查看: 981|回复: 1
我的CloudCone小鸡终于恢复了, 要换VPS了
发表于 2024-10-23 22:12:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下午12:39 开始 中断到现在,我的SC2   才恢复。
损失惨重,看来要换主机了,计划移到甲骨文免费云主机上面
按时自动备份就行。
下面是工单回复。
There was an active fire incident at the Aon Center in Los Angeles, where the building's power was turned off as a precaution. While our upstream provider is located on a different floor and unaffected directly, power restoration is ongoing.
Affected nodes are being powered on one by one at the moment. Power has already been restored to some of the affected nodes and the remaining nodes are currently being powered up.
We're working on getting other VMs online at the moment, please allow sometime for the node your VM is on to be powered up.
发表于 2024-10-23 22:14:01 | 只看该作者
出不出鸡 我收。
GMT+8, 2026-4-25 02:58 , Processed in 0.057896 second(s), 10 queries , Gzip On, MemCache On.
