查看: 1881|回复: 9
[交易VPS] [已出] 。免税法区kimsufi账号出美區 KS-LE
发表于 2024-8-26 13:37:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
【配置】
CPU: Intel Xeon E5-1650v2
内存:32G
硬盘:2x 4TB
带宽:100M。中獎雙向千兆
流量:不限
IP:1个
续费:21.99 歐元/月,到期时间:9月25日
25美刀 Paypal或USDT收款。
TG聯繫
  1. root@ovh3:~# curl -sL yabs.sh | bash
  2. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  3. #              Yet-Another-Bench-Script              #
  4. #                     v2024-06-09                    #
  5. # https://github.com/masonr/yet-another-bench-script #
  6. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. Mon Aug 26 13:28:23 CST 2024
  8. Basic System Information:
  9. ---------------------------------
  10. Uptime     : 0 days, 0 hours, 41 minutes
  11. Processor  : Intel(R) Xeon(R) CPU E5-1650 v2 [url=home.php?mod=space&uid=175]@[/url] 3.50GHz
  12. CPU cores  : 12 [url=home.php?mod=space&uid=175]@[/url] 3599.888 MHz
  13. AES-NI     : ✔ Enabled
  14. VM-x/AMD-V : ✔ Enabled
  15. RAM        : 31.3 GiB
  16. Swap       : 8.0 GiB
  17. Disk       : 3.6 TiB
  18. Distro     : Debian GNU/Linux 12 (bookworm)
  19. Kernel     : 6.8.12-1-pve
  20. VM Type    : NONE
  21. IPv4/IPv6  : ✔ Online / ✔ Online
  22. IPv6 Network Information:
  23. ---------------------------------
  24. ISP        : OVH SAS
  25. ASN        : AS16276 OVH SAS
  26. Host       : OVH Hosting, Inc
  27. Location   : Beauharnois, Quebec (QC)
  28. Country    : Canada
  29. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  30. ---------------------------------
  31. Block Size | 4k            (IOPS) | 64k           (IOPS)
  33. Read       | 701.00 KB/s    (175) | 10.73 MB/s     (167)
  34. Write      | 734.00 KB/s    (183) | 11.22 MB/s     (175)
  35. Total      | 1.43 MB/s      (358) | 21.95 MB/s     (342)
  36.            |                      |
  37. Block Size | 512k          (IOPS) | 1m            (IOPS)
  38.   ------   | ---            ----  | ----           ----
  39. Read       | 43.81 MB/s      (85) | 53.96 MB/s      (52)
  40. Write      | 46.12 MB/s      (90) | 57.65 MB/s      (56)
  41. Total      | 89.93 MB/s     (175) | 111.62 MB/s    (108)
  42. iperf3 Network Speed Tests (IPv4):
  43. ---------------------------------
  44. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  45. -----           | -----                     | ----            | ----            | ----
  46. Clouvider       | London, UK (10G)          | 885 Mbits/sec   | 863 Mbits/sec   | 85.8 ms
  47. Eranium         | Amsterdam, NL (100G)      | 885 Mbits/sec   | 871 Mbits/sec   | 84.2 ms
  48. Uztelecom       | Tashkent, UZ (10G)        | 820 Mbits/sec   | 630 Mbits/sec   | 182 ms
  49. Leaseweb        | Singapore, SG (10G)       | 478 Mbits/sec   | 591 Mbits/sec   | 244 ms
  50. Clouvider       | Los Angeles, CA, US (10G) | 892 Mbits/sec   | 692 Mbits/sec   | 68.3 ms
  51. Leaseweb        | NYC, NY, US (10G)         | 937 Mbits/sec   | 939 Mbits/sec   | 9.25 ms
  52. Edgoo           | Sao Paulo, BR (1G)        | 847 Mbits/sec   | 823 Mbits/sec   | 120 ms
  53. iperf3 Network Speed Tests (IPv6):
  54. ---------------------------------
  55. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  56. -----           | -----                     | ----            | ----            | ----
  57. Clouvider       | London, UK (10G)          | 870 Mbits/sec   | 845 Mbits/sec   | 85.8 ms
  58. Eranium         | Amsterdam, NL (100G)      | 874 Mbits/sec   | 823 Mbits/sec   | 84.5 ms
  59. Uztelecom       | Tashkent, UZ (10G)        | 782 Mbits/sec   | 264 Mbits/sec   | 183 ms
  60. Leaseweb        | Singapore, SG (10G)       | 565 Mbits/sec   | 615 Mbits/sec   | 244 ms
  61. Clouvider       | Los Angeles, CA, US (10G) | 880 Mbits/sec   | 783 Mbits/sec   | 68.3 ms
  62. Leaseweb        | NYC, NY, US (10G)         | 924 Mbits/sec   | 925 Mbits/sec   | 9.26 ms
  63. Edgoo           | Sao Paulo, BR (1G)        | 834 Mbits/sec   | 792 Mbits/sec   | 120 ms
  64. Running GB6 benchmark test... *cue elevator music*
 楼主| 发表于 2024-8-26 14:46:57 | 只看该作者
喜歡就帶走吧
 楼主| 发表于 2024-8-26 14:47:58 | 只看该作者
只有HDD
发表于 2024-8-26 22:55:01 来自手机 | 只看该作者
我的ks-le是16.49欧
发表于 2024-8-26 23:08:20 | 只看该作者
什么配置的
发表于 2024-8-27 09:59:06 来自手机 | 只看该作者
zhongziso 发表于 2024-8-26 22:55
我的ks-le是16.49欧
啥配置的?
发表于 2024-8-27 11:31:07 | 只看该作者
配置跟楼主一样,只是没有带宽中奖。目前自用
GMT+8, 2026-5-1 02:34 , Processed in 0.065100 second(s), 11 queries , Gzip On, MemCache On.
