CeraNetworks网络延迟测速工具IP归属甄别
查看: 1268|回复: 1
iwebfusion便宜
发表于 2024-8-2 13:35:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
iwebfusion有一批特价母鸡,看看有没有你中意的?
Dual E5-2670 (16 cores),128GB RAM,500GB SSD or 2TB SATA,30TB bandwidth @ 1Gbps,5 IPv4 + /64 IPv6,$79.00/mo
Dual E5-2699v4 44核心 64G,5x2TB HHD,  5 IPv4 + /64 IPv6,  30tb/1G, Price132.50
AMD Ryzen 9 7950x 128GB 2TB NVMe Software/BIOS 40TB/1G 5 IPv4 + /64 IPv6 price is $167.00
Dual E5-2690v2 / 128GB RAM / 2x 1TB SSD / 20TB bw @ 1Gbps / 5 IPv4 / $125.00
Quad E5-4650v2 (40 cores / 80 threads),512GB RAM,2TB SSD,5x IPv4/64 IPv6,30TB/ 10G,$152 / mo
Quad E5-4650v2 (40 cores / 80 threads),512GB RAM,2TB SSD,5x IPv4/64 IPv6,500M/unmetered,+ 253ips(mixed ip ranges)$427 / mo
Dual E5-2699v4(44 cores),512GB RAM,2TB SSD,5x IPv4/64 IPv6,30TB/ 10G,$162 / mo
洛杉矶, CA (Psychz)
洛杉矶, CA (Aptum)
俄勒冈州本德
AMD EPYC 7443P 24cores / 256GB RAM / 2x 2TB NVMe / 50TB bw @ 10GigE
$259 / mo
AMD EPYC 7443P 24cores / 256GB RAM / 4x 4TB NVMe / 50TB bw @ 10GigE
$347 / mo
Dual E5-2697v2
512GB DDR3 RAM
512G SSD(系统盘) system disk
4x2TB ssd(数据盘)data disk
1x4TB sata    (备份) back up
Hard Raid card,support at least 1G cache
40TB bandwidth @ 1Gbps
25x/29=125 ips
$209 / mo heavily discounted
Dual E5-2697v3
256GB DDR4 RAM
Hard Raid card,support at least 2G cache
25x/29=125 ips
Los Angeles or bend
$239 / mo with these specs - probably would be 3-5 working days for setup (edited)
豪华J
AMD EYPC 9654 96cores 256GB 2x 2TB NVMe Software/BIOS 40TB 5 IPv4 + /64 IPv6 $429 1-2 weeks
单加一个/24, $140.00,还有好多定制机配置,来找我。
 楼主| 发表于 2024-8-5 10:54:28 | 只看该作者
洛杉矶, CA (Psychz)
洛杉矶, CA (Aptum)
俄勒冈州本德
$259 / mo
$347 / mo
Dual E5-2697v2
512GB DDR3 RAM
25x/29=125 ips
Dual E5-2697v3
256GB DDR4 RAM
25x/29=125 ips
Los Angeles or bend
豪华J
GMT+8, 2026-4-28 15:57 , Processed in 0.059597 second(s), 10 queries , Gzip On, MemCache On.
