查看: 2182|回复: 26
【已无】[抽奖失败]100出ks-le-1 仅内存中奖 IE区push 没号.....
发表于 2024-11-23 00:58:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
100出ks-le-1  IE区push 没号的话我代持(租)
ks-le-1
标配:Intel Xeon E3-1245v2 - 4c/8t - 3.4 GHz/3.8 GHz 16G 2x480G 300M
这台只是内存翻倍(这批开的都一样)
  3. #                     v2024-06-09                    #
  6. Fri  22 Nov 2024 04:23:26 PM UTC
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 5 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 1600.000 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 0.0 KiB
  16. Disk       :
  17. Distro     : Debian GNU/Linux 10 (buster)
  18. Kernel     : 6.1.51-mod-std
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH SAS
  26. Location   : Roubaix, Hauts-de-France (HDF)
  27. Country    : France
  28. Less than 2GB of space available. Skipping disk test...
  29. iperf3 Network Speed Tests (IPv4):
  30. ---------------------------------
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  32. -----           | -----                     | ----            | ----            | ----
  33. Clouvider       | London, UK (10G)          | 287 Mbits/sec   | 936 Mbits/sec   | 4.51 ms
  34. Eranium         | Amsterdam, NL (100G)      | 286 Mbits/sec   | 934 Mbits/sec   | 9.16 ms
  35. Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 106 ms
  36. Leaseweb        | Singapore, SG (10G)       | 78.3 Mbits/sec  | 567 Mbits/sec   | --
  37. Clouvider       | Los Angeles, CA, US (10G) | 147 Mbits/sec   | 302 Mbits/sec   | 136 ms
  38. Leaseweb        | NYC, NY, US (10G)         | 264 Mbits/sec   | 594 Mbits/sec   | 76.7 ms
  39. Edgoo           | Sao Paulo, BR (1G)        | 127 Mbits/sec   | 228 Mbits/sec   | 185 ms
  40. iperf3 Network Speed Tests (IPv6):
  41. ---------------------------------
  42. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  43. -----           | -----                     | ----            | ----            | ----
  44. Clouvider       | London, UK (10G)          | 283 Mbits/sec   | 915 Mbits/sec   | 4.47 ms
  45. Eranium         | Amsterdam, NL (100G)      | 282 Mbits/sec   | 916 Mbits/sec   | 9.18 ms
  46. Uztelecom       | Tashkent, UZ (10G)        | 142 Mbits/sec   | 309 Mbits/sec   | 106 ms
  47. Leaseweb        | Singapore, SG (10G)       | 67.7 Mbits/sec  | 495 Mbits/sec   | 207 ms
  48. Clouvider       | Los Angeles, CA, US (10G) | 95.1 Mbits/sec  | 837 Mbits/sec   | 136 ms
  49. Leaseweb        | NYC, NY, US (10G)         | 183 Mbits/sec   | 542 Mbits/sec   | 76.2 ms
  50. Edgoo           | Sao Paulo, BR (1G)        | 138 Mbits/sec   | 254 Mbits/sec   | 184 ms
  1. NAME MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
  2. sda    8:0    0 447.1G  0 disk
  3. sdb    8:16   0 447.1G  0 disk
发表于 2024-11-23 01:53:02 | 只看该作者
阿里系 发表于 2024-11-23 01:08
下行G口也是标配吗?
发表于 2024-11-23 00:59:24 来自手机 | 只看该作者
v4居然中奖 我两台都没中
发表于 2024-11-23 01:01:49 来自手机 | 只看该作者
内存不是
 楼主| 发表于 2024-11-23 01:02:22 | 只看该作者
hacn 发表于 2024-11-23 00:59
v4居然中奖 我两台都没中
可我想要抽个带4T硬盘的
 楼主| 发表于 2024-11-23 01:04:55 | 只看该作者
看另一个帖子这波都是32G
发表于 2024-11-23 01:05:28 来自手机 | 只看该作者
阿里系 发表于 2024-11-23 01:02
可我想要抽个带4T硬盘的
难了 开机的都是最近退掉的垃圾
 楼主| 发表于 2024-11-23 01:07:09 | 只看该作者
hacn 发表于 2024-11-23 01:05
难了 开机的都是最近退掉的垃圾
所以我看看有没有人要这台 回头再收一个
发表于 2024-11-23 01:07:19 | 只看该作者
v4居然中奖 我两台都没中
什么眼神
发表于 2024-11-23 01:08:16 | 只看该作者
难了 开机的都是最近退掉的垃圾
怎么退啊
 楼主| 发表于 2024-11-23 01:08:18 | 只看该作者
下行G口也是标配吗?
GMT+8, 2026-4-24 05:23 , Processed in 0.065654 second(s), 11 queries , Gzip On, MemCache On.
