查看: 3498|回复: 37
[疑问] 求助一个PHP Curl网页源码动态的问题
发表于 2024-11-11 13:46:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
先道声谢谢了。
视频演示:https://thumbsnap.com/qkDgKM5o
网址信息:https://www.toutiao.com/video/7418557232318513703/
我使用PHP的url获取一个网页的时候,它的网页内容一直在跳动,不能获取完整,我知道可能是使用了js动态创建的,但有技术或方法可以获取完整的内容吗?谢谢了
  1. /*
  2. *  今日头条video页面的文件头
  3. **/
  4. function toutiao_html_header($url)
  5. {
  6.     $header = array(
  7.         "Host: https://www.toutiao.com",
  8.         "Referer: {$url}",
  9.         "set-cookie: tt_webid=7421001700129736202; path=/; expires=Sun, 09 Feb 2025 04:22:07 GMT; domain=toutiao.com; secure; httponly",
  10.         'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7',
  11.         'Accept-Language:zh-CN,zh;q=0.9,en;q=0.8',
  12.         'cookie: ******************************************************************************',
  13.         "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/130.0.0.0 Safari/537.36",
  14.     );
  15.     return $header;
  16. }
  17. /**
  18. * 模拟浏览器开始访问请求,这个用于今日头条视频的页面内容获取
  19. */
  20. function fetch_toutiao_video_html($url)
  21. {
  22.     $header = toutiao_html_header($url);
  23.     $timeout = 40;
  24.     $ch = curl_init($url);
  25.     curl_setopt($ch, CURLOPT_FAILONERROR, true);
  26.     //设置请求头信息
  27.     #curl_setopt($ch, CURLOPT_HTTPHEADER, $header);
  28.     curl_setopt($ch, CURLOPT_HEADER, $header);
  29.     //不取得返回头信息
  30.     #curl_setopt($ch, CURLOPT_HEADER, 0);
  31.     // 关闭https验证
  32.     curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
  33.     curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, false);
  34.     curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
  35.     curl_setopt($ch, CURLOPT_ENCODING, "");
  36.     curl_setopt($ch, CURLOPT_RETURNTRANSFER, false);
  37.     curl_setopt($ch, CURLOPT_AUTOREFERER, true);
  38.     curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
  39.     curl_setopt($ch, CURLOPT_TIMEOUT, $timeout);
  40.     curl_setopt($ch, CURLOPT_REFERER, $header[1]);
  41.     curl_setopt($ch, CURLOPT_MAXREDIRS, 10);
  42.     curl_setopt($ch, CURLOPT_USERAGENT, $header[6]);
  43.     $content = curl_exec($ch);
  44.     if (curl_errno($ch)) {
  45.         echo 'Error:' . curl_error($ch);
  46.     } else {
  47.         return $content;
  48.     }
  49.     curl_close($ch);
  50. }
 楼主| 发表于 2024-11-11 14:13:30 | 只看该作者
我查了网络上,有几个同样的问题
1、https://wenku.csdn.net/answer/e12d12f453044ecf8d2a3959ec080971
2、https://cloud.tencent.com/developer/ask/sof/104711852/answer/114173132
3、https://cloud.tencent.com/developer/ask/sof/100838855
我不太明白他们回复的方法,请教各位大佬们了,谢谢了
发表于 2024-11-11 14:03:52 | 只看该作者
太高端了 我不会
发表于 2024-11-11 14:21:19 | 只看该作者
可以尝试使用Headless Chrome或Puppeteer来抓取动态生成的内容。
 楼主| 发表于 2024-11-11 14:22:16 | 只看该作者
谢谢您的回复,在php中应该如何使用呢?
发表于 2024-11-11 14:35:44 | 只看该作者
这种动态的网页 我之前研究了很久你百度下:
ChromeDriver抓取动态网页
发表于 2024-11-11 14:43:40 | 只看该作者
做爬虫要先分析网页的结构,而不是直接就写请求,现在的网站很多都是前后端分离动态加载。
发表于 2024-11-11 14:50:23 | 只看该作者
你可以直接curl他的接口api拿内容
发表于 2024-11-11 15:06:31 | 只看该作者
你要获取页面内容不需要输出响应头信息
把这段curl_setopt($ch, CURLOPT_HEADER, $header); 改成curl_setopt($ch, CURLOPT_HEADER, false);
设置头信息函数里面可以把set-cookie相关代码删掉
发表于 2024-11-11 15:16:54 | 只看该作者
python + playwright 轻松搞定,php只能通过浏览器分析接口,直接抓接口
GMT+8, 2026-4-14 08:04 , Processed in 0.067294 second(s), 11 queries , Gzip On, MemCache On.
