查看: 1029|回复: 0
[美国VPS] 求助n1装的青龙安装依赖
发表于 2024-6-29 11:52:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是哪里有问题啊,求助
  1. 日志 - dailycheckin
  2. 开始安装依赖 dailycheckin,开始时间 2024-06-29 11:47:03
  3. WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8fa3a950>: Failed to establish a new connection: [Errno 13] Permission denied')': /simple/dailycheckin/
  4. Collecting dailycheckin
  5.   Using cached dailycheckin-24.5.15-py3-none-any.whl.metadata (10 kB)
  6. Collecting pycryptodome==3.17 (from dailycheckin)
  7.   Using cached pycryptodome-3.17-cp35-abi3-musllinux_1_1_aarch64.whl.metadata (3.2 kB)
  8. Collecting requests~=2.25.1 (from dailycheckin)
  9.   Using cached requests-2.25.1-py2.py3-none-any.whl.metadata (4.2 kB)
  10. Collecting rsa~=4.0 (from dailycheckin)
  11.   Using cached rsa-4.9-py3-none-any.whl.metadata (4.2 kB)
  12. Collecting urllib3~=1.26.2 (from dailycheckin)
  13.   Using cached urllib3-1.26.19-py2.py3-none-any.whl.metadata (49 kB)
  14. Collecting chardet<5,>=3.0.2 (from requests~=2.25.1->dailycheckin)
  15.   Using cached chardet-4.0.0-py2.py3-none-any.whl.metadata (3.5 kB)
  16. Collecting idna<3,>=2.5 (from requests~=2.25.1->dailycheckin)
  17.   Downloading idna-2.10-py2.py3-none-any.whl.metadata (9.1 kB)
  18. Collecting certifi>=2017.4.17 (from requests~=2.25.1->dailycheckin)
  19.   Downloading certifi-2024.6.2-py3-none-any.whl.metadata (2.2 kB)
  20. Collecting pyasn1>=0.1.3 (from rsa~=4.0->dailycheckin)
  21.   Downloading pyasn1-0.6.0-py2.py3-none-any.whl.metadata (8.3 kB)
  22. Downloading dailycheckin-24.5.15-py3-none-any.whl (47 kB)
  23.    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 47.3/47.3 kB 4.3 kB/s eta 0:00:00
  24. Downloading pycryptodome-3.17-cp35-abi3-musllinux_1_1_aarch64.whl (2.0 MB)
  25.    ━━━━━━                                   0.3/2.0 MB 5.6 kB/s eta 0:05:12
  26. ERROR: Exception:
  27. Traceback (most recent call last):
  28.   File "/usr/local/lib/python3.11/site-packages/pip/_vendor/urllib3/response.py", line 438, in _error_catcher
  29.     yield
  30.   File "/usr/local/lib/python3.11/site-packages/pip/_vendor/urllib3/response.py", line 561, in read
  31.     data = self._fp_read(amt) if not fp_closed else b""
  32.            ^^^^^^^^^^^^^^^^^^
  33.   File "/usr/local/lib/python3.11/site-packages/pip/_vendor/urllib3/response.py", line 527, in _fp_read
  34.     return self._fp.read(amt) if amt is not None else self._fp.read()
  35.            ^^^^^^^^^^^^^^^^^^
  36.   File "/usr/local/lib/python3.11/site-packages/pip/_vendor/cachecontrol/filewrapper.py", line 98, in read
  37.     data: bytes = self.__fp.read(amt)
  38.                   ^^^^^^^^^^^^^^^^^^^
  39.   File "/usr/local/lib/python3.11/http/client.py", line 473, in read
  40.     s = self.fp.read(amt)
  41.         ^^^^^^^^^^^^^^^^^
  42.   File "/usr/local/lib/python3.11/socket.py", line 706, in readinto
  43.     return self._sock.recv_into(b)
  44.            ^^^^^^^^^^^^^^^^^^^^^^^
  45.   File "/usr/local/lib/python3.11/ssl.py", line 1314, in recv_into
  46.     return self.read(nbytes, buffer)
  47.            ^^^^^^^^^^^^^^^^^^^^^^^^^
  48.   File "/usr/local/lib/python3.11/ssl.py", line 1166, in read
  49.     return self._sslobj.read(len, buffer)
  50.            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
  51. TimeoutError: The read operation timed out
  52. During handling of the above exception, another exception occurred:
  53. Traceback (most recent call last):
  54.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/cli/base_command.py", line 180, in exc_logging_wrapper
  55.     status = run_func(*args)
  56.              ^^^^^^^^^^^^^^^
  57.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 245, in wrapper
  58.     return func(self, options, args)
  59.            ^^^^^^^^^^^^^^^^^^^^^^^^^
  60.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/commands/install.py", line 377, in run
  61.     requirement_set = resolver.resolve(
  62.                       ^^^^^^^^^^^^^^^^^
  63.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 179, in resolve
  64.     self.factory.preparer.prepare_linked_requirements_more(reqs)
  65.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/operations/prepare.py", line 552, in prepare_linked_requirements_more
  66.     self._complete_partial_requirements(
  67.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/operations/prepare.py", line 467, in _complete_partial_requirements
  68.     for link, (filepath, _) in batch_download:
  69.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/network/download.py", line 183, in __call__
  70.     for chunk in chunks:
  71.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/cli/progress_bars.py", line 53, in _rich_progress_bar
  72.     for chunk in iterable:
  73.   File "/usr/local/lib/python3.11/site-packages/pip/_internal/network/utils.py", line 63, in response_chunks
  74.     for chunk in response.raw.stream(
  75.   File "/usr/local/lib/python3.11/site-packages/pip/_vendor/urllib3/response.py", line 622, in stream
  76.     data = self.read(amt=amt, decode_content=decode_content)
  77.            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
  78.   File "/usr/local/lib/python3.11/site-packages/pip/_vendor/urllib3/response.py", line 560, in read
  79.     with self._error_catcher():
  80.   File "/usr/local/lib/python3.11/contextlib.py", line 158, in __exit__
  81.     self.gen.throw(typ, value, traceback)
  82.   File "/usr/local/lib/python3.11/site-packages/pip/_vendor/urllib3/response.py", line 443, in _error_catcher
  83.     raise ReadTimeoutError(self._pool, None, "Read timed out.")
  84. pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Read timed out.
  85. 依赖安装失败,结束时间 2024-06-29 11:49:53,耗时 169 秒
GMT+8, 2026-4-15 12:24 , Processed in 0.064246 second(s), 10 queries , Gzip On, MemCache On.
