查看: 810|回复: 7
OVH ks E 这个硬盘写入量是多少
发表于 2024-11-9 10:03:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. smartctl 7.2 2020-07-07 r5074 [x86_64-linux-6.1.0-26-amd64] (CircleCI)
  2. Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
  3. === START OF INFORMATION SECTION ===
  4. Model Family:     Intel S4510/S4610/S4500/S4600 Series SSDs
  5. Device Model:     INTEL SSDSC2KB480G7
  6. Serial Number:    PHYS7380006G480BGN
  7. LU WWN Device Id: 5 5cd2e4 14e2ca4a1
  8. Firmware Version: SCV10150
  9. User Capacity:    480,103,981,056 bytes [480 GB]
  10. Sector Sizes:     512 bytes logical, 4096 bytes physical
  11. Rotation Rate:    Solid State Device
  12. Form Factor:      2.5 inches
  13. TRIM Command:     Available, deterministic, zeroed
  14. Device is:        In smartctl database [for details use: -P show]
  15. ATA Version is:   ACS-3 T13/2161-D revision 5
  16. SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
  17. Local Time is:    Sat Nov  9 01:29:42 2024 UTC
  18. SMART support is: Available - device has SMART capability.
  19. SMART support is: Enabled
  20. === START OF READ SMART DATA SECTION ===
  21. SMART overall-health self-assessment test result: PASSED
  22. General SMART Values:
  23. Offline data collection status:  (0x02)        Offline data collection activity
  24.                                         was completed without error.
  25.                                         Auto Offline Data Collection: Disabled.
  26. Self-test execution status:      (   0)        The previous self-test routine completed
  27.                                         without error or no self-test has ever
  28.                                         been run.
  29. Total time to complete Offline
  30. data collection:                 (    2) seconds.
  31. Offline data collection
  32. capabilities:                          (0x79) SMART execute Offline immediate.
  33.                                         No Auto Offline data collection support.
  34.                                         Suspend Offline collection upon new
  35.                                         command.
  36.                                         Offline surface scan supported.
  37.                                         Self-test supported.
  38.                                         Conveyance Self-test supported.
  39.                                         Selective Self-test supported.
  40. SMART capabilities:            (0x0003)        Saves SMART data before entering
  41.                                         power-saving mode.
  42.                                         Supports SMART auto save timer.
  43. Error logging capability:        (0x01)        Error logging supported.
  44.                                         General Purpose Logging supported.
  45. Short self-test routine
  46. recommended polling time:          (   1) minutes.
  47. Extended self-test routine
  48. recommended polling time:          (   2) minutes.
  49. Conveyance self-test routine
  50. recommended polling time:          (   2) minutes.
