查看: 1631|回复: 11
[美国VPS] 【已出】PUSH出CA区的KS-LE-C 加拿大机房, 内存和CPU中奖
发表于 2024-11-16 13:06:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
账号所在区域 : CA
服务器所在区域 : Canada
中奖信息:
Intel Xeon E5-1620v2 -> Intel Xeon(R) CPU E5-1630 v4
32 GB -> 64 GB
Yabs信息:
  3. #                     v2024-06-09                    #
  6. Sat Nov 16 04:17:20 UTC 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 1 hours, 9 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E5-1630 v4 [url=home.php?mod=space&uid=175]@[/url] 3.70GHz
  11. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 2509.036 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 62.7 GiB
  15. Swap       : 1024.0 MiB
  16. Disk       : 438.4 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-27-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH Hosting, Inc
  26. Location   : Beauharnois, Quebec (QC)
  27. Country    : Canada
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  32. Read       | 121.52 MB/s  (30.3k) | 187.42 MB/s   (2.9k)
  33. Write      | 121.84 MB/s  (30.4k) | 188.41 MB/s   (2.9k)
  34. Total      | 243.37 MB/s  (60.8k) | 375.83 MB/s   (5.8k)
  38. Read       | 175.73 MB/s    (343) | 191.14 MB/s    (186)
  39. Write      | 185.06 MB/s    (361) | 203.87 MB/s    (199)
  40. Total      | 360.79 MB/s    (704) | 395.01 MB/s    (385)
  45. Clouvider       | London, UK (10G)          | 268 Mbits/sec   | 902 Mbits/sec   | 84.0 ms
  46. Eranium         | Amsterdam, NL (100G)      | 256 Mbits/sec   | 774 Mbits/sec   | 86.4 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 255 Mbits/sec   | 647 Mbits/sec   | 176 ms
  48. Leaseweb        | Singapore, SG (10G)       | 226 Mbits/sec   | 371 Mbits/sec   | 236 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 270 Mbits/sec   | 340 Mbits/sec   | 68.3 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 291 Mbits/sec   | 938 Mbits/sec   | 9.80 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 258 Mbits/sec   | 851 Mbits/sec   | 118 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 261 Mbits/sec   | 888 Mbits/sec   | 84.0 ms
  57. Eranium         | Amsterdam, NL (100G)      | 264 Mbits/sec   | 791 Mbits/sec   | 86.4 ms
  58. Uztelecom       | Tashkent, UZ (10G)        | 248 Mbits/sec   | 784 Mbits/sec   | 176 ms
  59. Leaseweb        | Singapore, SG (10G)       | 225 Mbits/sec   | 686 Mbits/sec   | 236 ms
  60. Clouvider       | Los Angeles, CA, US (10G) | 238 Mbits/sec   | 890 Mbits/sec   | 68.3 ms
  61. Leaseweb        | NYC, NY, US (10G)         | 286 Mbits/sec   | 926 Mbits/sec   | 9.95 ms
  62. Edgoo           | Sao Paulo, BR (1G)        | 262 Mbits/sec   | 851 Mbits/sec   | 118 ms
  63. Geekbench 6 Benchmark Test:
  64. ---------------------------------
  65. Test            | Value
  66.                 |
  67. Single Core     | 1369
  68. Multi Core      | 4759
  69. Full Test       | https://browser.geekbench.com/v6/cpu/8862105
硬盘信息
  1. Examining hard disk configuration ...
  2. HDD Device  0: /dev/sda
  3. HDD Model ID : INTEL SSDSC2BB480G7
  4. HDD Serial No: BTDV718406B4480BGN
  5. HDD Revision : N2010121
  6. HDD Size     : 457863 MB
  7. Interface    : S-ATA Gen3, 6 Gbps
  8. Temperature  : 24 °C
  9. Highest Temp.: 25 °C
  10. Health       : 95 %
  11. Performance  : 100 %
  12. Power on time: 2358 days, 10 hours
  13. Est. lifetime: more than 95 days
  14. Total written: 65.52 TB
  15.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  16.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  #233 Media Wearout Indicator
  17.     No actions needed.
  18. HDD Device  1: /dev/sdb
  19. HDD Model ID : INTEL SSDSC2BB480G7
  20. HDD Serial No: BTDV71830673480BGN
  21. HDD Revision : N2010121
  22. HDD Size     : 457863 MB
  23. Interface    : S-ATA Gen3, 6 Gbps
  24. Temperature  : 23 °C
  25. Highest Temp.: 23 °C
  26. Health       : 95 %
  27. Performance  : 100 %
  28. Power on time: 2358 days, 10 hours
  29. Est. lifetime: more than 95 days
  30. Total written: 65.22 TB
  31.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  32.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  #233 Media Wearout Indicator
  33.     No actions needed.
发表于 2024-11-16 19:16:13 来自手机 | 只看该作者
小胖仔 发表于 2024-11-16 19:07
收到,多谢
 楼主| 发表于 2024-11-16 19:07:07 | 只看该作者
飘云 发表于 2024-11-16 17:35
这是什么硬盘脚本?
  1. wget -c https://www.hdsentinel.com/hdslin/hdsentinel-019c-x64.gz
  2. gunzip  hdsentinel-019c-x64.gz
  3. chmod 755  hdsentinel-019c-x64
  4. ./hdsentinel-019c-x64
发表于 2024-11-16 13:11:50 来自手机 | 只看该作者
我有一台 跟你一样   没想到能溢价400
发表于 2024-11-16 13:15:18 | 只看该作者
机器性价比很不错
发表于 2024-11-16 13:16:22 | 只看该作者
带不带账号出?
发表于 2024-11-16 13:19:23 | 只看该作者
帮顶,要不起
发表于 2024-11-16 16:37:37 来自手机 | 只看该作者
这是什么硬盘脚本?
发表于 2024-11-16 17:35:05 | 只看该作者
这是什么硬盘脚本?
GMT+8, 2026-4-16 20:53 , Processed in 0.068630 second(s), 10 queries , Gzip On, MemCache On.
