查看: 1353|回复: 8
sys-le-3 开机,来个测试
发表于 2024-11-20 23:38:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下了 ks-le-1 和 sys-le-3
sys-le-3 已经交付,哪位有个测试脚本,安装个系统后跑一下。
# 更新 :
服务区发500mb,收10G,其他标配
  3. #                     v2024-06-09                    #
  6. Thu Nov 21 01:41:10 UTC 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 14 minutes
  10. Processor  : Intel(R) Xeon(R) E-2236 CPU [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 12 [url=home.php?mod=space&uid=175]@[/url] 4665.799 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.1 GiB
  15. Swap       : 512.0 MiB
  16. Disk       : 467.9 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-27-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH
  26. Location   : Roubaix, Hauts-de-France (HDF)
  27. Country    : France
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/nvme0n1p3):
  32. Read       | 637.17 MB/s (159.2k) | 735.20 MB/s  (11.4k)
  33. Write      | 638.85 MB/s (159.7k) | 739.07 MB/s  (11.5k)
  34. Total      | 1.27 GB/s   (319.0k) | 1.47 GB/s    (23.0k)
  38. Read       | 688.30 MB/s   (1.3k) | 640.24 MB/s    (625)
  39. Write      | 724.87 MB/s   (1.4k) | 682.88 MB/s    (666)
  40. Total      | 1.41 GB/s     (2.7k) | 1.32 GB/s     (1.2k)
  45. Clouvider       | London, UK (10G)          | 484 Mbits/sec   | 8.05 Gbits/sec  | 4.49 ms
  46. Eranium         | Amsterdam, NL (100G)      | busy            | busy            | 5.83 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 447 Mbits/sec   | 1.28 Gbits/sec  | 107 ms
  48. Leaseweb        | Singapore, SG (10G)       | busy            | busy            | 207 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 418 Mbits/sec   | busy            | 139 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 458 Mbits/sec   | busy            | 80.1 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 410 Mbits/sec   | 910 Mbits/sec   | 183 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 478 Mbits/sec   | 5.65 Gbits/sec  | 4.48 ms
  57. Eranium         | Amsterdam, NL (100G)      | 476 Mbits/sec   | 9.16 Gbits/sec  | 5.85 ms
发表于 2024-11-20 23:49:36 | 只看该作者
  1. curl -sL yabs.sh | bash
 楼主| 发表于 2024-11-20 23:53:00 | 只看该作者
tks
晚点更新测试结果
发表于 2024-11-21 00:13:50 | 只看该作者
MrJet 发表于 2024-11-20 23:53
tks
晚点更新测试结果
下单多久开通的,我也下了一单,快半个小时了
发表于 2024-11-21 00:20:35 | 只看该作者
我9点半到现在都没开
发表于 2024-11-21 00:31:37 来自手机 | 只看该作者
15 分钟。
发表于 2024-11-21 01:00:05 | 只看该作者
我新注册的吃码咋还提示要安装费呢??
发表于 2024-11-21 01:48:16 来自手机 | 只看该作者
还没结果呢
 楼主| 发表于 2024-11-21 09:45:50 | 只看该作者
  3. #                     v2024-06-09                    #
  11. CPU cores  : 12 @ 4665.799 MHz
  14. RAM        : 31.1 GiB
  19. VM Type    : NONE
  23. ISP        : OVH SAS
  25. Host       : OVH
GMT+8, 2026-4-23 14:53 , Processed in 0.061734 second(s), 10 queries , Gzip On, MemCache On.
