查看: 1760|回复: 12
[美国VPS] KS-LE-B HDD款开机了 贴一下跑分
发表于 2024-11-6 10:35:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 4 minutes
  4. Processor  : Intel(R) Xeon(R) CPU E3-1245 v6 [url=home.php?mod=space&uid=175]@[/url] 3.70GHz
  5. CPU cores  : 8 @ 800.000 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 31.0 GiB
  9. Swap       : 1024.0 MiB
  10. Disk       : 1.8 TiB
  11. Distro     : Ubuntu 24.04.1 LTS
  12. Kernel     : 6.8.0-47-generic
  13. VM Type    : NONE
  14. IPv4/IPv6  : ✔ Online / ✔ Online
  15. IPv6 Network Information:
  16. ---------------------------------
  17. ISP        : OVH SAS
  18. ASN        : AS16276 OVH SAS
  19. Host       : OVH GmbH
  20. Location   : Saarbrücken, Saarland (SL)
  21. Country    : Germany
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 759.00 KB/s    (189) | 10.88 MB/s     (170)
  27. Write      | 794.00 KB/s    (198) | 11.41 MB/s     (178)
  28. Total      | 1.55 MB/s      (387) | 22.30 MB/s     (348)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 34.38 MB/s      (67) | 42.86 MB/s      (41)
  33. Write      | 36.53 MB/s      (71) | 46.32 MB/s      (45)
  34. Total      | 70.91 MB/s     (138) | 89.19 MB/s      (86)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | 295 Mbits/sec   | 937 Mbits/sec   | 15.3 ms
  40. Eranium         | Amsterdam, NL (100G)      | 297 Mbits/sec   | 939 Mbits/sec   | 9.38 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | 261 Mbits/sec   | 885 Mbits/sec   | 95.2 ms
  42. Leaseweb        | Singapore, SG (10G)       | 255 Mbits/sec   | 704 Mbits/sec   | 163 ms
  43. Clouvider       | Los Angeles, CA, US (10G) | 260 Mbits/sec   | 831 Mbits/sec   | 144 ms
  44. Leaseweb        | NYC, NY, US (10G)         | 281 Mbits/sec   | 802 Mbits/sec   | 85.6 ms
  45. Edgoo           | Sao Paulo, BR (1G)        | 245 Mbits/sec   | 782 Mbits/sec   | 198 ms
  46. iperf3 Network Speed Tests (IPv6):
  47. ---------------------------------
  48. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  49. -----           | -----                     | ----            | ----            | ----
  50. Clouvider       | London, UK (10G)          | 291 Mbits/sec   | 924 Mbits/sec   | 15.2 ms
  51. Eranium         | Amsterdam, NL (100G)      | 293 Mbits/sec   | 926 Mbits/sec   | 9.31 ms
  52. Uztelecom       | Tashkent, UZ (10G)        | 254 Mbits/sec   | 872 Mbits/sec   | 95.1 ms
  53. Leaseweb        | Singapore, SG (10G)       | 245 Mbits/sec   | 686 Mbits/sec   | 163 ms
  54. Clouvider       | Los Angeles, CA, US (10G) | busy            | 834 Mbits/sec   | 144 ms
  55. Leaseweb        | NYC, NY, US (10G)         | 261 Mbits/sec   | 812 Mbits/sec   | 85.5 ms
  56. Edgoo           | Sao Paulo, BR (1G)        | 241 Mbits/sec   | 773 Mbits/sec   | 198 ms
  57. Geekbench 6 Benchmark Test:
  58. ---------------------------------
  59. Test            | Value
