查看: 1190|回复: 9
[交易VPS] 【已出】oplink美国8核32g1T高速NVMe固态50T流量带win有DDos防御
发表于 2024-12-1 00:53:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
已出
  1. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
  3. Block Size | 4k            (IOPS) | 64k           (IOPS)
  4.   ------   | ---            ----  | ----           ----
  5. Read       | 172.91 MB/s  (43.2k) | 2.00 GB/s    (31.3k)
  6. Write      | 173.37 MB/s  (43.3k) | 2.01 GB/s    (31.4k)
  7. Total      | 346.29 MB/s  (86.5k) | 4.02 GB/s    (62.8k)
  8.            |                      |
  9. Block Size | 512k          (IOPS) | 1m            (IOPS)
  10.   ------   | ---            ----  | ----           ----
  11. Read       | 3.54 GB/s     (6.9k) | 3.78 GB/s     (3.6k)
  12. Write      | 3.72 GB/s     (7.2k) | 4.03 GB/s     (3.9k)
  13. Total      | 7.26 GB/s    (14.1k) | 7.82 GB/s     (7.6k)
  14. Geekbench 5 Benchmark Test:
  15. ---------------------------------
  16. Test            | Value
  17.                 |
  18. Single Core     | 668
  19. Multi Core      | 4666
  20. Full Test       | https://browser.geekbench.com/v5/cpu/23121723
  1. iperf3 Network Speed Tests (IPv4):
  3. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  4. -----           | -----                     | ----            | ----            | ----
  5. Clouvider       | London, UK (10G)          | 1.76 Gbits/sec  | 1.67 Gbits/sec  | 101 ms
  6. Eranium         | Amsterdam, NL (100G)      | 2.06 Gbits/sec  | 1.63 Gbits/sec  | 118 ms
  7. Uztelecom       | Tashkent, UZ (10G)        | 805 Mbits/sec   | busy            | 211 ms
  8. Leaseweb        | Singapore, SG (10G)       | busy            | 252 Mbits/sec   | 213 ms
  9. Clouvider       | Los Angeles, CA, US (10G) | 4.39 Gbits/sec  | 3.13 Gbits/sec  | 37.9 ms
  10. Leaseweb        | NYC, NY, US (10G)         | 6.85 Gbits/sec  | 4.40 Gbits/sec  | 32.5 ms
  11. Edgoo           | Sao Paulo, BR (1G)        | 1.61 Gbits/sec  | 1.29 Gbits/sec  | 139 ms
  12. iperf3 Network Speed Tests (IPv6):
  13. ---------------------------------
  14. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  15. -----           | -----                     | ----            | ----            | ----
  16. Clouvider       | London, UK (10G)          | 1.38 Gbits/sec  | 1.62 Gbits/sec  | 101 ms
  17. Eranium         | Amsterdam, NL (100G)      | 1.98 Gbits/sec  | 1.36 Gbits/sec  | 118 ms
  18. Uztelecom       | Tashkent, UZ (10G)        | 573 Mbits/sec   | 651 Mbits/sec   | 205 ms
  19. Leaseweb        | Singapore, SG (10G)       | 820 Mbits/sec   | busy            | 213 ms
  20. Clouvider       | Los Angeles, CA, US (10G) | 5.05 Gbits/sec  | 4.91 Gbits/sec  | 36.8 ms
  21. Leaseweb        | NYC, NY, US (10G)         | 6.96 Gbits/sec  | 5.02 Gbits/sec  | 32.6 ms
  22. Edgoo           | Sao Paulo, BR (1G)        | 1.61 Gbits/sec  | 1.15 Gbits/sec  | 137 ms
  1. ---------------------基础信息查询--感谢所有开源项目---------------------
  2. CPU 型号          : Intel(R) Xeon(R) CPU E5-2683 v4 @2.10GHz
  3. CPU 核心数        : 8
  4. CPU 频率          : 2099.998 MHz
  5. CPU 缓存          : L1: 256.00 KB / L2: 32.00 MB / L3: 128.00 MB
  6. AES-NI指令集      : ✔ Enabled
  7. VM-x/AMD-V支持    : ✔ Enabled
  8. 内存              : 236.96 MiB / 31.36 GiB
  9. Swap              : [ no swap partition or swap file detected ]
  10. 硬盘空间          : 1.60 GiB / 983.23 GiB
  11. 启动盘路径        : /dev/sda1
