查看: 1727|回复: 11
8号买的ovh KS-LE-A开机了,已中奖
发表于 2024-11-12 19:46:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
内存翻倍,cpu小奖,钻石盘
yabs
  3. #                     v2024-06-09                    #
  6. Tue Nov 12 11:17:59 UTC 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 24 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 8 @ 2458.305 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 1.5 GiB
  16. Disk       : 1.8 TiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-26-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH Hosting, Inc
  26. Location   : Beauharnois, Quebec (QC)
  27. Country    : Canada
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md2):
  32. Read       | 908.00 KB/s    (227) | 12.98 MB/s     (202)
  33. Write      | 946.00 KB/s    (236) | 13.60 MB/s     (212)
  34. Total      | 1.85 MB/s      (463) | 26.59 MB/s     (414)
  38. Read       | 50.04 MB/s      (97) | 67.30 MB/s      (65)
  39. Write      | 52.78 MB/s     (103) | 71.78 MB/s      (70)
  40. Total      | 102.83 MB/s    (200) | 139.09 MB/s    (135)
  45. Clouvider       | London, UK (10G)          | 263 Mbits/sec   | 120 Mbits/sec   | 78.7 ms
  46. Leaseweb        | Singapore, SG (10G)       | 119 Mbits/sec   | 331 Mbits/sec   | 246 ms
  47. Leaseweb        | NYC, NY, US (10G)         | 286 Mbits/sec   | 516 Mbits/sec   | 9.42 ms
  48. iperf3 Network Speed Tests (IPv6):
  49. ---------------------------------
  50. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  51. -----           | -----                     | ----            | ----            | ----
  52. Clouvider       | London, UK (10G)          | 590 Mbits/sec   | 141 Mbits/sec   | 78.7 ms
  53. Leaseweb        | Singapore, SG (10G)       | 300 Mbits/sec   | 416 Mbits/sec   | 246 ms
  54. Leaseweb        | NYC, NY, US (10G)         | 856 Mbits/sec   | 551 Mbits/sec   | 9.30 ms
  55. Geekbench 5 Benchmark Test:
  56. ---------------------------------
  57. Test            | Value
  58.                 |
  59. Single Core     | 913
  60. Multi Core      | 3527
  61. Full Test       | https://browser.geekbench.com/v5/cpu/23055872
  62. Geekbench 6 Benchmark Test:
  63. ---------------------------------
  64. Test            | Value
  65.                 |
  66. Single Core     | 772
  67. Multi Core      | 2681
  68. Full Test       | https://browser.geekbench.com/v6/cpu/8796284
  69. YABS completed in 17 min 35 sec
能不能分20g内存当缓存盘?
发表于 2024-11-12 19:53:43 | 只看该作者
CPU有超线程了,还不错
发表于 2024-11-12 20:11:07 | 只看该作者
这么晚开机
发表于 2024-11-12 20:11:21 | 只看该作者
这款续费多少刀一年啊?
发表于 2024-11-12 20:29:00 | 只看该作者
可以尝试,但需确保系统剩余内存充足。
发表于 2024-11-12 20:53:40 | 只看该作者
这个U有核显吗
 楼主| 发表于 2024-11-12 21:00:06 | 只看该作者
卡尔 发表于 2024-11-12 20:11
这款续费多少刀一年啊?
10欧安装费+10欧每月
 楼主| 发表于 2024-11-12 21:02:06 | 只看该作者
好像有
  1. lspci | grep -i vga
  2. 00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller (rev 09)
发表于 2024-11-12 21:05:12 | 只看该作者
一模一样 8号开的 也中奖了 不过这钻石盘能用吗
GMT+8, 2026-4-15 07:25 , Processed in 0.064009 second(s), 10 queries , Gzip On, MemCache On.
