查看: 1805|回复: 10
请教一个奇怪网络连通性的问题
发表于 2024-10-15 19:49:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. root@wiki-4837-pre:~# curl -I http://www.gstatic.com/generate_204
  2. curl: (28) Failed to connect to www.gstatic.com port 80 after 3067 ms: Couldn't connect to server
  3. root@wiki-4837-pre:~# curl -I http://www.gstatic.com/generate_204 -vv
  4. * Host www.gstatic.com:80 was resolved.
  5. * IPv6: 2607:f8b0:4007:810::2003
  6. * IPv4: 142.250.189.3
  7. *   Trying 142.250.189.3:80...
  8. *   Trying [2607:f8b0:4007:810::2003]:80...
  9. * Immediate connect fail for 2607:f8b0:4007:810::2003: Network is unreachable
  10. * connect to 142.250.189.3 port 80 from 172.247.*.* port 53350 failed: Connection timed out
  11. * Failed to connect to www.gstatic.com port 80 after 3100 ms: Couldn't connect to server
  12. * Closing connection
  13. curl: (28) Failed to connect to www.gstatic.com port 80 after 3100 ms: Couldn't connect to server
  14. root@wiki-4837-pre:~# nexttrace 142.250.189.3
  15. NextTrace v1.3.4 2024-09-10T13:25:26Z 6a3ea6a
  16. 2024/10/15 11:46:23 IP connection has been timeout, please check your network
  17. [NextTrace API] preferred API IP -  - ms - Get "https://45.88.195.154:443/v3/challenge/request_challenge": dial tcp 45.88.195.154:443: connect: connection timed out
  18. RetToken failed 3 times, please try again after a while, exit
  19. root@wiki-4837-pre:~#
一个上游是cera的4837优化线路,我连接服务器和ping服务器都正常,ssh连接也正常。
但是从vps访问其他网站就时不时啥也连不上,这到底是啥问题啊,有点摸不着头脑。
发表于 2024-10-15 19:53:00 | 只看该作者
人家封了你IP有什么奇怪的
 楼主| 发表于 2024-10-15 19:53:45 | 只看该作者
  1. root@wiki-4837-pre:~# ping 1.1.1.1
  2. PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
  3. 64 bytes from 1.1.1.1: icmp_seq=1 ttl=55 time=0.806 ms
  4. 64 bytes from 1.1.1.1: icmp_seq=2 ttl=55 time=0.802 ms
  5. 64 bytes from 1.1.1.1: icmp_seq=3 ttl=55 time=0.841 ms
  6. 64 bytes from 1.1.1.1: icmp_seq=4 ttl=55 time=0.782 ms
  7. ping 1.1.1.1 也是有回复的。
 楼主| 发表于 2024-10-15 19:58:24 | 只看该作者
HOH 发表于 2024-10-15 19:53
人家封了你IP有什么奇怪的
但是这个是不定时的,一会能通,一会不能通。
发表于 2024-10-15 20:03:56 | 只看该作者
wiki不是跑路了吗?
赶紧发工单呀
 楼主| 发表于 2024-10-15 20:04:47 | 只看该作者
NaiveGuy 发表于 2024-10-15 20:03
wiki不是跑路了吗?
赶紧发工单呀
他是块跑路了的感觉,发工单肯定也没人回。
发表于 2024-10-15 20:14:10 | 只看该作者
你这个ip不就是墙掉了么?大陆中国红
发表于 2024-10-15 20:16:22 | 只看该作者
附赠一份claude 回复:
根据您提供的信息,这个问题可能涉及几个方面。让我们逐步分析:
1. DNS 解析正常:
   curl 命令成功解析了 www.gstatic.com 的 IP 地址,说明 DNS 服务正常工作。
2. IPv4 和 IPv6 连接尝试:
   系统尝试使用 IPv4 (142.250.189.3) 和 IPv6 (2607:f8b0:4007:810::2003) 地址连接,但都失败了。
3. IPv6 连接立即失败:
