查看: 2719|回复: 8
[Windows VPS] 帮忙推荐一款便宜的服务器 装VPS
发表于 2012-7-9 23:21:37 | 只看该作者
要多IP的?WHT好像有个600IP的吧~才200多刀~~
 楼主| 发表于 2012-7-9 23:11:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
需要装VPS开流量精灵 要可以买ip的 http://www.serverstadium.com/ 这家不错 可惜ip只给4个不让多买 有跟他差不多 拜托推荐一下
发表于 2012-7-9 23:12:02 | 只看该作者
没有哦
参与人数 1威望 +20 收起 理由
唐伯虎 + 20 神马都是浮云
 楼主| 发表于 2012-7-9 23:13:04 | 只看该作者
楼上是顶贴机吗 我刚发 马上就回了
发表于 2012-7-9 23:15:45 | 只看该作者
得不偿失。
发表于 2012-7-9 23:45:22 来自手机 | 只看该作者
布吉岛
发表于 2012-7-9 23:46:06 | 只看该作者
这家可以加ip的 虽然不多
 楼主| 发表于 2012-7-9 23:58:00 | 只看该作者
IP ADDRESSES
4 usable IPs (per month) [$ 0.0]
Note: Request over 4 IPs will need to fill out this IP Justification Form
Due to a shortage of IP, we can only assign 4 IPs per server until further notice. Sorry for this inconvinience.
上面这么写的
发表于 2012-7-10 02:43:44 | 只看该作者
What is the maximum number of IPs that I can have in my server?
You can either have 8 IPs maximum or 12 IPs maximum in your server depending on how/when you order it.
Here are 3 scenarios that can happen when needing additional IPs:
1st scenario: 1st scenario: You order the server with 4 IPs only. Then 5 days later you decided that you need more IPs but cannot change the initial 4 IPs that you have in your server. In this scenario, you can only get 4 additional IPs for $8/mo. (total usable IPs are 8 IPs)
2nd scenario: You order the server with 4 IPs only. Then 5 days later you decided that you need more IPs and you don't mind giving up the initial 4 IPs to be changed to a new subnet. In this scenario, you can get a total of 12 IPs for $8/mo. (total usable IPs are 12 IPs)
3rd scenario: You order the server with 12 IPs. That's it. You are not able to add any additional IPs beyond 12 IPs.
Note: some servers can only have a maximum of 4 IPs. (If the IP is not upgradeable when you are placing your order, then you can never upgrade the IP for that particular server)
参与人数 1威望 +7 收起 理由
jjcbb + 7 很给力!
GMT+8, 2025-12-26 08:48 , Processed in 0.168808 second(s), 13 queries , Gzip On, MemCache On.
