查看: 2780|回复: 9
远程数据库棘手的问题
发表于 2012-7-6 13:56:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天搬迁了网站,   因为程序的原因, vps必须得打开远程数据库。
用phpmyadmin创建数据库时  主机输入的是% 账号密码和以前一样,  vps上测试一切正常, 但另一个vps使用远程数据库连接到本机时却死活连接不上 这是为啥
发表于 2012-7-6 13:57:53 | 只看该作者
有些在my.cnf中禁止了远程 自己检查
参与人数 1威望 +15 收起 理由
elves766 + 15 求方法
发表于 2012-7-6 14:00:35 | 只看该作者
/etc/my.cnf
skip-networking
再前面加个#
参与人数 1威望 +10 收起 理由
elves766 + 10 很给力!
发表于 2012-7-6 14:03:19 | 只看该作者
看三楼
 楼主| 发表于 2012-7-6 14:07:10 | 只看该作者
百度 发表于 2012-7-6 14:00
/etc/my.cnf
skip-networking
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port                = 3306
socket                = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice                = 0
[mysqld]
skip-locking
skip-innodb
# * Basic Settings
user                = mysql
pid-file        = /var/run/mysqld/mysqld.pid
port                = 3306
basedir                = /usr
datadir                = /var/lib/mysql
tmpdir                = /tmp
language        = /usr/share/mysql/english
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address                = 127.0.0.1
# * Fine Tuning
key_buffer                = 16M
max_allowed_packet        = 16M
thread_stack                = 192K
thread_cache_size       = 8
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover         = BACKUP
#max_connections        = 100
#table_cache            = 64
#thread_concurrency     = 10
# * Query Cache Configuration
query_cache_limit        = 1M
query_cache_size        = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file        = /var/log/mysql/mysql.log
#general_log             = 1
# Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
# Here you can see queries with especially long duration
#log_slow_queries        = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
#       other settings you may need to change.
#server-id                = 1
#log_bin                        = /var/log/mysql/mysql-bin.log
expire_logs_days        = 10
max_binlog_size         = 100M
#binlog_do_db                = include_database_name
#binlog_ignore_db        = include_database_name
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash        # faster start of mysql but no tab completition
[isamchk]
key_buffer                = 16M
# * IMPORTANT: Additional settings that can override those from this file!
#   The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
发表于 2012-7-6 14:07:48 | 只看该作者
发表于 2012-7-6 14:27:36 | 只看该作者
还没有解决吗?
试试telnet ip 3306
 楼主| 发表于 2012-7-6 22:29:33 | 只看该作者
百度 发表于 2012-7-6 14:27
还没有解决吗?
试试telnet ip 3306
恩恩解决了 上午单位有事就没上 今天分没了 明天不给你哈
发表于 2012-7-6 22:46:35 | 只看该作者
发表于 2012-7-6 22:50:58 | 只看该作者
GMT+8, 2026-5-1 19:33 , Processed in 0.132729 second(s), 12 queries , Gzip On, MemCache On.
