查看: 990|回复: 2
有谁玩懂了cf的那个重定向规则么?
发表于 2024-7-21 19:24:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以前在页面规则中可以
domain.com/*/*/*/*.jpg
转发 URL (状态代码: 301 - 临时重定向, URL: https://domain.com/$1/$2/$3/$4!webp)
但是那个重定向规则,我愣是看不太懂,她的文档我照着类推写了,提示不合法
说的是官方会在2025年全部将页面规则中的东西同步到其他规则中...
Cloudflare plans to migrate your existing Page Rules during 2025. You do not need to migrate your own rules, as Cloudflare will handle this process for you. However, it is beneficial to understand the correspondence between the different Page Rules settings and new Rules features ahead of the migration. This will help you familiarize yourself with implementing the new types of rules in your Cloudflare account.
Cloudflare 计划在 2025 年迁移您现有的页面规则。您无需迁移自己的规则,因为 Cloudflare 将为您处理此过程。但是,在迁移之前了解不同的页面规则设置与新规则功能之间的对应关系是有益的。这将帮助您熟悉如何在 Cloudflare 帐户中实施新类型的规则。
We encourage you to explore and start using the new Rules products to take advantage of their enhanced capabilities and features. This migration guide will be updated in the coming months with additional information about the Page Rules migration. Some instructions may also change as we simplify configuration deployment and release new features as part of this project. Cloudflare users will receive email updates about the migration of the Page Rules configured on their Cloudflare account before the migration occurs. We will not perform any migration or changes on your behalf without prior notification.
我们鼓励您探索并开始使用新的 Rules 产品,以利用其增强的功能和特性。本迁移指南将在未来几个月内更新,其中包含有关页面规则迁移的其他信息。随着我们简化配置部署并发布新功能作为此项目的一部分,某些说明也可能会更改。在迁移发生之前,Cloudflare 用户将收到有关迁移在其 Cloudflare 帐户上配置的页面规则的电子邮件更新。未经事先通知,我们不会代表您执行任何迁移或更改。
来自 3#
 楼主| 发表于 2024-7-21 22:06:09 | 只看该作者
已经搞定了,还是很简单的。
发表于 2024-7-21 19:26:42 | 只看该作者
让claude解释一下啊
GMT+8, 2026-5-3 21:00 , Processed in 0.061970 second(s), 12 queries , Gzip On, MemCache On.
