于 2024-12-18 13:32:53 来自手机 | 只看该作者
sqlemma 发表于 2024-12-18 12:31
Disk       : 20.5 GiB?
分的区 我忘了说是2x480g ssd的,我的锅
GMT+8, 2026-4-21 20:25 , Processed in 0.067843 second(s), 11 queries , Gzip On, MemCache On.