  60.                 |
  61. Single Core     | 1448
  62. Multi Core      | 5045
发表于 2024-11-6 10:40:08 | 只看该作者
石头盘,连带宽好像都被你的石头盘限制了。
发表于 2024-11-6 10:41:02 来自手机 | 只看该作者
嘿嘿,垃圾鸡
发表于 2024-11-6 10:43:33 来自手机 | 只看该作者
石头盘,拉不动
发表于 2024-11-6 10:48:18 来自手机 | 只看该作者
这硬盘速度,还不如内存卡吧
发表于 2024-11-6 10:50:04 | 只看该作者
难受。。石头盘+1
https://loc.qiche.eu.org/thread-1360571-1-1.html
  1. [root@ns50xxx ~]# smartctl -A /dev/sda | grep -iE "up_time|power_on"
  2.   3 Spin_Up_Time            0x0007   100   100   024    Pre-fail  Always       -       377
  3.   9 Power_On_Hours          0x0012   089   089   000    Old_age   Always       -       82903
  4. [root@ns501xxx ~]# smartctl -A /dev/sdb | grep -iE "up_time|power_on"
  5.   3 Spin_Up_Time            0x0007   100   100   024    Pre-fail  Always       -       386
  6.   9 Power_On_Hours          0x0012   091   091   000    Old_age   Always       -       69515
  7. [root@ns501xxx ~]# smartctl -A /dev/sdc | grep -iE "up_time|power_on"
  8.   3 Spin_Up_Time            0x0007   138   138   024    Pre-fail  Always       -       216 (Average 217)
  9.   9 Power_On_Hours          0x0012   093   093   000    Old_age   Always       -       50786
发表于 2024-11-6 10:56:28 | 只看该作者
  1. Processor  : Intel(R) Xeon(R) CPU E3-1245 v6 [url=home.php?mod=space&uid=175]@[/url] 3.70GHz
  2. CPU cores  : 8 @ 899.977 MHz
  3. AES-NI     : ✔ Enabled
  4. VM-x/AMD-V : ✔ Enabled
  5. RAM        : 31.0 GiB
  6. Swap       : 1024.0 MiB
  7. Disk       : 822.4 GiB
  8. Distro     : Debian GNU/Linux 12 (bookworm)
  9. Kernel     : 6.1.0-26-amd64
  10. VM Type    : NONE
  11. IPv4/IPv6  : ✔ Online / ✔ Online
  12. IPv6 Network Information:
  13. ---------------------------------
  14. ISP        : OVH SAS
  15. ASN        : AS16276 OVH SAS
  16. Host       : OVH GmbH
  17. Location   : Saarbrücken, Saarland (SL)
  18. Country    : Germany
  19. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 509.70 MB/s (127.4k) | 692.14 MB/s  (10.8k)
  24. Write      | 511.05 MB/s (127.7k) | 695.78 MB/s  (10.8k)
  25. Total      | 1.02 GB/s   (255.1k) | 1.38 GB/s    (21.6k)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 717.80 MB/s   (1.4k) | 753.92 MB/s    (736)
  30. Write      | 755.94 MB/s   (1.4k) | 804.13 MB/s    (785)
  31. Total      | 1.47 GB/s     (2.8k) | 1.55 GB/s     (1.5k)
  32. Geekbench 6 Benchmark Test:
  33. ---------------------------------
  34. Test            | Value
  35.                 |
  36. Single Core     | 1525
  37. Multi Core      | 5245
  38. Full Test       | https://browser.geekbench.com/v6/cpu/8677244
NVMe款绑定。
发表于 2024-11-6 11:02:39 来自手机 | 只看该作者
你这跟我的hdd差很多啊
 楼主| 发表于 2024-11-6 11:05:00 | 只看该作者
耗子尾汁 发表于 2024-11-6 11:02
你这跟我的hdd差很多啊
是不是和组了raid有关?
发表于 2024-11-6 11:08:57 来自手机 | 只看该作者
llol9420 发表于 2024-11-6 11:05
是不是和组了raid有关?
我没组啊
GMT+8, 2026-4-23 07:54 , Processed in 0.067910 second(s), 10 queries , Gzip On, MemCache On.
