查看: 1275|回复: 3
请教AWS能不能更改账号国家
发表于 2024-7-4 14:29:44 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
接上贴,不知道是不是因为前几天openai开始查中国访问的API。我申请的azure openai给我拒了。所以就开始搞AWS的claude,然后发现自己的账号以前注册的国家是中国,用不了这个。想问下大佬,有没有可能更高AWS的国家信息,然后再开claude呢?也有尝试新注册了个AWS号,但发现用不了claude3.5,所以还是想在老号上改改试试
发表于 2024-7-4 16:14:37 | 只看该作者
sunkeinfo 发表于 2024-7-4 15:44
我是AWS专家, 我的AWSDO.COM已经服务了数以千计的客户, 我对AWS了如指掌, 我来回答你的问题吧, 我的解 ...
不敢苟同 老账户 刚刚提交的
Dear AWS Marketplace Customer,
You have subscribed to the following product in AWS Marketplace:
* Claude 3.5 Sonnet (Amazon Bedrock Edition) sold by Anthropic, PBC
Your subscription to this product results either from a subscription you made directly or a subscription that you were granted from an associated account in your AWS Organization.
You are now able to use this software with AWS. Amazon Machine Image (AMI)-based products can be launched directly from AWS Marketplace, via the AWS Console, or through EC2 APIs.
If you have subscribed to a Software as a Service (SaaS) product, you can access it directly from the seller’s website or from the Your Software page in AWS Marketplace.
If you have subscribed to a Professional Services product, your service provider will reach out to contact you directly.
发表于 2024-7-4 14:46:39 | 只看该作者
怎么查看账户的注册国家啊
发表于 2024-7-4 15:44:28 | 只看该作者
我是AWS专家, 我的AWSDO.COM已经服务了数以千计的客户, 我对AWS了如指掌, 我来回答你的问题吧, 我的解答应该是有一定权威性的:
AWS不能开claude,不管你是什么国家地址。你也有尝试新注册了个AWS号,但发现还是用不了claude3.5。综上所述,claude3.5 不适用于你的AWS账号。
GMT+8, 2026-4-30 13:11 , Processed in 0.064134 second(s), 11 queries , Gzip On, MemCache On.
