查看: 910|回复: 6
1T大盘鸡测试
发表于 2024-12-6 18:25:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2024-11-11
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : Intel(R) Xeon(R) CPU E5-2690 v4 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz
  6. CPU Cores          : 1 @ 2599.996 MHz
  7. CPU Cache          : 35840 KB
  8. AES-NI             : ✓ Enabled
  9. VM-x/AMD-V         : ✓ Enabled
  10. Total Disk         : 984.2 GB (1.3 GB Used)
  11. Total Mem          : 1.9 GB (310.6 MB Used)
  12. System uptime      : 0 days, 10 hour 20 min
  13. Load average       : 0.00, 0.00, 0.00
  14. OS                 : Debian GNU/Linux 12
  15. Arch               : x86_64 (64 Bit)
  16. Kernel             : 6.1.0-9-amd64
  17. TCP CC             : cubic
  18. Virtualization     : KVM
  19. IPv4/IPv6          : ✓ Online / ✗ Offline
  20. Organization       : AS14315 1GSERVERS, LLC
  21. Location           : Phoenix / US
  22. Region             : Arizona
  23. ----------------------------------------------------------------------
  24. I/O Speed(1st run) : 211 MB/s
  25. I/O Speed(2nd run) : 194 MB/s
  26. I/O Speed(3rd run) : 206 MB/s
  27. I/O Speed(average) : 203.7 MB/s
  28. ----------------------------------------------------------------------
  29. Node Name        Upload Speed      Download Speed      Latency
  30. Speedtest.net    9019.16 Mbps      8349.23 Mbps        0.63 ms
  31. Los Angeles, US  8068.36 Mbps      6538.55 Mbps        10.20 ms
  32. Dallas, US       3714.86 Mbps      6196.03 Mbps        22.99 ms
  33. Montreal, CA     258.83 Mbps       937.55 Mbps         62.85 ms
  34. Paris, FR        828.73 Mbps       5708.21 Mbps        132.06 ms
  35. Amsterdam, NL    345.79 Mbps       5636.39 Mbps        133.50 ms
  36. Beijing, CN      439.77 Mbps       1694.42 Mbps        199.50 ms
  37. Shanghai, CN     1.68 Mbps         2395.14 Mbps        269.61 ms
  38. Hong Kong, CN    3.40 Mbps         1.49 Mbps           160.41 ms
  39. Singapore, SG    188.81 Mbps       692.14 Mbps         186.52 ms
  40. Tokyo, JP        717.96 Mbps       5946.27 Mbps        123.70 ms
  41. ----------------------------------------------------------------------
  42. Finished in        : 5 min 41 sec
  43. Timestamp          : 2024-12-06 05:21:28 EST
  44. ----------------------------------------------------------------------
 楼主| 发表于 2024-12-6 18:42:31 | 只看该作者
  3. #                     v2024-06-09                    #
  6. Fri Dec  6 05:26:54 AM EST 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 10 hours, 31 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E5-2690 v4 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz
  11. CPU cores  : 1 @ 2599.996 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 1.9 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 984.2 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-9-amd64
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : objx.net
  24. ASN        : AS14315 1GSERVERS, LLC
  25. Host       : 0webhost LLC
  26. Location   : Middletown, Delaware (DE)
  27. Country    : United States
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  32. Read       | 743.00 KB/s    (185) | 9.81 MB/s      (153)
  33. Write      | 777.00 KB/s    (194) | 10.31 MB/s     (161)
  34. Total      | 1.52 MB/s      (379) | 20.13 MB/s     (314)
  38. Read       | 27.39 MB/s      (53) | 54.91 MB/s      (53)
  39. Write      | 29.36 MB/s      (57) | 58.72 MB/s      (57)
  40. Total      | 56.76 MB/s     (110) | 113.63 MB/s    (110)
  41. Geekbench 6 Benchmark Test:
  43. Test            | Value
  44.                 |
  45. Single Core     | 970
  46. Multi Core      | 992
  47. Full Test       | https://browser.geekbench.com/v6/cpu/9273095
  48. YABS completed in 13 min 57 sec
 楼主| 发表于 2024-12-6 19:33:08 | 只看该作者
0webhost
 楼主| 发表于 2024-12-6 19:34:37 | 只看该作者
0webhost 1T
GMT+8, 2026-4-16 00:46 , Processed in 0.065709 second(s), 9 queries , Gzip On, MemCache On.
