查看: 2265|回复: 18
【+1刀出】cloudcone cc黑五闪购小鸡
发表于 2024-12-1 10:56:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
【1 vCPU, 1 GB RAM, 20 GB Disk, 3 TB BW 】 9.99刀+1刀=¥80
【1 vCPU, 1 GB RAM, 30 GB Disk, 3 TB BW 】 10.25刀+1刀=¥81
【1 vCPU, 1 GB RAM, 40 GB Disk, 3 TB BW 】 10.5刀+1刀=¥83
【2 vCPU, 1 GB RAM, 40 GB Disk, 3 TB BW 】 10.99刀 +1.5=¥90
都是74段ip 解锁好 tg就是论坛id
硬盘 CPU 已质检都还可以
#              Yet-Another-Bench-Script              #
#                     v2024-06-09                    #
# https://github.com/masonr/yet-another-bench-script #
Sun Dec  1 09:20:05 AM UTC 2024
Basic System Information:
Uptime     : 0 days, 1 hours, 18 minutes
Processor  : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
CPU cores  : 1 @ 2699.998 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM        : 969.5 MiB
Swap       : 1023.0 MiB
Disk       : 28.4 GiB
Distro     : Ubuntu 22.04.1 LTS
Kernel     : 5.15.0-46-generic
VM Type    : KVM
IPv4/IPv6  : ✔ Online / ❌ Offline
IPv4 Network Information:
ISP        : Multacom Corporation
ASN        : AS35916 MULTACOM CORPORATION
Host       : TELUS Communications Inc
Country    : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
Read       | 9.32 MB/s     (2.3k) | 126.67 MB/s   (1.9k)
Write      | 9.36 MB/s     (2.3k) | 127.34 MB/s   (1.9k)
Total      | 18.68 MB/s    (4.6k) | 254.01 MB/s   (3.9k)
Read       | 390.08 MB/s    (761) | 345.04 MB/s    (336)
Write      | 410.81 MB/s    (802) | 368.02 MB/s    (359)
Total      | 800.89 MB/s   (1.5k) | 713.07 MB/s    (695)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | busy            | 176 Mbits/sec   | --
Eranium         | Amsterdam, NL (100G)      | 830 Mbits/sec   | 527 Mbits/sec   | --
Uztelecom       | Tashkent, UZ (10G)        | 640 Mbits/sec   | 32.7 Mbits/sec  | --
Leaseweb        | Singapore, SG (10G)       | 792 Mbits/sec   | 505 Mbits/sec   | --
Clouvider       | Los Angeles, CA, US (10G) | 934 Mbits/sec   | 929 Mbits/sec   | --
Leaseweb        | NYC, NY, US (10G)         | 886 Mbits/sec   | 451 Mbits/sec   | --
Edgoo           | Sao Paulo, BR (1G)        | 796 Mbits/sec   | 106 Mbits/sec   | --
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 609
Multi Core      | 596
Full Test       | https://browser.geekbench.com/v5/cpu/23114357
YABS completed in 8 min 3 sec
最差的盘是这样:
#                     v2024-06-09                    #
Sun Dec  1 07:44:55 AM UTC 2024
Uptime     : 0 days, 0 hours, 1 minutes
CPU cores  : 2 @ 2699.998 MHz
AES-NI     : ✔ Enabled
RAM        : 969.2 MiB
Swap       : 1023.0 MiB
Disk       : 38.3 GiB
VM Type    : KVM
Read       | 6.61 MB/s     (1.6k) | 105.62 MB/s   (1.6k)
Write      | 6.62 MB/s     (1.6k) | 106.18 MB/s   (1.6k)
Total      | 13.24 MB/s    (3.3k) | 211.81 MB/s   (3.3k)
Read       | 341.27 MB/s    (666) | 313.64 MB/s    (306)
Write      | 359.40 MB/s    (701) | 334.52 MB/s    (326)
Total      | 700.68 MB/s   (1.3k) | 648.16 MB/s    (632)
Clouvider       | London, UK (10G)          | 829 Mbits/sec   | 104 Mbits/sec   | 129 ms
Eranium         | Amsterdam, NL (100G)      | 831 Mbits/sec   | 531 Mbits/sec   | --
Uztelecom       | Tashkent, UZ (10G)        | 642 Mbits/sec   | 49.7 Mbits/sec  | --
Leaseweb        | Singapore, SG (10G)       | 776 Mbits/sec   | 383 Mbits/sec   | --
Clouvider       | Los Angeles, CA, US (10G) | 935 Mbits/sec   | 933 Mbits/sec   | --
Leaseweb        | NYC, NY, US (10G)         | 886 Mbits/sec   | 427 Mbits/sec   | --
Edgoo           | Sao Paulo, BR (1G)        | 792 Mbits/sec   | 71.9 Mbits/sec  | --
Test            | Value
Single Core     | 610
Multi Core      | 1167
Full Test       | https://browser.geekbench.com/v5/cpu/23114106
发表于 2024-12-1 11:30:23 | 只看该作者
毫无购买欲望 都是常规款。。。
发表于 2024-12-1 11:46:25 | 只看该作者
好鸡,建议留着传家
发表于 2024-12-1 17:21:43 | 只看该作者
Read       | 6.61 MB/s     (1.6k) | 105.62 MB/s   (1.6k)  硬盘个位数 图啥啊
楼主的 DD 硬盘测试 他选择性的隐藏了 那个发出来更震惊
这个是4k写入  发表于 2024-12-1 17:23
发表于 2024-12-1 17:22:57 | 只看该作者
6.75刀的话我就要了
发表于 2024-12-1 17:24:17 | 只看该作者
这么好的小鸡还是自己留着吧,说不定十年后能卖1000刀
 楼主| 发表于 2024-12-1 17:25:19 | 只看该作者
楼主的 DD 硬盘测试 他选 ...
没有隐藏的 yabs的测试 完整数据就是这样的
GMT+8, 2026-4-22 14:03 , Processed in 0.063616 second(s), 8 queries , Gzip On, MemCache On.
