CeraNetworks网络延迟测速工具IP归属甄别
查看: 5014|回复: 6
c大看过来。来。。。
发表于 2010-4-1 08:27:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
演示站里的两个网站 8bar8.com和www.emsgaming.com/  应该都是芝加哥机房的。但是为什么tracert出来走的线路不一样呢。
8bar8
Microsoft Windows XP [版本 5.1.2600]
(C) 版权所有 1985-2001 Microsoft Corp.
C:\Documents and Settings\Administrator>tracert 8bar8.com
Tracing route to 8bar8.com [66.90.101.124]
over a maximum of 30 hops:
  1     1 ms     1 ms     1 ms  DeDeB [192.168.3.1]
  2     2 ms     2 ms     2 ms  192.168.2.1
  3     4 ms     2 ms     2 ms  220.115.183.1
  4     2 ms     2 ms     2 ms  172.16.253.137
  5     4 ms     2 ms     2 ms  172.16.251.61
  6     4 ms     4 ms     2 ms  172.16.251.10
  7     5 ms     4 ms     4 ms  210.77.87.1
  8     3 ms     4 ms     4 ms  192.168.8.2
  9    37 ms    37 ms    37 ms  159.226.46.129
10    39 ms    37 ms    37 ms  8.200 [159.226.254.233]
11    38 ms    51 ms    37 ms  8.198 [159.226.254.30]
12   234 ms   234 ms   235 ms  194.25.210.105
13   237 ms   235 ms   238 ms  lax-sa1-i.LAX.US.NET.DTAG.DE [62.154.14.105]
14   233 ms   232 ms   234 ms  217.239.40.106
15   235 ms   234 ms   234 ms  217.243.217.74
16   282 ms   282 ms   283 ms  if-2-0-0-854.core1.CT8-Chicago.as6453.net [216.6
.30.58]
17   285 ms   287 ms     *     Vlan18.icore1.CT8-Chicago.as6453.net [66.110.14.
34]
18   273 ms   273 ms   274 ms  Vlan541.icore1.CT8-Chicago.as6453.net [206.82.14
1.78]
19   274 ms     *        *     66.90.127.177 [66.90.127.177]
20   281 ms   282 ms   280 ms  . [66.90.101.124]
Trace complete.
www.emsgaming.com/
C:\Documents and Settings\Administrator>tracert www.emsgaming.com
Tracing route to www.emsgaming.com [74.63.66.82]
  3     3 ms     4 ms     2 ms  220.115.183.1
  5     2 ms     2 ms     2 ms  172.16.253.138
  6     3 ms     4 ms     2 ms  172.16.253.174
  7     4 ms     4 ms     4 ms  210.77.87.1
  8     4 ms     4 ms     4 ms  192.168.8.2
  9    38 ms    37 ms    37 ms  159.226.46.129
10    38 ms    37 ms    37 ms  8.201 [159.226.254.245]
11    39 ms    39 ms    38 ms  8.198 [159.226.254.158]
12   236 ms   235 ms   234 ms  194.25.210.105
13   301 ms   299 ms   299 ms  lax-sa1-i.LAX.US.NET.DTAG.DE [62.154.14.105]
14   297 ms   296 ms   303 ms  was-sa3-i.WAS.US.NET.DTAG.DE [62.154.5.10]
15   300 ms   297 ms   298 ms  194.25.209.42
16   298 ms   298 ms   298 ms  pos-2-3-0-0-cr01.mclean.va.ibone.comcast.net [68
.86.86.29]
17   294 ms   295 ms   294 ms  pos-0-14-0-0-cr01.newyork.ny.ibone.comcast.net [
68.86.85.94]
18   303 ms   302 ms   302 ms  pos-2-10-0-0-cr01.chicago.il.ibone.comcast.net [
68.86.86.114]
19   304 ms   303 ms   304 ms  pos-0-3-0-0-pe01.350ecermak.il.ibone.comcast.net
[68.86.86.158]
20     *        *        *     Request timed out.
21   295 ms   294 ms   295 ms  . [74.63.66.82]
Trace complete.
发表于 2010-4-1 09:07:53 | 只看该作者
你是长城宽带? 前面那个是到德国电信再经过TATA线路到FDC芝加哥机房,后面的那个路由跟踪是到德国电信再经过Comcast线路到FDC芝加哥机房。
动态路由选择,因为FDC机房是BGP线路,有多条线路可以选择。
PS: 电信访问FDC芝加哥机房都是走的Comcast线路。
发表于 2010-4-1 09:17:59 | 只看该作者
FDC官网我这儿打开非常快。
看了一下他的独服,MS比84更有吸引力。
 楼主| 发表于 2010-4-1 09:22:16 | 只看该作者
   明白了 。我是长城宽带为什么会两个站不一样的路线呢?
网通访问FDC芝加哥机房是走什么路线呢?
发表于 2010-4-1 11:25:44 | 只看该作者
楼主的长宽怎么走了科技网的节点啊:
 楼主| 发表于 2010-4-1 13:37:41 | 只看该作者
原帖由 Black-Xstar 于 2010-4-1 11:25 发表
楼主的长宽怎么走了科技网的节点啊:
11    38 ms    51 ms    37 ms  8.198 [159.226.254.30] ...
不知道,一直如此。可能我的长宽账号是公网ip的缘故吧。
发表于 2010-4-1 19:00:06 | 只看该作者
原帖由 mayapop1 于 2010-4-1 09:22 发表
动态路由,由你的ISP长城宽带决定的线路。
网通访问FDC芝加哥机房走的Comcast线路。
GMT+8, 2026-4-20 17:44 , Processed in 0.058266 second(s), 10 queries , Gzip On, MemCache On.
