查看: 915|回复: 3
HH洛杉矶已恢复
发表于 2024-9-22 10:05:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前几天收到 转移数据的邮件,
1) Create a new VM with identical specifications and a new IP address. Both your old/current and new VMs will remain online for 14 days. We will shut down the old VM after this, or earlier if you inform us that you have moved over the data. At this time, we can move over your old IP address to the new VM, if that is needed.
2) We can remove your current VM, and create a new one with identical specifications with the same IP address. In this case, you will need to restore the data from your own backups. Please let us know how you wish to proceed.
没有回复,发现vps挂了,今天发现恢复了(还是原IP),这说明在转移我的数据ing中,还是已经转移成功了
发表于 2024-9-22 10:43:59 | 只看该作者
会不会是 开启让你备份 数据 备份好了给他们说
发表于 2024-9-22 16:03:14 来自手机 | 只看该作者
荷兰上次转移新服务器后,无限流量就修复了,其他区不知道是不是一样
发表于 2024-9-22 16:03:44 | 只看该作者
GMT+8, 2026-4-22 16:12 , Processed in 0.060542 second(s), 10 queries , Gzip On, MemCache On.
