楼主: Favsky
[疑问] 请问那个命令可以查看vps的那个程序卡住了?
 楼主| 发表于 2010-4-1 00:20:23 | 只看该作者
http://76.164.231.72   很慢打开
发表于 2010-4-1 00:24:35 | 只看该作者
/usr/local/php/sbin/php-fpm restart
重启服务看看..没可能0字节的....
配置你改过?
发表于 2010-4-1 00:25:26 | 只看该作者
SWAP都用了
top
然后按大写M.给我看看...冲凉去
 楼主| 发表于 2010-4-1 00:26:51 | 只看该作者
原帖由 shinko 于 2010-4-1 00:25 发表
SWAP都用了
top
然后按大写M.给我看看...冲凉去
top - 12:26:41 up 5 days, 15:31,  1 user,  load average: 5.08, 4.52, 4.14
Tasks:  60 total,   3 running,  57 sleeping,   0 stopped,   0 zombie
Cpu(s):  3.0%us,  0.3%sy,  0.0%ni, 42.5%id, 54.0%wa,  0.0%hi,  0.0%si,  0.2%st
Mem:    524464k total,   361444k used,   163020k free,     3072k buffers
Swap:   524280k total,    97580k used,   426700k free,   182156k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
17695 www       15   0 57940  40m 4108 S  0.0  7.9   2:54.01 php-cgi
1041 mysql     18   0 51584  23m 2324 S  5.7  4.6   2323:55 mysqld
8832 www       16   0 40564  22m 4404 S  0.0  4.4   7:52.86 php-cgi
8029 www       16   0 38804  22m 4288 R  1.0  4.3   8:29.72 php-cgi
29384 www       16   0 38540  21m 4448 S  0.3  4.2  14:27.37 php-cgi
22362 www       15   0 36632  21m 4816 S  0.0  4.1   0:09.72 php-cgi
22095 www       16   0 31492  15m  696 S  0.0  3.1   0:00.55 nginx
1104 root      15   0 11524 2452  496 S  0.0  0.5   0:00.02 nginx
22555 root      15   0  2216 1068  832 R  0.0  0.2   0:00.00 top
21118 root      15   0 10100  860  736 R  0.0  0.2   0:00.02 sshd
21120 root      16   0  2476  832  696 S  0.0  0.2   0:00.00 bash
21686 root      15   0 10096  716  716 S  0.0  0.1   0:00.01 sshd
1061 root      15   0  9200  476  340 S  0.0  0.1   0:00.07 sendmail
1097 root      15   0 23204  424  300 S  0.0  0.1   0:00.45 php-cgi
21688 root      15   0  6648  416  416 S  0.0  0.1   0:00.00 sftp-server
  904 root      18   0  7088  288  264 S  0.0  0.1   0:00.54 sshd
1069 smmsp     15   0  8148  280  280 S  0.0  0.1   0:00.00 sendmail
  875 root      18   0  1740  260  220 S  0.0  0.0   0:00.67 syslogd
    1 root      15   0  2088  172  152 S  0.0  0.0   0:00.08 init
1090 xfs       18   0  3176  152  124 S  0.0  0.0   0:00.00 xfs
  920 root      25   0  2472  116  116 S  0.0  0.0   0:00.00 mysqld_safe
  335 root      21  -4  2172  104  104 S  0.0  0.0   0:00.02 udevd
  878 root      15   0  1692  100   96 S  0.0  0.0   0:00.00 klogd
1107 root      17   0  1676   76   76 S  0.0  0.0   0:00.00 mingetty
1108 root      18   0  1676   76   76 S  0.0  0.0   0:00.00 mingetty
1109 root      18   0  1676   76   76 S  0.0  0.0   0:00.00 mingetty
1110 root      19   0  1676   76   76 S  0.0  0.0   0:00.00 mingetty
1111 root      20   0  1676   76   76 S  0.0  0.0   0:00.00 mingetty
1112 root      21   0  1676   76   76 S  0.0  0.0   0:00.00 mingetty
1113 root      22   0  1676   76   76 S  0.0  0.0   0:00.00 mingetty
    2 root      RT  -5     0    0    0 S  0.0  0.0   0:00.40 migration/0
    3 root      34  19     0    0    0 S  0.0  0.0   0:00.33 ksoftirqd/0
    4 root      RT  -5     0    0    0 S  0.0  0.0   0:00.00 watchdog/0
    5 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 events/0
    6 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 khelper
    7 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 kthread
    9 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 xenwatch
   10 root      12  -5     0    0    0 S  0.0  0.0   0:00.00 xenbus
   16 root      RT  -5     0    0    0 S  0.0  0.0   0:00.43 migration/1
   17 root      34  19     0    0    0 S  0.0  0.0   0:00.46 ksoftirqd/1
   18 root      RT  -5     0    0    0 S  0.0  0.0   0:00.00 watchdog/1
   19 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 events/1
   22 root      10  -5     0    0    0 S  0.0  0.0   0:00.04 kblockd/0
   23 root      15  -5     0    0    0 S  0.0  0.0   0:00.00 kblockd/1
   24 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 cqueue/0
   25 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 cqueue/1
   29 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 khubd
   31 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 kseriod
   99 root      10  -5     0    0    0 S  0.0  0.0   0:24.35 kswapd0
  100 root      12  -5     0    0    0 S  0.0  0.0   0:00.00 aio/0
  101 root      12  -5     0    0    0 S  0.0  0.0   0:00.00 aio/1
  242 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 kpsmoused
  270 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 kstriped
  286 root      10  -5     0    0    0 S  0.0  0.0   0:14.16 kjournald
  307 root      11  -5     0    0    0 S  0.0  0.0   0:00.00 kauditd
  642 root      16  -5     0    0    0 S  0.0  0.0   0:00.00 kmpathd/0
  643 root      16  -5     0    0    0 S  0.0  0.0   0:00.00 kmpathd/1
 楼主| 发表于 2010-4-1 00:27:40 | 只看该作者
原帖由 shinko 于 2010-4-1 00:24 发表
重启服务看看..没可能0字节的....
配置你改过?
一齐默认
 楼主| 发表于 2010-4-1 00:29:50 | 只看该作者
重启服务看看..没可能0字节的....
配置你改过?
重启后正常一会了,又继续很慢。。。
发表于 2010-4-1 00:42:12 | 只看该作者
回复 16# 的帖子
你网站多少IP?
 楼主| 发表于 2010-4-1 00:45:42 | 只看该作者
現在1天3000左右
发表于 2010-4-1 00:47:40 | 只看该作者
回复 18# 的帖子
什么程序?
20#
 楼主| 发表于 2010-4-1 00:48:21 | 只看该作者
之前用burst 幾個網站一起1w ip也沒死,近來搬到diahosting,幾天就死一次
GMT+8, 2025-12-24 14:30 , Processed in 0.080060 second(s), 9 queries , Gzip On, MemCache On.
