查看: 902|回复: 3
[不限流量] [已出]出OVH IE区法国SYS-LE-3,512G NVME+4x12T HDD大盘鸡
发表于 2024-11-21 16:30:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1.   第 1 块硬盘           通电 24182 小时,型号 WDC CL SN720 SDAQNTW-512G-2000
  2.   第 1 块硬盘           通电 33888 小时,型号 HGST HUH721212ALE601
  3.   第 2 块硬盘           通电 33241 小时,型号 HGST HUH721212ALE601
  4.   第 3 块硬盘           通电 35966 小时,型号 HGST HUH721212ALE601
  5.   第 4 块硬盘           通电 35968 小时,型号 HGST HUH721212ALE601
  1. SMART/Health Information (NVMe Log 0x02)
  2. Critical Warning:                   0x00
  3. Temperature:                        40 Celsius
  4. Available Spare:                    100%
  5. Available Spare Threshold:          10%
  6. Percentage Used:                    10%
  7. Data Units Read:                    39,525,924 [20.2 TB]
  8. Data Units Written:                 105,924,206 [54.2 TB]
  9. Host Read Commands:                 367,046,492
  10. Host Write Commands:                1,443,591,806
  11. Controller Busy Time:               4,047
  12. Power Cycles:                       66
  13. Power On Hours:                     24,182
  14. Unsafe Shutdowns:                   62
  15. Media and Data Integrity Errors:    0
  16. Error Information Log Entries:      0
  17. Warning  Comp. Temperature Time:    0
  18. Critical Comp. Temperature Time:    0
  1. Basic System Information:
  3. Uptime     : 0 days, 1 hours, 50 minutes
  4. Processor  : Intel(R) Xeon(R) E-2236 CPU [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  5. CPU cores  : 12 [url=home.php?mod=space&uid=175]@[/url] 799.865 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 31.1 GiB
  9. Swap       : 512.0 MiB
  10. Disk       : 467.9 GiB
  11. Distro     : Debian GNU/Linux 12 (bookworm)
  12. Kernel     : 6.1.0-27-amd64
  13. VM Type    : NONE
  14. IPv4/IPv6  : ✔ Online / ✔ Online
  15. IPv6 Network Information:
  16. ---------------------------------
  17. ISP        : OVH SAS
  18. ASN        : AS16276 OVH SAS
  19. Host       : OVH SAS
  20. Location   : Roubaix, Hauts-de-France (HDF)
  21. Country    : France
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/nvme0n1p3):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 628.37 MB/s (157.0k) | 844.08 MB/s  (13.1k)
  27. Write      | 630.03 MB/s (157.5k) | 848.52 MB/s  (13.2k)
  28. Total      | 1.25 GB/s   (314.6k) | 1.69 GB/s    (26.4k)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 682.09 MB/s   (1.3k) | 651.12 MB/s    (635)
  33. Write      | 718.33 MB/s   (1.4k) | 694.49 MB/s    (678)
  34. Total      | 1.40 GB/s     (2.7k) | 1.34 GB/s     (1.3k)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | 486 Mbits/sec   | 940 Mbits/sec   | 4.83 ms
  40. Eranium         | Amsterdam, NL (100G)      | 485 Mbits/sec   | 940 Mbits/sec   | 9.15 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | 419 Mbits/sec   | 753 Mbits/sec   | 97.1 ms
  42. Leaseweb        | Singapore, SG (10G)       | 398 Mbits/sec   | 465 Mbits/sec   | 211 ms
  43. Clouvider       | Los Angeles, CA, US (10G) | 394 Mbits/sec   | 835 Mbits/sec   | 140 ms
  44. Leaseweb        | NYC, NY, US (10G)         | 447 Mbits/sec   | 817 Mbits/sec   | 76.0 ms
  45. Edgoo           | Sao Paulo, BR (1G)        | busy            | 799 Mbits/sec   | 185 ms
  46. iperf3 Network Speed Tests (IPv6):
  47. ---------------------------------
  48. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  49. -----           | -----                     | ----            | ----            | ----
  50. Clouvider       | London, UK (10G)          | 479 Mbits/sec   | 927 Mbits/sec   | 4.64 ms
  51. Eranium         | Amsterdam, NL (100G)      | 478 Mbits/sec   | 926 Mbits/sec   | 9.17 ms
  52. Uztelecom       | Tashkent, UZ (10G)        | 438 Mbits/sec   | 811 Mbits/sec   | 97.2 ms
  53. Leaseweb        | Singapore, SG (10G)       | 392 Mbits/sec   | 675 Mbits/sec   | 212 ms
  54. Clouvider       | Los Angeles, CA, US (10G) | 392 Mbits/sec   | 817 Mbits/sec   | 140 ms
  55. Leaseweb        | NYC, NY, US (10G)         | 419 Mbits/sec   | 797 Mbits/sec   | 76.0 ms
  56. Edgoo           | Sao Paulo, BR (1G)        | 398 Mbits/sec   | 793 Mbits/sec   | 185 ms
  57. Geekbench 6 Benchmark Test:
  58. ---------------------------------
  59. Test            | Value
  60.                 |
  61. Single Core     | 1780
  62. Multi Core      | 7036
  63. Full Test       | https://browser.geekbench.com/v6/cpu/8983669
  64. YABS completed in 11 min 44 sec
细节说明:
1、请再次阅读一次本帖标题。
官网购买地址:
https://eco.ovhcloud.com/en-ie/soyoustart/sys-le-3/
2、这台机器是OVH IE区的。
法国RBX5数据中心。
安装费59.99欧元。
月付,无合约,续费价59.99欧元,到期日2024年12月21日。
3、请自备OVH IE免税账号,我不出账号。
4、买家先款。支付方式可以详谈,买家先款。
只要标题没有“[已出]”的前缀字样,表示这台机器还在。
如果你想购买这台机器,请你把你的联系方式通过站内私信的方式告诉我,而不是问我什么联系方式。
5、这台机器是1gbps下行,500mbps上行,不限流。
因为我对万兆下行有刚需,所以这台机器对我没有任何意义。
因此我自刀一半安装费,只为回血,即买家只需要支付我一半安装费和首月月租,合计688元。
6、我持有不止一台上述情况的机器。
它们的IPV4和IPV6都国内可正常直连。
请仔细阅读上述情况的描述文字,它们的硬件型号都是一致的,其他时间寿命啥的当然会有区别。
7、为了节省字数,已删除测试脚本的无用文字。
我本帖没有提供的信息就是我不方便提供,我拒绝提供任何关于这台机器的其他信息。
8、如果你私信我,默认你已接受上述所有文字提及的全部细节。
请注意:我已经在上文中详细说明了所有交易细节。尊重他人的最佳方式是仔细阅读我所写的每一个字,并确保完全理解。如果你忽视这点而表现出不尊重的行为,你将需要承担我不友善态度的后果。
发表于 2024-11-21 16:39:47 | 只看该作者
专业申明,楼主大业务啊
发表于 2024-11-21 18:22:40 | 只看该作者
大盘鸡真爱啊
GMT+8, 2026-4-28 01:04 , Processed in 0.059496 second(s), 10 queries , Gzip On, MemCache On.
