查看: 2496|回复: 11
【干货】快易特价机测试全纪录
发表于 2012-7-11 15:38:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
购入快易rak特价机一台,测试数据如下:
选的默认kloxo
开机后负载情况:
  1. load average: 0.00, 0.09, 0.96
内存
  1. [root@MyVPS ~]# free -m
  2.              total       used       free     shared    buffers     cached
  3. Mem:          1024        929         94          0        128        662
  4. -/+ buffers/cache:        138        885
  5. Swap:         1023          0       1023
CPU型号:
  1. 2  Intel(R) Xeon(R) CPU E31230 @ 3.20GHz
百兆文件下载测试(跑满百兆端口):
  1. 100%[======================================>] 104,857,600 11.2M/s   in 9.0s
  2. 2012-07-11 15:35:06 (11.2 MB/s) - `100mb.test.1' saved [104857600/104857600]
dd测试
  1. # dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  2. 268435456 bytes (268 MB) copied, 5.38188 seconds, 49.9 MB/s
  3. 268435456 bytes (268 MB) copied, 7.66046 seconds, 35.0 MB/s
  4. 268435456 bytes (268 MB) copied, 5.68319 seconds, 47.2 MB/s
P I N G
  1. 最快:深圳[电信]  161 毫秒    最慢:四川遂宁[电信]  396 毫秒
  2. 电信平均: 257 毫秒    联通平均: 221 毫秒
晚上出高峰期的ping测试→9L
跑分
  1. Benchmark Run: Wed Jul 11 2012 14:15:37 - 14:43:53
  2. 2 CPUs in system; running 1 parallel copy of tests
  3. Dhrystone 2 using register variables       10970253.5 lps   (10.0 s, 7 samples)
  4. Double-Precision Whetstone                     2518.4 MWIPS (10.1 s, 7 samples)
  5. Execl Throughput                               2120.8 lps   (30.0 s, 2 samples)
  6. File Copy 1024 bufsize 2000 maxblocks        349380.1 KBps  (30.0 s, 2 samples)
  7. File Copy 256 bufsize 500 maxblocks           97558.8 KBps  (30.0 s, 2 samples)
  8. File Copy 4096 bufsize 8000 maxblocks       1074905.4 KBps  (30.0 s, 2 samples)
  9. Pipe Throughput                              594259.4 lps   (10.0 s, 7 samples)
  10. Pipe-based Context Switching                  91018.9 lps   (10.0 s, 7 samples)
  11. Process Creation                               4101.9 lps   (30.0 s, 2 samples)
  12. Shell Scripts (1 concurrent)                   4106.0 lpm   (60.0 s, 2 samples)
  13. Shell Scripts (8 concurrent)                    825.4 lpm   (60.0 s, 2 samples)
  14. System Call Overhead                         513844.9 lps   (10.0 s, 7 samples)
  15. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  16. Dhrystone 2 using register variables         116700.0   10970253.5    940.0
  17. Double-Precision Whetstone                       55.0       2518.4    457.9
  18. Execl Throughput                                 43.0       2120.8    493.2
  19. File Copy 1024 bufsize 2000 maxblocks          3960.0     349380.1    882.3
  20. File Copy 256 bufsize 500 maxblocks            1655.0      97558.8    589.5
  21. File Copy 4096 bufsize 8000 maxblocks          5800.0    1074905.4   1853.3
  22. Pipe Throughput                               12440.0     594259.4    477.7
  23. Pipe-based Context Switching                   4000.0      91018.9    227.5
  24. Process Creation                                126.0       4101.9    325.5
  25. Shell Scripts (1 concurrent)                     42.4       4106.0    968.4
  26. Shell Scripts (8 concurrent)                      6.0        825.4   1375.7
  27. System Call Overhead                          15000.0     513844.9    342.6
  28.        ========
  29. System Benchmarks Index Score                                         621.2
  30. ------------------------------------------------------------------------
  31. Benchmark Run: Wed Jul 11 2012 14:43:53 - 15:12:12
  32. 2 CPUs in system; running 2 parallel copies of tests
  33. Dhrystone 2 using register variables       21372778.9 lps   (10.0 s, 7 samples)
  34. Double-Precision Whetstone                     5044.6 MWIPS (10.0 s, 7 samples)
  35. Execl Throughput                               3773.7 lps   (29.6 s, 2 samples)
  36. File Copy 1024 bufsize 2000 maxblocks        313176.9 KBps  (30.0 s, 2 samples)
  37. File Copy 256 bufsize 500 maxblocks           82356.8 KBps  (30.0 s, 2 samples)
  38. File Copy 4096 bufsize 8000 maxblocks       1010468.8 KBps  (30.0 s, 2 samples)
  39. Pipe Throughput                             1101657.8 lps   (10.0 s, 7 samples)
  40. Pipe-based Context Switching                 163572.5 lps   (10.0 s, 7 samples)
  41. Process Creation                               6819.0 lps   (30.0 s, 2 samples)
  42. Shell Scripts (1 concurrent)                   5665.8 lpm   (60.0 s, 2 samples)
  43. Shell Scripts (8 concurrent)                    859.2 lpm   (60.1 s, 2 samples)
  44. System Call Overhead                         889812.9 lps   (10.0 s, 7 samples)
  45. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  46. Dhrystone 2 using register variables         116700.0   21372778.9   1831.4
  47. Double-Precision Whetstone                       55.0       5044.6    917.2
  48. Execl Throughput                                 43.0       3773.7    877.6
  49. File Copy 1024 bufsize 2000 maxblocks          3960.0     313176.9    790.9
  50. File Copy 256 bufsize 500 maxblocks            1655.0      82356.8    497.6
  51. File Copy 4096 bufsize 8000 maxblocks          5800.0    1010468.8   1742.2
  52. Pipe Throughput                               12440.0    1101657.8    885.6
  53. Pipe-based Context Switching                   4000.0     163572.5    408.9
  54. Process Creation                                126.0       6819.0    541.2
  55. Shell Scripts (1 concurrent)                     42.4       5665.8   1336.3
  56. Shell Scripts (8 concurrent)                      6.0        859.2   1432.1
  57. System Call Overhead                          15000.0     889812.9    593.2
  58.        ========
  59. System Benchmarks Index Score                                         883.1
参与人数 1威望 +20 收起 理由
winder + 20 感谢支持
发表于 2012-7-11 15:41:25 | 只看该作者
发表于 2012-7-11 15:41:29 | 只看该作者
价格?
发表于 2012-7-11 15:42:33 | 只看该作者
发表于 2012-7-11 15:43:45 | 只看该作者
神马皆浮云 发表于 2012-7-11 15:41
价格?
地址参见:http://www.kiiyi.com/wa-2-year.php
发表于 2012-7-11 15:44:10 | 只看该作者
发表于 2012-7-11 15:44:11 | 只看该作者
还是比较NB的!
发表于 2012-7-11 15:45:17 | 只看该作者
价格?
好像是88元送8G U盘的那款。。
 楼主| 发表于 2012-7-11 20:38:33 | 只看该作者
20:39 ping测试
  1. 最快:广东东莞[电信]  160 毫秒    最慢:四川德阳[电信]  347 毫秒
  2. 电信平均: 257 毫秒    联通平均: 226 毫秒
发表于 2012-7-11 20:39:44 | 只看该作者
GMT+8, 2026-4-18 15:28 , Processed in 0.203445 second(s), 16 queries , Gzip On, MemCache On.
