查看: 1234|回复: 7
[特价VPS] serverpoint | 5$每月新加坡20TB超大流量VPS体测
发表于 2024-9-26 13:28:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大元帅,serverpoint体测结果摘要如下
购入套餐
  1. 2 vCPUs, Intel E5v4 at 2.1Ghz
  2. 2 GBs of RAM
  3. 80 GBs SSD storage
  4. 10,000 GBs/mo data transfer
  5. 1 IPv4 IP included
  6. 1gbps network port
  7. Private VLAN included
  8. DDoS protection included
YABS
  3. #                     v2024-06-09                    #
  4. #  #
  6. Thu Sep 26 09:11:14 AM +08 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 51 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E5-2683 v4 @ 2.10GHz
  11. CPU cores  : 2 @ 2099.998 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 1.9 GiB
  15. Swap       : 128.0 MiB
  16. Disk       : 78.4 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-20-amd64
  19. VM Type    : MICROSOFT
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : ServerPoint.com
  24. ASN        : AS26277 ServerPoint.com
  25. Host       : Singapore SG Datacenter
  26. Location   : Singapore, Central Singapore (01)
  27. Country    : Singapore
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  32. Read       | 79.83 MB/s   (19.9k) | 607.33 MB/s   (9.4k)
  33. Write      | 80.04 MB/s   (20.0k) | 610.52 MB/s   (9.5k)
  34. Total      | 159.87 MB/s  (39.9k) | 1.21 GB/s    (19.0k)
  38. Read       | 613.84 MB/s   (1.1k) | 602.24 MB/s    (588)
  39. Write      | 646.46 MB/s   (1.2k) | 642.35 MB/s    (627)
  40. Total      | 1.26 GB/s     (2.4k) | 1.24 GB/s     (1.2k)
  45. Clouvider       | London, UK (10G)          | busy            | 477 Mbits/sec   | 161 ms
  46. Eranium         | Amsterdam, NL (100G)      | busy            | 907 Mbits/sec   | 239 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | busy            | 325 Mbits/sec   | 244 ms
  48. Leaseweb        | Singapore, SG (10G)       | 1.21 Gbits/sec  | 1.18 Gbits/sec  | 1.22 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 979 Mbits/sec   | 129 Mbits/sec   | 168 ms
  50. Leaseweb        | NYC, NY, US (10G)         | busy            | 654 Mbits/sec   | 232 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | busy            | 224 Mbits/sec   | 349 ms
  52. Running GB6 benchmark test... *cue elevator music*
  53. Geekbench 6 Benchmark Test:
  54. ---------------------------------
  55. Test            | Value
  56.                 |
  57. Single Core     | 898
  58. Multi Core      | 1614
  59. YABS completed in 16 min 43 sec
流媒体
  1. ============[ Multination ]============
  2. Dazn:                                  Yes (Region: SG)
  3. Disney+:                               Yes (Region: US)
  4. Netflix:                               Yes (Region: US)
  5. 有图比 Premium:                       Yes (Region: US)
  6. Amazon Prime Video:                    Yes (Region: SG)
  7. TVBAnywhere+:                          Yes
  8. Spotify Registration:                  No
  9. Instagram Licensed Audio:              Yes
  10. OneTrust Region:                       SG [Unknown]
  11. iQyi Oversea Region:                   SG
  12. Bing Region:                           SG
  13. 有图比 CDN:                           Singapore
  14. Netflix Preferred CDN:                 Hong Kong
  15. ChatGPT:                               Yes
  16. Google Gemini:                         Yes (Region: USA)
  17. Wikipedia Editability:                 No
  18. Google Search CAPTCHA Free:            Yes
  19. Steam Currency:                        SGD
  20. ---Forum---
  21. Reddit:                                Yes
  22. =======================================
Loc貌似不支持Md格式
懒得搬了   详细内容烦请移至小生站点(xzllll.com)食用
发表于 2024-9-26 13:48:13 | 只看该作者
没国内测速?起码加个HK JP的测速
发表于 2024-9-26 13:53:02 | 只看该作者
有免费甲骨文新加坡10T还不够用吗?
 楼主| 发表于 2024-9-26 14:02:06 | 只看该作者
daniu 发表于 2024-9-26 13:48
没国内测速?起码加个HK JP的测速
请大佬移步俺的小破站   测试全全的
 楼主| 发表于 2024-9-26 14:03:12 | 只看该作者
tomcb 发表于 2024-9-26 13:53
有免费甲骨文新加坡10T还不够用吗?
能薅是福
但也不是谁都有
发表于 2024-9-26 14:22:49 来自手机 | 只看该作者
xzllll.com 发表于 2024-9-26 14:03
能薅是福
但也不是谁都有
测速建议测下晚高峰
发表于 2024-9-26 15:59:15 | 只看该作者
有免费甲骨文新加坡10T还不够用吗?
就是啊!一语惊醒梦中人
GMT+8, 2026-5-1 11:20 , Processed in 0.062152 second(s), 8 queries , Gzip On, MemCache On.
