查看: 1775|回复: 11
✅有没有flutter开发大佬✅
发表于 2024-9-1 14:11:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
远程帮我本地配置下开发环境,能正常编译安卓的app就行(源码没问题,就是环境报错)
预算200
会的大佬私信我
报错信息
* What went wrong:
Execution failed for task ':app:processReleaseResources'.
> A failure occurred while executing com.android.build.gradle.internal.res.LinkApplicationAndroidResourcesTask$TaskAction
   > Android resource linking failed
     aapt2.exe E 09-01 19:44:55 14644 17828 LoadedArsc.cpp:94] RES_TABLE_TYPE_TYPE entry offsets overlap actual entry data.
     aapt2.exe E 09-01 19:44:55 14644 17828 ApkAssets.cpp:149] Failed to load resources table in APK 'D:\sdk\platforms\android-35\android.jar'.
     error: failed to load include path D:\sdk\platforms\android-35\android.jar.
Execution failed for task ':app_group_directory:verifyReleaseResources'.
> A failure occurred while executing com.android.build.gradle.tasks.VerifyLibraryResourcesTask$Action
     ERROR:\BlackProject\build\app_group_directory\intermediates\merged_res\release\values\values.xml:194: AAPT: error: resource android:attr/lStar not found.
发表于 2024-9-1 16:20:24 | 只看该作者
Using the answer from here Update compileSdkVersion and targetSdkVersion to 31
And add this code snippet in your android/build.gradle file at the very end.
configurations.all {
    resolutionStrategy {
        force 'androidx.core:core-ktx:1.6.0'
Just recently the original author of audioplayers package fixed this issue in his recent PR. It has been fixed in audioplayers version 0.20.1, so if your issue is related to audioplayers, do upgrade.
可以试试
 楼主| 发表于 2024-9-1 14:15:01 | 只看该作者
需要远程帮我解决
发表于 2024-9-1 14:27:59 | 只看该作者
找chatgpt问一问基本就解决了。。。
 楼主| 发表于 2024-9-1 14:38:08 | 只看该作者
哎,我就是问了。屁用没用
发表于 2024-9-1 14:39:47 | 只看该作者
8iack 发表于 2024-9-1 14:15
需要远程帮我解决
报错贴出来   看下大概是什么问题咯
发表于 2024-9-1 14:44:47 来自手机 | 只看该作者
你这是要编译指定源码啊,那估计挺麻烦的。
发表于 2024-9-1 15:00:48 来自手机 | 只看该作者
源码发一下
发表于 2024-9-1 15:04:56 | 只看该作者
我第一次用flutter都是gpt给我查错的,能运行。 环境的话是卡在google网络检测上了吧
GMT+8, 2026-4-22 07:53 , Processed in 0.064119 second(s), 11 queries , Gzip On, MemCache On.
