查看: 1920|回复: 14
【已出】ovh ks-le-1中奖硬盘双960G固态 网络G口上下 内存32G
发表于 2024-11-25 20:18:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IE区 加拿大机房BHS2  9.99欧月付 退坑398出
  1. Disk /dev/sda: 894.3 GiB, 960197124096 bytes, 1875385008 sectors
  2. Disk model: INTEL SSDSC2KB96
  3. Units: sectors of 1 * 512 = 512 bytes
  4. Sector size (logical/physical): 512 bytes / 4096 bytes
  5. I/O size (minimum/optimal): 4096 bytes / 4096 bytes
  6. Disk /dev/sdb: 894.3 GiB, 960197124096 bytes, 1875385008 sectors
  7. Disk model: INTEL SSDSC2KB96
  8. Units: sectors of 1 * 512 = 512 bytes
  9. Sector size (logical/physical): 512 bytes / 4096 bytes
  10. I/O size (minimum/optimal): 4096 bytes / 4096 bytes
  3. #                     v2024-06-09                    #
  6. Mon 25 Nov 2024 12:06:27 PM UTC
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 5 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 1600.000 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 0.0 KiB
  16. Disk       :
  17. Distro     : Debian GNU/Linux 10 (buster)
  18. Kernel     : 6.1.51-mod-std
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH Hosting, Inc
  26. Location   : Beauharnois, Quebec (QC)
  27. Country    : Canada
  28. Less than 2GB of space available. Skipping disk test...
  29. iperf3 Network Speed Tests (IPv4):
  30. ---------------------------------
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  32. -----           | -----                     | ----            | ----            | ----
  33. Clouvider       | London, UK (10G)          | 768 Mbits/sec   | 560 Mbits/sec   | 75.1 ms
  34. Eranium         | Amsterdam, NL (100G)      | 824 Mbits/sec   | 679 Mbits/sec   | 87.7 ms
  35. Uztelecom       | Tashkent, UZ (10G)        | 747 Mbits/sec   | 428 Mbits/sec   | 185 ms
  36. Leaseweb        | Singapore, SG (10G)       | 556 Mbits/sec   | 479 Mbits/sec   | 239 ms
  37. Clouvider       | Los Angeles, CA, US (10G) | 815 Mbits/sec   | 832 Mbits/sec   | 68.5 ms
  38. Leaseweb        | NYC, NY, US (10G)         | 922 Mbits/sec   | 882 Mbits/sec   | 12.6 ms
  39. Edgoo           | Sao Paulo, BR (1G)        | 785 Mbits/sec   | 309 Mbits/sec   | 119 ms
  40. iperf3 Network Speed Tests (IPv6):
  41. ---------------------------------
  42. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  43. -----           | -----                     | ----            | ----            | ----
  44. Clouvider       | London, UK (10G)          | 821 Mbits/sec   | 349 Mbits/sec   | 75.1 ms
  45. Eranium         | Amsterdam, NL (100G)      | 797 Mbits/sec   | 684 Mbits/sec   | 87.2 ms
  46. Uztelecom       | Tashkent, UZ (10G)        | busy            | 214 Mbits/sec   | 185 ms
  47. Leaseweb        | Singapore, SG (10G)       | 631 Mbits/sec   | 465 Mbits/sec   | 239 ms
  48. Clouvider       | Los Angeles, CA, US (10G) | 784 Mbits/sec   | 161 Mbits/sec   | 68.3 ms
  49. Leaseweb        | NYC, NY, US (10G)         | 912 Mbits/sec   | 875 Mbits/sec   | 12.2 ms
  50. Edgoo           | Sao Paulo, BR (1G)        | 740 Mbits/sec   | 504 Mbits/sec   | 119 ms
 楼主| 发表于 2024-11-25 20:20:03 | 只看该作者
买了那么多次ovh 终于轮到我中奖了
发表于 2024-11-25 20:22:29 | 只看该作者
3中奖,这牛逼了
发表于 2024-11-25 20:28:33 | 只看该作者
羡慕
我的鸡都开不出来
发表于 2024-11-25 20:43:16 来自手机 | 只看该作者
好机.楼主出吗,私聊下报价
发表于 2024-11-25 20:46:12 | 只看该作者
好机.楼主出吗,私聊下报价
发表于 2024-11-25 21:00:03 | 只看该作者
Fightlee 发表于 2024-11-25 20:28
羡慕
我的鸡都开不出来
ks-le-1吗?几天了?
发表于 2024-11-25 21:04:12 | 只看该作者
KS-LE-A 我的也是中了宽带  IPV4是双G
发表于 2024-11-25 21:21:00 | 只看该作者
羡慕啊 网络中奖
GMT+8, 2026-5-2 07:57 , Processed in 0.073042 second(s), 10 queries , Gzip On, MemCache On.
