查看: 1312|回复: 4
[特价VPS] Hosthatch伦敦机器宣布迁移失败,又换回去了......
发表于 2024-8-16 10:17:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi there,
Due to unexpected difficulties, we will be canceling the London RAID-10 migration for now. We will offer migration again in the future once we've worked things out.
Since your old VM was replaced with the new one on the new RAID-10 platform, I've gone ahead and deleted it and reprovisioned a new one for you on our existing London aka "old" storage platform. The same hostname and IP have been retained.
As compensation for the issues faced, I've also added 15 days to your service. Please let us know if there's any further assistance required and we'd be glad to help.
Best Regards,
Ivan T
HostHatch Support
你好,
由于意外的困难,我们将暂时取消伦敦 RAID-10 迁移。我们会在解决问题后再次提供迁移服务。
因为您的旧虚拟机已经被新 RAID-10 平台上的新虚拟机替换,我已删除它并在我们现有的伦敦(即“旧”存储平台)上为您重新配置了一个新的虚拟机。相同的主机名和 IP 地址已保留。
作为对所遇到问题的补偿,我还为您的服务增加了15天。如果需要进一步帮助,请告知,我们很乐意提供协助。
此致,
Ivan T
HostHatch 支持
有一点值得肯定的是,工单回复速度比以前快不少 = =
发表于 2024-8-16 10:21:27 | 只看该作者
15天打发狗
 楼主| 发表于 2024-8-16 10:40:03 | 只看该作者
确实,这鸡65刀3年我都用来当额外备份的
发表于 2024-8-16 17:24:46 | 只看该作者
大佬好多鸡
 楼主| 发表于 2024-8-16 17:28:04 | 只看该作者
鸡鸡复鸡鸡
GMT+8, 2026-4-25 16:19 , Processed in 0.071865 second(s), 10 queries , Gzip On, MemCache On.
