查看: 906|回复: 5
T楼得到的服务器
发表于 2024-11-26 09:37:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
感谢大佬@Qiao
  3. #                     v2024-06-09                    #
  6. Mon Nov 25 11:18:45 AM JST 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 13 minutes
  10. Processor  : Intel Core Processor (Broadwell, IBRS)
  11. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 2499.996 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 1.6 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 25.9 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-9-amd64
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : Cogent Communications
  24. ASN        : AS979 NetLab Global
  25. Host       : NetLab
  26. Location   : Los Angeles, California (CA)
  27. Country    : United States
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
  32. Read       | 116.88 MB/s  (29.2k) | 1.25 GB/s    (19.5k)
  33. Write      | 117.18 MB/s  (29.2k) | 1.26 GB/s    (19.6k)
  34. Total      | 234.06 MB/s  (58.5k) | 2.51 GB/s    (39.2k)
  38. Read       | 1.18 GB/s     (2.3k) | 1.30 GB/s     (1.2k)
  39. Write      | 1.25 GB/s     (2.4k) | 1.39 GB/s     (1.3k)
  40. Total      | 2.43 GB/s     (4.7k) | 2.69 GB/s     (2.6k)
  45. Clouvider       | London, UK (10G)          | 22.2 Mbits/sec  | 20.0 Mbits/sec  | 212 ms
  46. Eranium         | Amsterdam, NL (100G)      | 21.3 Mbits/sec  | 19.5 Mbits/sec  | 275 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 23.3 Mbits/sec  | 20.3 Mbits/sec  | 97.9 ms
  48. Leaseweb        | Singapore, SG (10G)       | 22.2 Mbits/sec  | 19.5 Mbits/sec  | 183 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | busy            | 19.0 Mbits/sec  | 152 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 21.8 Mbits/sec  | 19.7 Mbits/sec  | 210 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 20.4 Mbits/sec  | 19.3 Mbits/sec  | 319 ms
  52. Geekbench 6 test failed. Run manually to determine cause.
  53. YABS completed in 14 min 38 sec
发表于 2024-11-26 09:43:44 | 只看该作者
属实是羡慕了哥
发表于 2024-11-26 10:01:19 | 只看该作者
还有这好事。
GMT+8, 2026-4-25 03:14 , Processed in 0.063656 second(s), 10 queries , Gzip On, MemCache On.
