查看: 1761|回复: 13
【已出】折价200出HostHatch香港AMD6核心24G内存270GB固态12TB月....
发表于 2024-9-17 11:50:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. Basic System Information:
  3. Uptime     : 68 days, 14 hours, 21 minutes
  4. Processor  : AMD EPYC 7513 32-Core Processor
  5. CPU cores  : 6 [url=home.php?mod=space&uid=175]@[/url] 2595.122 MHz
  6. AES-NI     : ✔️ Enabled
  7. VM-x/AMD-V : ✔️ Enabled
  8. RAM        : 23.5 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 243.6 GiB
  11. Distro     : Ubuntu 22.04.3 LTS
  12. Kernel     : 6.5.0-35-generic
  13. VM Type    : KVM
  14. IPv4/IPv6  : ✔️ Online / ✔️ Online
  15. IPv6 Network Information:
  16. ---------------------------------
  17. ISP        : HostHatch
  18. ASN        : AS63473 HostHatch, LLC
  19. Host       : HostHatch, LLC
  20. Location   : Tseung Kwan O, Sai Kung District (NSK)
  21. Country    : Hong Kong
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 214.74 MB/s  (53.6k) | 2.12 GB/s    (33.1k)
  27. Write      | 215.30 MB/s  (53.8k) | 2.13 GB/s    (33.3k)
  28. Total      | 430.05 MB/s (107.5k) | 4.25 GB/s    (66.5k)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 2.47 GB/s     (4.8k) | 2.61 GB/s     (2.5k)
  33. Write      | 2.60 GB/s     (5.0k) | 2.78 GB/s     (2.7k)
  34. Total      | 5.07 GB/s     (9.9k) | 5.40 GB/s     (5.2k)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | 706 Mbits/sec   | 899 Mbits/sec   | 229 ms
  40. Eranium         | Amsterdam, NL (100G)      | 5.07 Gbits/sec  | 4.07 Gbits/sec  | 188 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | busy            | 1.10 Gbits/sec  | 173 ms
  42. Leaseweb        | Singapore, SG (10G)       | 6.70 Gbits/sec  | 5.07 Gbits/sec  | 37.3 ms
  43. Clouvider       | Los Angeles, CA, US (10G) | 1.18 Gbits/sec  | 1.48 Gbits/sec  | 149 ms
  44. Leaseweb        | NYC, NY, US (10G)         | busy            | 3.34 Gbits/sec  | 203 ms
  45. Edgoo           | Sao Paulo, BR (1G)        | 3.36 Gbits/sec  | 1.62 Gbits/sec  | 320 ms
  46. iperf3 Network Speed Tests (IPv6):
  47. ---------------------------------
  48. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  49. -----           | -----                     | ----            | ----            | ----
  50. Clouvider       | London, UK (10G)          | 708 Mbits/sec   | 920 Mbits/sec   | 229 ms
  51. Eranium         | Amsterdam, NL (100G)      | 4.84 Gbits/sec  | 3.78 Gbits/sec  | 187 ms
  52. Uztelecom       | Tashkent, UZ (10G)        | busy            | 1.35 Gbits/sec  | 171 ms
  53. Leaseweb        | Singapore, SG (10G)       | 6.67 Gbits/sec  | 5.44 Gbits/sec  | 36.9 ms
  54. Clouvider       | Los Angeles, CA, US (10G) | 1.18 Gbits/sec  | 1.47 Gbits/sec  | 149 ms
  55. Leaseweb        | NYC, NY, US (10G)         | 4.01 Gbits/sec  | 3.60 Gbits/sec  | 202 ms
  56. Edgoo           | Sao Paulo, BR (1G)        | busy            | 1.59 Gbits/sec  | 320 ms
  57. Geekbench 6 Benchmark Test:
  58. ---------------------------------
  59. Test            | Value
  60.                 |
  61. Single Core     | 1320
  62. Multi Core      | 5463
  63. Full Test       | https://browser.geekbench.com/v6/cpu/7424151
  64. YABS completed in 13 min 53 sec
细节说明:
1、型号:Black Friday 2023 - AMD Compute 16GB - T2
CPU是6核心AMD EPYC 7513
内存是24.00 GiB
固态是270.00 GB
带宽是共享10GbE。来自官网信息:https://docs.hosthatch.com/features/
月流量是12.00 TB
2、该机器无合约,三年付。到期日是2026年12月23日。续费价350刀。折合下来一年730cny一年
3、官网历史监控:https://status.hosthatch.com/787768648   官方测试lg:http://lg.hkg.hosthatch.com/
4、该机器优缺点:大陆绕路,国际都没问题,不适合做前端,性能很强,适合跑后端/windows。
5、我只收剩余价值再减200元,然后去掉十位数和个位数取整。请有意者私信告知你的联系方式,支付方式可以详谈,买家先款。
6、我承担Server Transfers的10刀转让费。
7、如果你私信我,默认你已接受上述所有文字提及的全部细节。
发表于 2024-9-17 13:09:35 | 只看该作者
NodeLoc 发表于 2024-9-17 12:56
我这个是香港的。
显得着你了?听不懂话?显摆鸡毛 没完了?你找个最便宜的,就要求别人的也都是最便宜的?我们说的是前几天 懂?吗的前几天哪里200发出来?
发表于 2024-9-17 11:57:33 | 只看该作者
之前不是另外一个id发的么? 怎么换人了。
 楼主| 发表于 2024-9-17 12:02:27 来自手机 | 只看该作者
就是收的他的。我自己有一台本来想做一下分流的。但是好像是同一台母鸡,做分流没有意义了。
发表于 2024-9-17 12:18:47 | 只看该作者
机器不错 留了一台月付的
发表于 2024-9-17 12:19:38 来自手机 | 只看该作者
伊丽莎白 发表于 2024-9-17 12:02
就是收的他的。我自己有一台本来想做一下分流的。但是好像是同一台母鸡,做分流没有意义了。 ...
前几天这款只要200$两年,有点背刺了
 楼主| 发表于 2024-9-17 12:20:48 | 只看该作者
NodeLoc 发表于 2024-9-17 12:19
前几天这款只要200$两年,有点背刺了
所以折价了。
发表于 2024-9-17 12:24:46 来自手机 | 只看该作者
前几天这款只要200$两年,有点背刺了
没注意,这个价其实很可以
发表于 2024-9-17 12:31:24 | 只看该作者
香港正常是2年220刀
 楼主| 发表于 2024-9-17 12:34:33 | 只看该作者
Eric.c 发表于 2024-9-17 12:24
没注意,这个价其实很可以
这机器性能真的很好。拿来做后端非常舒服,我印象中好像他们家AMD的香港目前还没出过问题
发表于 2024-9-17 12:34:37 | 只看该作者
Rot 发表于 2024-9-17 12:31
香港正常是2年220刀
你看我的
GMT+8, 2026-5-2 23:05 , Processed in 0.067071 second(s), 11 queries , Gzip On, MemCache On.
