查看: 1099|回复: 9
[特价VPS] OVH KS-LE-C SSD Nvme款/cpu 内存 硬盘中奖 只测不评了
发表于 2024-11-22 15:50:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. CPU  1630V4
  2. 内存:64G  2400 频率
  3. 硬盘:450G*2 Nvme
  4. 数据中心:加拿大
  5. -------------------------------------------------
  6. Basic System Information:
  7. ---------------------------------
  8. Uptime     : 2 days, 13 hours, 49 minutes
  9. Processor  : Intel(R) Xeon(R) CPU E5-1630 v4 [url=home.php?mod=space&uid=175]@[/url] 3.70GHz
  10. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 3799.935 MHz
  11. AES-NI     : ✔ Enabled
  12. VM-x/AMD-V : ✔ Enabled
  13. RAM        : 62.7 GiB
  14. Swap       : 4.0 GiB
  15. Disk       : 822.4 GiB
  16. Distro     : Debian GNU/Linux 12 (bookworm)
  17. Kernel     : 6.1.0-27-amd64
  18. VM Type    : NONE
  19. IPv4/IPv6  : ✔ Online / ✔ Online
  20. IPv6 Network Information:
  21. ---------------------------------
  22. ISP        : OVH SAS
  23. ASN        : AS16276 OVH SAS
  24. Host       : OVH Hosting, Inc
  25. Location   : Beauharnois, Quebec (QC)
  26. Country    : Canada
  27. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md1):
  28. ---------------------------------
  29. Block Size | 4k            (IOPS) | 64k           (IOPS)
  30.   ------   | ---            ----  | ----           ----
  31. Read       | 512.57 MB/s (128.1k) | 580.36 MB/s   (9.0k)
  32. Write      | 513.92 MB/s (128.4k) | 583.42 MB/s   (9.1k)
  33. Total      | 1.02 GB/s   (256.6k) | 1.16 GB/s    (18.1k)
  34.            |                      |
  35. Block Size | 512k          (IOPS) | 1m            (IOPS)
  36.   ------   | ---            ----  | ----           ----
  37. Read       | 589.74 MB/s   (1.1k) | 640.44 MB/s    (625)
  38. Write      | 621.08 MB/s   (1.2k) | 683.09 MB/s    (667)
  39. Total      | 1.21 GB/s     (2.3k) | 1.32 GB/s     (1.2k)
  40. iperf3 Network Speed Tests (IPv4):
  41. ---------------------------------
  42. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  43. -----           | -----                     | ----            | ----            | ----
  44. Clouvider       | London, UK (10G)          | 273 Mbits/sec   | 894 Mbits/sec   | 80.7 ms
  45. Eranium         | Amsterdam, NL (100G)      | 275 Mbits/sec   | 795 Mbits/sec   | 90.8 ms
  46. Uztelecom       | Tashkent, UZ (10G)        | 256 Mbits/sec   | 777 Mbits/sec   | 190 ms
  47. Leaseweb        | Singapore, SG (10G)       | 236 Mbits/sec   | 617 Mbits/sec   | 234 ms
  48. Clouvider       | Los Angeles, CA, US (10G) | 275 Mbits/sec   | busy            | 72.8 ms
  49. Leaseweb        | NYC, NY, US (10G)         | 290 Mbits/sec   | 938 Mbits/sec   | 10.5 ms
  50. Edgoo           | Sao Paulo, BR (1G)        | 263 Mbits/sec   | 855 Mbits/sec   | 120 ms
  51. iperf3 Network Speed Tests (IPv6):
  52. ---------------------------------
  53. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  54. -----           | -----                     | ----            | ----            | ----
  55. Clouvider       | London, UK (10G)          | 274 Mbits/sec   | 885 Mbits/sec   | 80.7 ms
  56. Eranium         | Amsterdam, NL (100G)      | 269 Mbits/sec   | 785 Mbits/sec   | 90.8 ms
  57. Uztelecom       | Tashkent, UZ (10G)        | 251 Mbits/sec   | 736 Mbits/sec   | 190 ms
  58. Leaseweb        | Singapore, SG (10G)       | 233 Mbits/sec   | 682 Mbits/sec   | 234 ms
  59. Clouvider       | Los Angeles, CA, US (10G) | 271 Mbits/sec   | 888 Mbits/sec   | 71.8 ms
  60. Leaseweb        | NYC, NY, US (10G)         | 286 Mbits/sec   | 925 Mbits/sec   | 10.6 ms
  61. Edgoo           | Sao Paulo, BR (1G)        | 258 Mbits/sec   | 803 Mbits/sec   | 120 ms
  62. ------------------------------------------
  63. Geekbench 6 Benchmark Test:
  64. ---------------------------------
  65. Test            | Value
  66.                 |
  67. Single Core     | 1233
  68. Multi Core      | 4235
  69. Full Test       | https://browser.geekbench.com/v6/cpu/9002974
发表于 2024-11-22 16:15:35 | 只看该作者
因为 这款 比B还差  价格比B还贵 3欧 所以没有突出点 除了内存 64G 其他都比不过B  E就更不要说了 E直接全方位碾压
 楼主| 发表于 2024-11-22 16:05:00 | 只看该作者
怎么没有人关注呢,专门测试的,这款不香吗?
发表于 2024-11-22 16:09:43 来自手机 | 只看该作者
加拿大刚开的吗?
发表于 2024-12-20 18:04:40 | 只看该作者
招财猫 发表于 2024-11-22 16:15
因为 这款 比B还差  价格比B还贵 3欧 所以没有突出点 除了内存 64G 其他都比不过B  E就更不要说了 E直接全 ...
大佬推荐哪一款?
发表于 2024-12-20 19:29:01 | 只看该作者
小俊哟 发表于 2024-12-20 18:04
大佬推荐哪一款?
小需求上B 9.9   需求高点上E 6核12线程 64G
GMT+8, 2026-4-27 15:17 , Processed in 0.063688 second(s), 10 queries , Gzip On, MemCache On.
