查看: 4645|回复: 24
[特价VPS] [已出]折价200出HostHatch日本4核心24G内存300GB固态20TB月流量
发表于 2024-8-15 11:35:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. Basic System Information:
  3. Uptime     : 68 days, 14 hours, 21 minutes
  4. Processor  : AMD EPYC 7513 32-Core Processor
  5. CPU cores  : 4 [url=home.php?mod=space&uid=175]@[/url] 2595.122 MHz
  6. AES-NI     : ✔️ Enabled
  7. VM-x/AMD-V : ✔️ Enabled
  8. RAM        : 23.6 GiB
  9. Swap       : 2.0 GiB
  10. Disk       : 270.6 GiB
  11. Distro     : Ubuntu 22.04.1 LTS
  12. Kernel     : 6.5.0-35-generic
  13. VM Type    : KVM
  14. IPv4/IPv6  : ✔️ Online / ❌ Offline
  15. IPv4 Network Information:
  16. ---------------------------------
  17. ISP        : EpicUp Holdings Inc
  18. ASN        : AS63473 HostHatch, LLC
  19. Host       : Ipxo LLC
  20. Location   : Tokyo, Tokyo (13)
  21. Country    : Japan
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 201.38 MB/s  (50.3k) | 1.91 GB/s    (29.8k)
  27. Write      | 201.91 MB/s  (50.4k) | 1.92 GB/s    (30.0k)
  28. Total      | 403.29 MB/s (100.8k) | 3.83 GB/s    (59.8k)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 2.86 GB/s     (5.6k) | 2.84 GB/s     (2.7k)
  33. Write      | 3.02 GB/s     (5.9k) | 3.03 GB/s     (2.9k)
  34. Total      | 5.89 GB/s    (11.5k) | 5.88 GB/s     (5.7k)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | 761 Mbits/sec   | 513 Mbits/sec   | 204 ms
  40. Eranium         | Amsterdam, NL (100G)      | 4.55 Gbits/sec  | 3.42 Gbits/sec  | 208 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | 361 Mbits/sec   | 1.30 Gbits/sec  | 173 ms
  42. Leaseweb        | Singapore, SG (10G)       | busy            | 1.42 Gbits/sec  | 67.6 ms
  43. Clouvider       | Los Angeles, CA, US (10G) | 1.73 Gbits/sec  | 1.06 Gbits/sec  | 98.0 ms
  44. Leaseweb        | NYC, NY, US (10G)         | 3.40 Gbits/sec  | 1.77 Gbits/sec  | 141 ms
  45. Edgoo           | Sao Paulo, BR (1G)        | 1.80 Gbits/sec  | 1.01 Gbits/sec  | 272 ms
  46. Geekbench 6 Benchmark Test:
  47. ---------------------------------
  48. Test            | Value
  49.                 |
  50. Single Core     | 1221
  51. Multi Core      | 3604
  52. Full Test       | https://browser.geekbench.com/v6/cpu/7424125
  53. YABS completed in 11 min 7 sec
细节说明:
1、型号:AMD Compute 16GB - PROMO-O
CPU是4核心AMD EPYC 7513
内存是24.19 GiB
固态是300.00 GB
带宽是共享10GbE。来自官网信息:https://docs.hosthatch.com/features/
月流量是20.00 TB
2、该机器只有1个IPV4地址,只有1段/64的IPV6。
如果我贴的测试脚本看到没有IPV6测试,只是因为我没配。
3、该机器无合约,两年付。到期日是2025年10月14日。续费价290刀。
4、每个月流量双向计算,每月1号重置月流量,截止发帖时,该机器的流量只用了不到1TB。
5、我只收剩余价值折价200元,然后去掉十位数和个位数取整。请有意者私信告知你的联系方式,支付方式可以详谈,买家先款。
6、我承担Server Transfers的10刀转让费。
7、如果你私信我,默认你已接受上述所有文字提及的全部细节。
发表于 2024-8-15 11:53:13 | 只看该作者
4c24g300g 一年150$ 不如 6c24g 300g 10$一月的。
发表于 2024-8-15 12:02:37 | 只看该作者
才发现我是 6h  24 的 还有这个区别~
 楼主| 发表于 2024-8-15 15:15:23 | 只看该作者
请问你说的这一款,HH日本,具体配置和流量和价格是多少?
 楼主| 发表于 2024-8-15 18:45:39 | 只看该作者
自刀至88元溢价
GMT+8, 2026-4-16 05:51 , Processed in 0.065873 second(s), 11 queries , Gzip On, MemCache On.
