查看: 992|回复: 8
出了 120出OVH IE区GRA KS-LE-1内存翻倍
发表于 2024-11-23 16:26:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
续费9.9欧元
IE区直接push
  3. #                     v2024-06-09                    #
  6. Sat 23 Nov 2024 08:20:51 AM UTC
  7. Basic System Information:
  9. Uptime     : 0 days, 16 hours, 44 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 2700.000 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 439.0 GiB
  17. Distro     : Debian GNU/Linux 10 (buster)
  18. Kernel     : 6.1.51-mod-std
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH SAS
  26. Location   : Lille, Hauts-de-France (HDF)
  27. Country    : France
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda):
  32. Read       | 121.61 MB/s  (30.4k) | 183.23 MB/s   (2.8k)
  33. Write      | 121.93 MB/s  (30.4k) | 184.20 MB/s   (2.8k)
  34. Total      | 243.54 MB/s  (60.8k) | 367.43 MB/s   (5.7k)
  38. Read       | 217.86 MB/s    (425) | 222.71 MB/s    (217)
  39. Write      | 229.43 MB/s    (448) | 237.54 MB/s    (231)
  40. Total      | 447.29 MB/s    (873) | 460.25 MB/s    (448)
  45. Clouvider       | London, UK (10G)          | 287 Mbits/sec   | 941 Mbits/sec   | 3.72 ms
  46. Eranium         | Amsterdam, NL (100G)      | 286 Mbits/sec   | 940 Mbits/sec   | 9.76 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 234 Mbits/sec   | 602 Mbits/sec   | 106 ms
  48. Leaseweb        | Singapore, SG (10G)       | 107 Mbits/sec   | 575 Mbits/sec   | 160 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 127 Mbits/sec   | 714 Mbits/sec   | 136 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 263 Mbits/sec   | 601 Mbits/sec   | --
  51. Edgoo           | Sao Paulo, BR (1G)        | 154 Mbits/sec   | 376 Mbits/sec   | 187 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 283 Mbits/sec   | 928 Mbits/sec   | 3.74 ms
  57. Eranium         | Amsterdam, NL (100G)      | 282 Mbits/sec   | 925 Mbits/sec   | 9.11 ms
  58. Uztelecom       | Tashkent, UZ (10G)        | 196 Mbits/sec   | 642 Mbits/sec   | 106 ms
  59. Leaseweb        | Singapore, SG (10G)       | 96.2 Mbits/sec  | 627 Mbits/sec   | 159 ms
  60. Clouvider       | Los Angeles, CA, US (10G) | 218 Mbits/sec   | 687 Mbits/sec   | 136 ms
  61. Leaseweb        | NYC, NY, US (10G)         | 232 Mbits/sec   | 639 Mbits/sec   | 75.9 ms
  62. Edgoo           | Sao Paulo, BR (1G)        | 164 Mbits/sec   | 627 Mbits/sec   | 187 ms
  63. Running GB6 benchmark test... *cue elevator music*
  64. Geekbench 6 Benchmark Test:
  65. ---------------------------------
  66. Test            | Value
  67.                 |
  68. Single Core     | 767
  69. Multi Core      | 2695
  70. Full Test       | https://browser.geekbench.com/v6/cpu/9022909
  71. YABS completed in 16 min 37 sec
  1. Device Model:     INTEL SSDSC2BB480G6
  2. 9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       34938
  3. 9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       51064
发表于 2024-11-23 16:32:16 | 只看该作者
加拿大还是法国?是SSD吗?
 楼主| 发表于 2024-11-23 16:33:11 | 只看该作者
番职男孩 发表于 2024-11-23 16:32
加拿大还是法国?是SSD吗?
法国GRA,480GB*2 SATA SSD
发表于 2024-11-23 16:34:27 | 只看该作者
能先机吗?你这看起来有点担心,可以先机的话,我就要了
发表于 2024-11-23 16:40:58 | 只看该作者
或者走咸鱼
发表于 2024-11-23 17:26:40 来自手机 | 只看该作者
带账号出吗?
发表于 2024-11-23 18:36:35 | 只看该作者
我有一个,可带账号出,私聊
发表于 2024-11-23 19:46:24 | 只看该作者
xiaosong 发表于 2024-11-23 18:36
我有一个,可带账号出,私聊
已PM
发表于 2024-11-23 22:10:08 | 只看该作者
可以,新号的话还能赚一点儿
GMT+8, 2026-4-16 11:13 , Processed in 0.061575 second(s), 8 queries , Gzip On, MemCache On.
