查看: 1987|回复: 15
50 Push出Nocix 10刀月付杜甫 5个可用IP
发表于 2024-11-30 04:41:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
i3-2100 @ 3.1GHz
16GB RAM
240GB SSD
5 IPv4 + /64 IPv6
Unmetered @ 1Gbps
带5个IPv4地址
G口不限量
美国堪萨斯州
Intel低通电时数固态硬盘
  3. #                     v2024-06-09                    #
  6. Fri Nov 29 14:17:08 CST 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 2 hours, 21 minutes
  10. Processor  : Intel(R) Core(TM) i3-2100 CPU [url=home.php?mod=space&uid=175]@[/url] 3.10GHz
  11. CPU cores  : 4 [url=home.php?mod=space&uid=175]@[/url] 3100.000 MHz
  12. AES-NI     : ❌ Disabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 15.3 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 223.4 GiB
  17. Distro     : AlmaLinux 8.8 (Sapphire Caracal)
  18. Kernel     : 4.18.0-477.10.1.el8_8.x86_64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : Nocix, LLC
  24. ASN        : AS33387 Nocix, LLC
  25. Host       : Fbivps
  26. Location   : Kansas City, Missouri (MO)
  27. Country    : United States
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mapper/vg-root):
  32. Read       | 71.16 MB/s   (17.7k) | 84.02 MB/s    (1.3k)
  33. Write      | 71.35 MB/s   (17.8k) | 84.46 MB/s    (1.3k)
  34. Total      | 142.51 MB/s  (35.6k) | 168.48 MB/s   (2.6k)
  38. Read       | 102.66 MB/s    (200) | 108.71 MB/s    (106)
  39. Write      | 108.12 MB/s    (211) | 115.95 MB/s    (113)
  40. Total      | 210.78 MB/s    (411) | 224.66 MB/s    (219)
  45. Clouvider       | London, UK (10G)          | 867 Mbits/sec   | 97.0 Mbits/sec  | 96.8 ms
  46. Eranium         | Amsterdam, NL (100G)      | 871 Mbits/sec   | 698 Mbits/sec   | 103 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 755 Mbits/sec   | busy            | 201 ms
  48. Leaseweb        | Singapore, SG (10G)       | busy            | busy            | 244 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 915 Mbits/sec   | busy            | 41.1 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 923 Mbits/sec   | 677 Mbits/sec   | 28.3 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 767 Mbits/sec   | 170 Mbits/sec   | 141 ms
  52. Geekbench 6 Benchmark Test:
  53. ---------------------------------
  54. Test            | Value
  55.                 |
  56. Single Core     | 567
  57. Multi Core      | 1197
  58. Full Test       | https://browser.geekbench.com/v6/cpu/9145165
  59. YABS completed in 18 min 27 sec
  1. === START OF INFORMATION SECTION ===
  2. Model Family:     Intel 540 Series SSDs
  3. Device Model:     INTEL SSDSC2KW240H6
  4. Serial Number:    CVLT620007MU240CGN
  5. LU WWN Device Id: 5 5cd2e4 14cbf947e
  6. Firmware Version: LSBG200
  7. User Capacity:    240,057,409,536 bytes [240 GB]
  8.   9 Power_On_Hours_and_Msec 0x0032   100   100   000    Old_age   Always       -       1244h+00m+00.000s
  9. 241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       1559856
  10. 242 Total_LBAs_Read         0x0032   100   100   000    Old_age   Always       -       29973
发表于 2024-11-30 05:01:17 来自手机 | 只看该作者
跟楼主同款,年付 99 刀
发表于 2024-11-30 07:57:40 来自手机 | 只看该作者
收了个,好像没中奖哎,是我太菜了吗
发表于 2024-11-30 09:12:39 来自手机 | 只看该作者
搭车同出,年付 99 刀
发表于 2024-12-1 16:30:16 | 只看该作者
为什么一直在降。。。
GMT+8, 2026-4-16 15:52 , Processed in 0.064652 second(s), 10 queries , Gzip On, MemCache On.
