查看: 2476|回复: 17
我买到了一只神鸡...
发表于 2024-12-5 18:55:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个鸡好花啊,能干啥呢
  1. root@debian:~# curl -sL https://yabs.sh | bash
  2. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  3. #              Yet-Another-Bench-Script              #
  4. #                     v2024-06-09                    #
  5. # https://github.com/masonr/yet-another-bench-script #
  6. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. Thu 05 Dec 2024 05:31:58 AM EST
  8. Basic System Information:
  9. ---------------------------------
  10. Uptime     : 1 days, 8 hours, 35 minutes
  11. Processor  : AMD Ryzen 9 3900X 12-Core Processor
  12. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 3799.996 MHz
  13. AES-NI     : ✔ Enabled
  14. VM-x/AMD-V : ✔ Enabled
  15. RAM        : 335.3 MiB
  16. Swap       : 473.0 MiB
  17. Disk       : 9.3 GiB
  18. Distro     : Debian GNU/Linux 11 (bullseye)
  19. Kernel     : 5.10.0-32-amd64
  20. VM Type    : KVM
  21. IPv4/IPv6  : ✔ Online / ❌ Offline
  22. IPv4 Network Information:
  23. ---------------------------------
  24. ISP        : Cox Communications Inc.
  25. ASN        : AS4213 Krypt Technologies
  26. Host       : Virtual Machine Solutions LLC
  27. Location   : Los Angeles, California (CA)
  28. Country    : United States
  29. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  30. ---------------------------------
  31. Block Size | 4k            (IOPS) | 64k           (IOPS)
  33. Read       | 235.85 MB/s  (58.9k) | 99.74 MB/s    (1.5k)
  34. Write      | 236.47 MB/s  (59.1k) | 100.26 MB/s   (1.5k)
  35. Total      | 472.33 MB/s (118.0k) | 200.01 MB/s   (3.1k)
  36.            |                      |
  37. Block Size | 512k          (IOPS) | 1m            (IOPS)
  38.   ------   | ---            ----  | ----           ----
  39. Read       | 436.88 MB/s    (853) | 918.77 MB/s    (897)
  40. Write      | 460.09 MB/s    (898) | 979.96 MB/s    (956)
  41. Total      | 896.98 MB/s   (1.7k) | 1.89 GB/s     (1.8k)
  42. iperf3 Network Speed Tests (IPv4):
  43. ---------------------------------
  44. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  45. -----           | -----                     | ----            | ----            | ----
  46. Clouvider       | London, UK (10G)          | 143 Mbits/sec   | 531 Mbits/sec   | 135 ms
  47. Eranium         | Amsterdam, NL (100G)      | 113 Mbits/sec   | 449 Mbits/sec   | 159 ms
  48. Uztelecom       | Tashkent, UZ (10G)        | 74.1 Mbits/sec  | 271 Mbits/sec   | 245 ms
  49. Leaseweb        | Singapore, SG (10G)       | 39.6 Mbits/sec  | 377 Mbits/sec   | 183 ms
  50. Clouvider       | Los Angeles, CA, US (10G) | 306 Mbits/sec   | 873 Mbits/sec   | 7.11 ms
  51. Leaseweb        | NYC, NY, US (10G)         | 61.0 Mbits/sec  | 518 Mbits/sec   | 85.3 ms
  52. Edgoo           | Sao Paulo, BR (1G)        | 10.4 Mbits/sec  | 384 Mbits/sec   | 183 ms
  53. Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
  54. YABS completed in 7 min 20 sec
  1. 正在测试,请稍等...
  2. ——————————————————————————————
  3. 目标:北京电信[219.141.136.12]   回程线路:电信163
  4. 目标:北京联通[202.106.50.1]     回程线路:联通169
  5. 目标:北京移动[221.179.155.161]  回程线路:移动CMI
  6. 目标:上海电信[202.96.209.133]   回程线路:电信163
  7. 目标:上海联通[210.22.97.1]      回程线路:联通169
  8. 目标:上海移动[211.136.112.200]  回程线路:移动CMI
  9. 目标:深圳电信[58.60.188.222]    回程线路:电信163
  10. 目标:深圳联通[210.21.196.6]     回程线路:联通169
  11. 目标:深圳移动[120.196.165.24]   回程线路:移动CMI
  12. ——————————————————————————————
  13. 本脚本测试结果为TCP回程路由,非ICMP回程路由 仅供参考,以最新IP段为准 谢谢
这个小鸡能干什么 MJJ支招
发表于 2024-12-5 19:14:32 | 只看该作者
神机,建议传家
发表于 2024-12-5 18:58:40 | 只看该作者
 楼主| 发表于 2024-12-5 19:01:50 | 只看该作者
崇拜技术大佬 发表于 2024-12-5 18:58
都ping出二维码了
牛逼
发表于 2024-12-5 19:05:00 | 只看该作者
amd yyds 简称神鸡
发表于 2024-12-5 19:08:28 | 只看该作者
无敌了,我去
发表于 2024-12-5 19:10:04 来自手机 | 只看该作者
红红火火恍恍惚惚
发表于 2024-12-5 19:13:02 | 只看该作者
想起了以前买的DediPath, 网络和这个一样
发表于 2024-12-5 22:14:14 | 只看该作者
你让我回到了2019年,用pacificrack的感觉。
发表于 2024-12-5 22:16:59 | 只看该作者
mtr相当炸裂
GMT+8, 2026-4-13 22:17 , Processed in 0.065525 second(s), 11 queries , Gzip On, MemCache On.