  12. 系统在线时间      : 0 days, 0 hour 27 min
  13. 负载              : 0.90, 0.54, 0.42
  14. 系统              : Debian GNU/Linux 12 (bookworm) (x86_64)
  15. 架构              : x86_64 (64 Bit)
  16. 内核              : 6.10.10
  17. TCP加速方式       : bbr
  18. 虚拟化架构        : KVM
  19. NAT类型           : Full Cone
  20. IPV4 ASN          : AS40156 The Optimal Link Corporation
  21. IPV4 位置         : Houston / Texas / US
  22. IPV6 ASN          : AS40156 The Optimal Link Corporation
  23. IPV6 位置         : United States
  24. IPV6 子网掩码     : 128
  25. ----------------------CPU测试--通过sysbench测试-------------------------
  26. -> CPU 测试中 (Fast Mode, 1-Pass @5sec)
  27. 1 线程测试(单核)得分:                 769 Scores
  28. 8 线程测试(多核)得分:                 6427 Scores
  29. ---------------------内存测试--感谢lemonbench开源-----------------------
  30. -> 内存测试 Test (Fast Mode, 1-Pass @5sec)
  31. 单线程读测试:                16561.76 MB/s
  32. 单线程写测试:                12760.44 MB/s
  33. ---------------------磁盘fio读写测试--感谢yabs开源----------------------
  34. Block Size | 4k            (IOPS) | 64k           (IOPS)
  35.   ------   | ---            ----  | ----           ----
  36. Read       | 179.20 MB/s  (44.8k) | 2.22 GB/s    (34.7k)
  37. Write      | 179.67 MB/s  (44.9k) | 2.23 GB/s    (34.9k)
  38. Total      | 358.88 MB/s  (89.7k) | 4.46 GB/s    (69.7k)
  39.            |                      |
  40. Block Size | 512k          (IOPS) | 1m            (IOPS)
  41.   ------   | ---            ----  | ----           ----
  42. Read       | 3.55 GB/s     (6.9k) | 3.77 GB/s     (3.6k)
  43. Write      | 3.74 GB/s     (7.3k) | 4.03 GB/s     (3.9k)
  44. Total      | 7.30 GB/s    (14.2k) | 7.81 GB/s     (7.6k)
  45. --------------------自动更新测速节点列表--本脚本原创--------------------
  46. 位置                 上传速度         下载速度         延迟          丢包率
  47. Speedtest.net         5531.06 Mbps         5259.21 Mbps         16.26          0.0%
  48. 联通WuXi         38.20 Mbps         5643.50 Mbps         359.54          7.7%
  49. 电信浙江         197.00 Mbps         575.53 Mbps         180.32          NULL
oplink 美国
Houston, Texas (TX)
休斯顿,德克萨斯
US原生ip,完美解锁,测试如图
配置:
        8核cpu
        32 GB DDR4 内存
        1T NVMe 硬盘 (Raid 10)
        10Gbps大带宽
        50TB流量/月
        1 IPv4 + 1 IPv6
        DDos防御 Always On DDoS Protection
面板重装,带windows系统:
        Windows 10 Pro
        Windows 11 Pro
        Windows Server 2022
        Windows Server 2019
签名TG联系brunuhville
或者论坛私信
发表于 2024-12-1 00:55:54 | 只看该作者
绑定,祝早出。
发表于 2024-12-1 01:07:32 | 只看该作者
他家以前用cpu占用超过30%的理由清退了特卖SSD,小心哦
 楼主| 发表于 2024-12-1 01:12:52 | 只看该作者
所有 Oplink.net 虚拟专用服务器 (VDS) 帐户均可全天候分配 100% CPU。
只要 VPS 整体节点正常,所有虚拟专用服务器 (VPS) 帐户的 CPU 都可以爆发到 100%。
2 GB VPS 帐户可保证 30% 的 CPU 分配,而 4GB 及以上的 VPS 帐户可保证 50% 的 CPU 分配。
一般来说,只要 VPS 节点整体负载正常并且没有其他客户端受到影响,我们就不会管这件事。
低配机,cpu长期平均不超过30%
4GB内存以上的高配机,cpu长期平均不超过50%  即可
发表于 2024-12-1 03:02:34 来自手机 | 只看该作者
这家总体可以适合建站,之前德州飓风刮过,一直都很稳,我以为黑五会有9950,结果等来的是几个垃圾杜甫和Intel的vps。算了,有台7950高配也满足了。
 楼主| 发表于 2024-12-4 01:50:49 | 只看该作者
NVMe硬盘,I/O嘎嘎猛
 楼主| 发表于 2024-12-4 02:20:57 | 只看该作者
  1. bash <(curl -L -s https://github.com/1-stream/RegionRestrictionCheck/raw/main/check.sh)
更新解锁测试脚本
之前常用的media.ispvps.com似乎作者已经停止更新
 楼主| 发表于 2024-12-5 20:19:11 | 只看该作者
好鸡等大佬
 楼主| 发表于 2024-12-8 09:46:38 | 只看该作者
继续出鸡紫薯布丁
 楼主| 发表于 2024-12-10 19:45:23 | 只看该作者
好鸡等大佬,888带走
GMT+8, 2026-4-29 22:14 , Processed in 0.062518 second(s), 10 queries , Gzip On, MemCache On.
