查看: 896|回复: 0
[美国VPS] [出]芬兰杜甫 24.03欧/月
发表于 2024-10-1 12:41:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
配置:i5-8500t/32G/2x1TB NVMe,流量标注无限,下面是官方描述。
Unmetered Bandwidth: Fair use policy still applies. There is no specific limit, it depends on the whole rack bandwidth utilization and your nei**ors. Typically ~100TB/Month or ~300Mbps 95th Percentile is completely fine on 1Gbps.
专门做盒子的商家,允许跑BT,抗版权。
  1. Processor  : Intel(R) Core(TM) i5-8500T CPU [url=home.php?mod=space&uid=175]@[/url] 2.10GHz
  2. CPU cores  : 6 @ 1509.821 MHz
  3. AES-NI     : ✔ Enabled
  4. VM-x/AMD-V : ✔ Enabled
  5. RAM        : 31.2 GiB
  6. Swap       : 0.0 KiB
  7. Disk       : 1.8 TiB
  8. Distro     : Debian GNU/Linux 11 (bullseye)
  9. Kernel     : 5.10.0-30-amd64
  10. VM Type    : NONE
  11. IPv4/IPv6  : ✔ Online / ❌ Offline
  12. IPv4 Network Information:
  13. ---------------------------------
  14. ISP        : Magna Capax Finland Oy
  15. ASN        : AS203003 Magna Capax Finland Oy
  16. Host       : Magnacapax
  17. Location   : Helsinki, Uusimaa (18)
  18. Country    : Finland
  19. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md1):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 313.95 MB/s  (78.4k) | 961.23 MB/s  (15.0k)
  24. Write      | 314.78 MB/s  (78.6k) | 966.29 MB/s  (15.0k)
  25. Total      | 628.73 MB/s (157.1k) | 1.92 GB/s    (30.1k)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 1.31 GB/s     (2.5k) | 1.35 GB/s     (1.3k)
  30. Write      | 1.38 GB/s     (2.7k) | 1.44 GB/s     (1.4k)
  31. Total      | 2.70 GB/s     (5.2k) | 2.80 GB/s     (2.7k)
  32. iperf3 Network Speed Tests (IPv4):
  33. ---------------------------------
  34. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  35. -----           | -----                     | ----            | ----            | ----
  36. Clouvider       | London, UK (10G)          | 922 Mbits/sec   | 327 Mbits/sec   | 31.8 ms
  37. Eranium         | Amsterdam, NL (100G)      | 928 Mbits/sec   | 936 Mbits/sec   | 28.0 ms
  38. Uztelecom       | Tashkent, UZ (10G)        | 890 Mbits/sec   | 896 Mbits/sec   | 82.2 ms
  39. Leaseweb        | Singapore, SG (10G)       | 717 Mbits/sec   | 675 Mbits/sec   | 258 ms
  40. Clouvider       | Los Angeles, CA, US (10G) | 806 Mbits/sec   | 840 Mbits/sec   | 167 ms
  41. Leaseweb        | NYC, NY, US (10G)         | 873 Mbits/sec   | 899 Mbits/sec   | 102 ms
  42. Edgoo           | Sao Paulo, BR (1G)        | 747 Mbits/sec   | 669 Mbits/sec   | 217 ms
  43. Geekbench 6 Benchmark Test:
  44. ---------------------------------
  45. Test            | Value
  46.                 |
  47. Single Core     | 1395
  48. Multi Core      | 5337
  49. Full Test       | https://browser.geekbench.com/v6/cpu/8069088
Registration Date
02.05.2024
First Payment Amount
34.02€
Recurring Amount
24.03€
Billing Cycle
Monthly
Next Due Date
02.11.2024
Payment Method
PayPal Basic
目前这家已经涨价了,所以算是传家宝吧,就算涨价前这也是抄底价。
剩余价值200+安装费80+溢价20一共300改邮箱出(改邮箱需要开工单,先给root)
GMT+8, 2026-4-25 13:22 , Processed in 0.065961 second(s), 10 queries , Gzip On, MemCache On.
