查看: 844|回复: 3
[经验] 绿云 AZ 大盘鸡测试
发表于 2024-12-3 17:52:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
年付为 1C 2G,20G NVME + 500G SATA RAID-10 HDD,3T 流量,美国 Phoenix, AZ 区域。
三年付,可选内存 + HDD 翻倍或者流量 + HDD 翻倍,我选流量 + HDD 翻倍。
以下 YABS:
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 6 minutes
  4. Processor  : Intel(R) Xeon(R) Gold 6148 CPU [url=home.php?mod=space&uid=175]@[/url] 2.40GHz
  5. CPU cores  : 1 @ 2400.004 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 1.9 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 19.9 GiB
  11. Distro     : Debian GNU/Linux 12 (bookworm)
  12. Kernel     : 6.1.0-28-amd64
  13. VM Type    : KVM
  14. IPv4/IPv6  : ✔ Online / ❌ Offline
  15. IPv4 Network Information:
  16. ---------------------------------
  17. ISP        : tzulo, inc.
  18. ASN        : AS11878 tzulo, inc.
  19. Host       : tzulo, inc
  20. Location   : Phoenix, Arizona (AZ)
  21. Country    : United States
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 230.32 MB/s  (57.5k) | 1.15 GB/s    (18.0k)
  27. Write      | 230.93 MB/s  (57.7k) | 1.16 GB/s    (18.1k)
  28. Total      | 461.26 MB/s (115.3k) | 2.31 GB/s    (36.2k)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 1.23 GB/s     (2.4k) | 1.22 GB/s     (1.1k)
  33. Write      | 1.30 GB/s     (2.5k) | 1.30 GB/s     (1.2k)
  34. Total      | 2.54 GB/s     (4.9k) | 2.52 GB/s     (2.4k)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | 1.26 Gbits/sec  | 800 Mbits/sec   | 123 ms
  40. Eranium         | Amsterdam, NL (100G)      | 1.16 Gbits/sec  | 1.36 Gbits/sec  | 141 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 212 ms
  42. Leaseweb        | Singapore, SG (10G)       | 777 Mbits/sec   | 970 Mbits/sec   | 178 ms
  43. Clouvider       | Los Angeles, CA, US (10G) | 6.55 Gbits/sec  | 6.40 Gbits/sec  | 8.38 ms
  44. Leaseweb        | NYC, NY, US (10G)         | 2.95 Gbits/sec  | 2.94 Gbits/sec  | 57.5 ms
  45. Edgoo           | Sao Paulo, BR (1G)        | 930 Mbits/sec   | 1.10 Gbits/sec  | 162 ms
  46. Geekbench 6 Benchmark Test:
  47. ---------------------------------
  48. Test            | Value
  49.                 |
  50. Single Core     | 1229
  51. Multi Core      | 1227
HDD 单独测试:
  1. Disk       : 1003.2 GiB
  2. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vdb):
  6. Read       | 48.76 MB/s   (12.1k) | 259.89 MB/s   (4.0k)
  7. Write      | 48.85 MB/s   (12.2k) | 261.26 MB/s   (4.0k)
  8. Total      | 97.61 MB/s   (24.4k) | 521.16 MB/s   (8.1k)
  9.            |                      |
  10. Block Size | 512k          (IOPS) | 1m            (IOPS)
  11.   ------   | ---            ----  | ----           ----
  12. Read       | 673.32 MB/s   (1.3k) | 637.02 MB/s    (622)
  13. Write      | 709.10 MB/s   (1.3k) | 679.45 MB/s    (663)
  14. Total      | 1.38 GB/s     (2.6k) | 1.31 GB/s     (1.2k)
发表于 2024-12-3 18:00:43 | 只看该作者
好像很不错,想入一个
发表于 2024-12-3 18:01:10 | 只看该作者
HDD?价格合适吗?
 楼主| 发表于 2024-12-3 18:03:22 | 只看该作者
WSR 发表于 2024-12-3 18:01
HDD?价格合适吗?
NVME 系统盘 + HDD 储存盘,一年付 25 刀,三年付 70 刀
GMT+8, 2026-4-23 16:17 , Processed in 0.060770 second(s), 11 queries , Gzip On, MemCache On.
