查看: 980|回复: 1
[疑问] 关于 iOS 集成 tun2socks 的一些问题
发表于 2024-9-25 15:20:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
tun2socks config
  1. tunnel:
  2.           mtu: 9000
  3.         socks5:
  4.           port: 7890
  5.           address: ::1
  6.           udp: 'udp'
  7.         misc:
  8.           task-stack-size: 20480
  9.           connect-timeout: 5000
  10.           read-write-timeout: 60000
  11.           log-file: stderr
  12.           log-level: error
  13.           limit-nofile: 65535
PacketTunnelProvider
  1. let settings = NEPacketTunnelNetworkSettings(tunnelRemoteAddress: "254.1.1.1")
  2.     settings.mtu = 9000
  3.     settings.ipv4Settings = {
  4.         let settings = NEIPv4Settings(addresses: ["198.18.0.0"], subnetMasks: ["255.255.0.0"])
  5.         settings.includedRoutes = [NEIPv4Route.default()]
  6.         return settings
  7.     }()
  8.     settings.ipv6Settings = {
  9.         let settings = NEIPv6Settings(addresses: ["fd6e:a81b:704f:1211::1"], networkPrefixLengths: [64])
  10.         settings.includedRoutes = [NEIPv6Route.default()]
  11.         return settings
  12.     }()
  13.     settings.dnsSettings = NEDNSSettings(servers: ["127.0.0.1"])
  14.     try await self.setTunnelNetworkSettings(settings)
问题情况
当 socks5 地址为
::1
监听本地起的 socks 服务时,就无法使用,所有的请求到达本地 socks 服务,都无法出去,形成了路由环路 请求超时
使用 *.*.*.* 远程 socks 服务一切正常
GPT 已经是问的想吐了,实在是没有任何的思路,includedRoutes excludedRoutes 都试过,别人的项目参考也看了,无法解决,请各位大佬指点下
发表于 2024-9-25 15:52:53 | 只看该作者
跑通了应该还会面临内存问题
GMT+8, 2026-4-22 02:56 , Processed in 0.060121 second(s), 10 queries , Gzip On, MemCache On.