   "Network is unreachable" 错误表明您的 VPS 可能没有正确配置 IPv6 或者网络不支持 IPv6。
4. IPv4 连接超时:
   连接到 IPv4 地址超时,这可能是网络问题或防火墙设置导致的。
5. nexttrace 命令也失败:
   这进一步证实了网络连接问题。
可能的原因和解决方案:
1. 网络配置问题:
   - 检查 VPS 的网络配置,特别是默认网关和路由表。
   - 运行 `ip route` 命令查看路由表。
2. 防火墙设置:
   - VPS 或上游服务商的防火墙可能阻止了出站连接。
   - 检查 iptables 规则:`iptables -L -n -v`
3. 上游网络问题:
   - 联系您的 VPS 提供商,询问是否有已知的网络问题或维护。
4. MTU 设置:
   - 检查并调整网络接口的 MTU 值:`ifconfig eth0`(替换 eth0 为您的接口名)
   - 尝试降低 MTU:`ifconfig eth0 mtu 1400`
5. TCP/IP 堆栈问题:
   - 尝试重启网络服务:`systemctl restart networking`
   - 或重启 VPS
6. 路由优化问题:
   - 4837 优化线路可能存在临时性问题。
   - 尝试使用 `traceroute` 命令检查网络路径。
7. 服务商限制:
   - 一些 VPS 提供商可能限制某些类型的流量或目的地。
建议操作:
1. 进行持续的 ping 测试,观察问题是持续性还是间歇性的。
2. 使用 `tcpdump` 或 `wireshark` 捕获网络流量,分析数据包。
3. 尝试更改 DNS 服务器,看是否有改善。
4. 如果可能,尝试从其他网络位置(如其他 VPS 或您的本地网络)访问同样的目标,以确定问题是否特定于这台 VPS。
如果问题持续存在,建议与 VPS 提供商联系,他们可能需要检查网络配置或上游连接问题。
发表于 2024-10-15 20:18:16 | 只看该作者
再附赠一份:”
根据您提供的新信息,情况变得更加有趣了。让我们进一步分析:
1. 基本连接性正常:
   - 您可以 SSH 到服务器。
   - 可以 ping 通 1.1.1.1(Cloudflare 的 DNS 服务器),而且延迟非常低(约 0.8 ms)。
2. 特定网站连接问题:
   - 无法连接到 www.gstatic.com(Google 的静态内容服务器)。
   - 可能其他网站也有类似问题。
这种情况下,我们可以排除一些之前考虑的问题,如全局网络配置问题或 VPS 提供商的整体连接性问题。现在,我们需要考虑更具体的原因:
可能的原因和解决方案:
1. DNS 解析后的连接问题:
   - 尝试使用 IP 直接访问网站,例如:`curl -I http://142.250.189.3`
   - 如果直接使用 IP 可以连接,那么可能是 DNS 相关的问题。
2. 特定端口或协议被阻止:
   - 尝试使用不同的端口,如 HTTPS(443 端口):`curl -I https://www.gstatic.com`
   - 检查是否只有 HTTP 流量受到影响。
3. 路由问题:
   - 运行 `traceroute www.gstatic.com` 或 `mtr www.gstatic.com` 查看网络路径。
   - 查看是否有特定的跳转点出现问题。
4. 防火墙或安全组设置:
   - 检查 VPS 提供商的控制面板,查看是否有防火墙规则阻止了特定的出站连接。
   - 查看系统防火墙规则:`iptables -L -n -v`
5. 代理设置:
   - 检查系统或环境变量中是否设置了代理:`env | grep -i proxy`
   - 如果有,尝试暂时取消代理设置。
6. TCP 连接问题:
   - 尝试调整 TCP 参数:`sysctl -w net.ipv4.tcp_syn_retries=2`
   - 检查当前 TCP 连接状态:`netstat -tunapl`
7. 特定 IP 范围的问题:
   - 尝试访问其他知名网站,如 `curl -I https://www.cloudflare.com`
   - 看问题是否只针对特定的 IP 范围或服务提供商。
8. 时间同步问题:
   - 检查系统时间是否准确:`date`
   - 如果不准确,同步 NTP:`ntpdate pool.ntp.org`
9. 网络接口 MTU 设置:
   - 查看当前 MTU:`ifconfig eth0 | grep MTU`
   - 尝试调低 MTU:`ifconfig eth0 mtu 1400`
10. 临时网络异常:
    - 持续监控问题,看是否为临时现象。
    - 使用 `tcpdump` 捕获特定目标的网络流量进行分析。
建议步骤:
1. 执行上述测试,特别是直接使用 IP 地址访问和尝试 HTTPS 连接。
2. 运行 `traceroute` 或 `mtr` 来分析网络路径。
3. 检查系统日志:`journalctl -xe` 查看是否有相关错误信息。
4. 如果问题仍然存在,收集所有测试结果,并联系 VPS 提供商的支持团队,他们可能需要检查网络配置或上游连接。
这种复杂的网络问题通常需要逐步排除,可能还需要 VPS 提供商的协助来完全解决。
 楼主| 发表于 2024-10-15 20:19:20 | 只看该作者
MondoViva 发表于 2024-10-15 20:18
再附赠一份:”
ok,我试试
GMT+8, 2026-4-17 02:56 , Processed in 0.060906 second(s), 10 queries , Gzip On, MemCache On.
