查看: 1375|回复: 9
Centos系统现在安装不了宝塔了吗??
发表于 2024-8-23 22:49:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
安装了好几次都是错误 哪位大哥大姐帮忙解决下呗
One of the configured repositories failed (Unknown),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:
     1. Contact the upstream for the repository and get them to fix the problem.
     2. Reconfigure the baseurl/etc. for the repository, to point to a working
        upstream. This is most often useful if you are using a newer
        distribution release than is supported by the repository (and the
        packages for the previous distribution release still work).
     3. Run the command with the repository temporarily disabled
            yum --disablerepo=<repoid> ...
     4. Disable the repository permanently, so yum won't use it by default. Yum
        will then just ignore the repository until you permanently enable it
        again or use --enablerepo for temporary usage:
            yum-config-manager --disable <repoid>
        or
            subscription-manager repos --disable=<repoid>
     5. Configure the failing repository to be skipped, if it is unavailable.
        Note that yum will try to contact the repo. when it runs most commands,
        so will have to try and fail each time (and thus. yum will be be much
        slower). If it is a very temporary problem though, this is often a nice
        compromise:
            yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot find a valid baseurl for repo: base/7/x86_64
install.sh: line 730: unzip: command not found
-rw-r--r--. 1 root root 20M Jan  4  2024 panel.zip
ERROR: Failed to download, please try install again!
ERROR: 下载宝塔失败,请尝试重新安装!
CentOS Linux release 7.9.2009 (Core)
Bit:64 Mem:1789M Core:2
Linux vps-b7622b6d.vps.ovh.ca 3.10.0-1160.119.1.el7.x86_64 #1 SMP Tue Jun 4 14:43:51 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
请截图以上报错信息发帖至论坛求助
[root@vps-b7622b6d centos]#
发表于 2024-8-23 22:54:07 来自手机 | 只看该作者
大家都在用这个系统,都能安装,怎么就你不行啊,别老怀疑系统,多找找自己的原因,是不是自己没奴隶学技术?
发表于 2024-8-23 22:56:51 | 只看该作者
yum坏了,重新重建下yum缓存
发表于 2024-8-23 23:05:08 | 只看该作者
是centos7吧?换源安装
发表于 2024-8-23 23:10:19 | 只看该作者
centos7  2024年12月31日停止提供支持,现在是不是rocky坐正,取代了centos的位置?
发表于 2024-8-23 23:14:46 | 只看该作者
你这是centos7吧 换yum源就好了
发表于 2024-8-24 01:38:54 | 只看该作者
发表于 2024-8-24 02:12:28 | 只看该作者
huangdog 发表于 2024-8-23 23:10
centos7  2024年12月31日停止提供支持,现在是不是rocky坐正,取代了centos的位置? ...
AlmaLinux
RockyLinux
 楼主| 发表于 2024-8-24 10:28:52 | 只看该作者
茶会参谋 发表于 2024-8-24 01:38
解决办法
https://loc.qiche.eu.org/thread-1326449-1-1.html
谢谢大哥。
GMT+8, 2026-4-24 10:00 , Processed in 0.075539 second(s), 12 queries , Gzip On, MemCache On.
