查看: 1067|回复: 4
剛買的sys-2-sat-32 還不錯
发表于 2024-7-8 14:43:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Poland的
可惜沒中硬盤
  3. #                     v2024-06-09                    #
  6. Mon Jul  8 06:22:49 UTC 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 5 minutes
  10. Processor  : Intel(R) Xeon(R) CPU D-1541 [url=home.php?mod=space&uid=175]@[/url] 2.10GHz
  11. CPU cores  : 16 @ 800.000 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 2.0 GiB
  16. Disk       : 1.8 TiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-22-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH Sp. z o. o
  26. Location   : Wroclaw, Lower Silesia (02)
  27. Country    : Poland
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  32. Read       | 956.00 KB/s    (239) | 13.23 MB/s     (206)
  33. Write      | 988.00 KB/s    (247) | 13.86 MB/s     (216)
  34. Total      | 1.94 MB/s      (486) | 27.10 MB/s     (422)
  38. Read       | 50.55 MB/s      (98) | 68.49 MB/s      (66)
  39. Write      | 53.43 MB/s     (104) | 73.05 MB/s      (71)
  40. Total      | 103.98 MB/s    (202) | 141.55 MB/s    (137)
  45. Clouvider       | London, UK (10G)          | 5.25 Gbits/sec  | 5.16 Gbits/sec  | 39.3 ms
  46. Eranium         | Amsterdam, NL (100G)      | busy            | busy            | --
  47. Uztelecom       | Tashkent, UZ (10G)        | 2.04 Gbits/sec  | 2.17 Gbits/sec  | 115 ms
  48. Leaseweb        | Singapore, SG (10G)       | 961 Mbits/sec   | 488 Mbits/sec   | 182 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 932 Mbits/sec   | 1.05 Gbits/sec  | 168 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 1.71 Gbits/sec  | 1.82 Gbits/sec  | 102 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 964 Mbits/sec   | 815 Mbits/sec   | 183 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 3.90 Gbits/sec  | 4.14 Gbits/sec  | 39.4 ms
  57. Eranium         | Amsterdam, NL (100G)      | busy            | busy            | --
  58. Uztelecom       | Tashkent, UZ (10G)        | 1.41 Gbits/sec  | 882 Mbits/sec   | 115 ms
  59. Leaseweb        | Singapore, SG (10G)       | 1.04 Gbits/sec  | 943 Mbits/sec   | 182 ms
  60. Clouvider       | Los Angeles, CA, US (10G) | 988 Mbits/sec   | 1.04 Gbits/sec  | 168 ms
  61. Leaseweb        | NYC, NY, US (10G)         | 2.13 Gbits/sec  | 1.83 Gbits/sec  | 102 ms
  62. Edgoo           | Sao Paulo, BR (1G)        | 1.10 Gbits/sec  | 963 Mbits/sec   | 184 ms
  63. Geekbench 6 Benchmark Test:
  64. ---------------------------------
  65. Test            | Value
  66.                 |
  67. Single Core     | 954
  68. Multi Core      | 5001
  69. Full Test       | https://browser.geekbench.com/v6/cpu/6825906
  70. YABS completed in 18 min 34 sec
发表于 2024-7-8 15:01:08 来自手机 | 只看该作者
看不出哪好
发表于 2024-7-8 15:22:00 | 只看该作者
硬盘4t?你raid1了?
 楼主| 发表于 2024-7-8 15:22:57 | 只看该作者
網路沒限250mb
发表于 2024-7-8 15:23:40 | 只看该作者
网络中奖。挺好的
GMT+8, 2026-4-23 22:04 , Processed in 0.058118 second(s), 9 queries , Gzip On, MemCache On.
