查看: 841|回复: 9
已出
发表于 2024-12-3 11:16:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
註冊日期: 29/11/2021
循環出帳金額: €59,95 EUR
出帳循環: 年繳
下次到期日: 06/12/2024
40出,需要的PM
  1. Last login: Fri Nov 29 19:01:58 2024 from 123.115.239.70
  2. root@Pang:~# curl -sL yabs.sh | bash
  3. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  4. #              Yet-Another-Bench-Script              #
  5. #                     v2024-06-09                    #
  6. # https://github.com/masonr/yet-another-bench-script #
  7. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  8. Tue 03 Dec 2024 12:01:53 PM CST
  9. Basic System Information:
  10. ---------------------------------
  11. Uptime     : 84 days, 17 hours, 23 minutes
  12. Processor  : AMD EPYC 7452 32-Core Processor
  13. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 2349.998 MHz
  14. AES-NI     : ✔ Enabled
  15. VM-x/AMD-V : ✔ Enabled
  16. RAM        : 3.8 GiB
  17. Swap       : 255.0 MiB
  18. Disk       : 1007.6 GiB
  19. Distro     : Debian GNU/Linux 11 (bullseye)
  20. Kernel     : 5.10.0-18-amd64
  21. VM Type    : KVM
  22. IPv4/IPv6  : ✔ Online / ✔ Online
  23. IPv6 Network Information:
  25. ISP        : The Infrastructure Group B.V.
  26. ASN        : AS60404 The Infrastructure Group B.V.
  27. Host       : TIG
  28. Location   : Dronten, Flevoland (FL)
  29. Country    : The Netherlands
  30. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  31. ---------------------------------
  32. Block Size | 4k            (IOPS) | 64k           (IOPS)
  33.   ------   | ---            ----  | ----           ----
  34. Read       | 4.06 MB/s     (1.0k) | 64.57 MB/s    (1.0k)
  35. Write      | 4.09 MB/s     (1.0k) | 64.96 MB/s    (1.0k)
  36. Total      | 8.16 MB/s     (2.0k) | 129.54 MB/s   (2.0k)
  37.            |                      |
  38. Block Size | 512k          (IOPS) | 1m            (IOPS)
  40. Read       | 194.96 MB/s    (380) | 206.21 MB/s    (201)
  41. Write      | 205.32 MB/s    (401) | 219.94 MB/s    (214)
  42. Total      | 400.29 MB/s    (781) | 426.16 MB/s    (415)
  43. iperf3 Network Speed Tests (IPv4):
  44. ---------------------------------
  45. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  46. -----           | -----                     | ----            | ----            | ----
  47. Clouvider       | London, UK (10G)          | 798 Mbits/sec   | 631 Mbits/sec   | 9.90 ms
  48. Eranium         | Amsterdam, NL (100G)      | 780 Mbits/sec   | 872 Mbits/sec   | 2.60 ms
  49. Uztelecom       | Tashkent, UZ (10G)        | busy            | 278 Mbits/sec   | 87.6 ms
  50. Leaseweb        | Singapore, SG (10G)       | 329 Mbits/sec   | 119 Mbits/sec   | 162 ms
  51. Clouvider       | Los Angeles, CA, US (10G) | 709 Mbits/sec   | 97.4 Mbits/sec  | 145 ms
  52. Leaseweb        | NYC, NY, US (10G)         | 761 Mbits/sec   | 349 Mbits/sec   | 77.6 ms
  53. Edgoo           | Sao Paulo, BR (1G)        | 620 Mbits/sec   | 178 Mbits/sec   | 195 ms
  54. iperf3 Network Speed Tests (IPv6):
  55. ---------------------------------
  56. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  57. -----           | -----                     | ----            | ----            | ----
  58. Clouvider       | London, UK (10G)          | busy            | 539 Mbits/sec   | 8.98 ms
  59. Eranium         | Amsterdam, NL (100G)      | 804 Mbits/sec   | 881 Mbits/sec   | 2.56 ms
  60. Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 86.8 ms
  61. Leaseweb        | Singapore, SG (10G)       | 659 Mbits/sec   | 328 Mbits/sec   | 161 ms
  62. Clouvider       | Los Angeles, CA, US (10G) | 700 Mbits/sec   | 207 Mbits/sec   | 144 ms
  63. Leaseweb        | NYC, NY, US (10G)         | 730 Mbits/sec   | 467 Mbits/sec   | 77.5 ms
  64. Edgoo           | Sao Paulo, BR (1G)        | 636 Mbits/sec
  65. Geekbench 6 Benchmark Test:
  66. ---------------------------------
  67. Test            | Value
  68.                 |
  69. Single Core     | 1221
  70. Multi Core      | 2169
  71. Full Test       | https://browser.geekbench.com/v6/cpu/9212986
  72. YABS completed in 15 min 30 sec
发表于 2024-12-3 11:51:24 来自手机 | 只看该作者
你把cpu报出来,或者跑个yabs,应该更好卖。这家折扣大盘鸡基本绝版了。
 楼主| 发表于 2024-12-3 12:16:49 | 只看该作者
正在更新
 楼主| 发表于 2024-12-3 12:17:52 | 只看该作者
不清楚,应该可以
发表于 2024-12-3 12:17:59 | 只看该作者
这款是限制io的还是没限制的? 前年的貌似是没有限制的
 楼主| 发表于 2024-12-3 12:22:03 | 只看该作者
不清楚,这个是之前收来的,nvme发邮件转的大盘鸡配置
发表于 2024-12-3 12:23:13 | 只看该作者
可以,但是win10以上会卡,win7估计丝滑,HDD负载现在比较高。
CPU很强的。
 楼主| 发表于 2024-12-3 13:04:44 | 只看该作者
已更新yabs
 楼主| 发表于 2024-12-3 15:58:29 | 只看该作者
继续出,这款算是绝版大盘鸡
GMT+8, 2026-1-12 14:09 , Processed in 0.069035 second(s), 9 queries , Gzip On, MemCache On.