  51. SCT capabilities:                (0x003d)        SCT Status supported.
  52.                                         SCT Error Recovery Control supported.
  53.                                         SCT Feature Control supported.
  54.                                         SCT Data Table supported.
  55. SMART Attributes Data Structure revision number: 1
  56. Vendor Specific SMART Attributes with Thresholds:
  57. ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  58.   5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  59.   9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       46700
  60. 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       47
  61. 170 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
  62. 171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
  63. 172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
  64. 174 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       44
  65. 175 Power_Loss_Cap_Test     0x0033   100   100   010    Pre-fail  Always       -       2506 (322 5223)
  66. 183 SATA_Downshift_Count    0x0032   100   100   000    Old_age   Always       -       0
  67. 184 End-to-End_Error_Count  0x0033   100   100   090    Pre-fail  Always       -       0
  68. 187 Uncorrectable_Error_Cnt 0x0032   100   100   000    Old_age   Always       -       0
  69. 190 Drive_Temperature       0x0022   067   065   000    Old_age   Always       -       33 (Min/Max 32/40)
  70. 192 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       44
  71. 194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       33
  72. 197 Pending_Sector_Count    0x0012   100   100   000    Old_age   Always       -       0
  73. 199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
  74. 225 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       9455369
  75. 226 Workld_Media_Wear_Indic 0x0032   100   100   000    Old_age   Always       -       20398
  76. 227 Workld_Host_Reads_Perc  0x0032   100   100   000    Old_age   Always       -       57
  77. 228 Workload_Minutes        0x0032   100   100   000    Old_age   Always       -       2801659
  78. 232 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
  79. 233 Media_Wearout_Indicator 0x0032   081   081   000    Old_age   Always       -       0
  80. 234 Thermal_Throttle_Status 0x0032   100   100   000    Old_age   Always       -       0/0
  81. 241 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       9455369
  82. 242 Host_Reads_32MiB        0x0032   100   100   000    Old_age   Always       -       12773538
  83. 243 NAND_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       19022017
  84. SMART Error Log Version: 1
  85. No Errors Logged
  86. SMART Self-test log structure revision number 1
  87. Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
  88. # 1  Short offline       Completed without error       00%     46628         -
  89. # 2  Short offline       Aborted by host               00%     46628         -
  90. # 3  Short offline       Completed without error       00%     46626         -
  91. # 4  Short offline       Aborted by host               00%     46626         -
  92. # 5  Short offline       Completed without error       00%     46626         -
  93. # 6  Short offline       Aborted by host               00%     46626         -
  94. # 7  Short offline       Completed without error       00%     15945         -
  95. # 8  Short offline       Aborted by host               00%     15945         -
  96. # 9  Short offline       Completed without error       00%     15943         -
  97. #10  Short offline       Aborted by host               00%     15943         -
  98. #11  Short offline       Completed without error       00%     15943         -
  99. #12  Short offline       Aborted by host               00%     15943         -
  100. #13  Short offline       Completed without error       00%     15937         -
  101. #14  Short offline       Aborted by host               00%     15937         -
  102. #15  Short offline       Completed without error       00%     15936         -
  103. #16  Short offline       Aborted by host               00%     15936         -
  104. #17  Short offline       Completed without error       00%       245         -
  105. #18  Short offline       Aborted by host               00%       245         -
  106. #19  Short offline       Completed without error       00%       244         -
  107. #20  Short offline       Aborted by host               00%       244         -
  108. #21  Short offline       Completed without error       00%       244         -
  109. SMART Selective self-test log data structure revision number 1
  110. SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
  111.     1        0        0  Not_testing
  112.     2        0        0  Not_testing
  113.     3        0        0  Not_testing
  114.     4        0        0  Not_testing
  115.     5        0        0  Not_testing
  116. Selective self-test flags (0x0):
  117.   After scanning selected spans, do NOT read-scan remainder of disk.
  118. If Selective self-test is pending on power-up, resume after 0 minute delay.
 楼主| 发表于 2024-11-9 10:04:50 | 只看该作者
写入量多少?这个SSD硬盘用于放网站还可以吗
发表于 2024-11-9 10:08:44 | 只看该作者
bench.sh
测一下,一般来说,ssd足以。但是nvme是ssd的2倍
发表于 2024-11-9 10:09:43 | 只看该作者
这么明显 9455369*32MB
 楼主| 发表于 2024-11-9 10:15:45 | 只看该作者
iiii.im 发表于 2024-11-9 10:08
bench.sh
4万多小时了啊
发表于 2024-11-9 10:38:38 | 只看该作者
快5万小时了。OVH的都是报废危盘。
发表于 2024-11-9 10:41:15 来自手机 | 只看该作者
hostv 发表于 2024-11-9 10:38
快5万小时了。OVH的都是报废危盘。
我那个ssd九千多小时吧 看人品
发表于 2024-11-9 10:50:07 | 只看该作者
好像没有看到有人用坏过!
GMT+8, 2026-1-14 04:38 , Processed in 0.065563 second(s), 10 queries , Gzip On, MemCache On.
