查看: 1276|回复: 3
[疑问] vaultwarden这个日志正常吗
发表于 2024-6-26 15:57:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自建了个vaultwarden,没开防火墙,看了这个日志貌似像扫漏洞。
[error] 502948#502948: *9630 access forbidden by rule, client: 179.43.188.122, server: vault.usbusb.xyz, request: "GET /.git/config
[error] 502948#502948: *10070 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /a/.git/config
[error] 502948#502948: *10073 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/admin/v2/.git/config
[error] 502948#502948: *10074 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/admin/v3/.git/config
[error] 502948#502948: *10075 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/user/v2/.git/config
[error] 502949#502949: *10080 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /aomanalyzer/.git/config
[error] 502948#502948: *10081 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /application/.git/config
[error] 502949#502949: *10079 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/user/v1/.git/config
[error] 502949#502949: *10083 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /amphtml/.git/config
[error] 502948#502948: *10082 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /app/.git/config
[error] 502949#502949: *10086 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/v4/.git/config
[error] 502948#502948: *10088 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/user/v3/.git/config
[error] 502949#502949: *10090 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/admin/v1/.git/config
[error] 502949#502949: *10091 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /admin/.git/config
[error] 502949#502949: *10076 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/v1/.git/config
[error] 502949#502949: *10089 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/admin/v4/.git/config
[error] 502949#502949: *10093 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /common/.git/config
[error] 502949#502949: *10092 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /blog/.git/config
[error] 502948#502948: *10094 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /build/.git/config
[error] 502948#502948: *10095 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /blog/wp-content/themes/.git/config
[error] 502948#502948: *10096 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /beta/.git/config
[error] 502949#502949: *10097 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /cms/.git/config
[error] 502949#502949: *10098 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /config/.git/config
[error] 502949#502949: *10099 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /backup/.git/config
[error] 502949#502949: *10072 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /alpha/.git/config
[error] 502948#502948: *10087 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/v3/.git/config
[error] 502948#502948: *10101 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /data/.git/config
[error] 502948#502948: *10103 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /flock/.git/config
[error] 502949#502949: *10104 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /dev/.git/config
[error] 502949#502949: *10106 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /.git/config
[error] 502948#502948: *10107 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /git/.git/config
[error] 502949#502949: *10108 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /developer/.git/config
[error] 502948#502948: *10110 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /__MACOSX/.git/config
[error] 502948#502948: *10084 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/v2/.git/config
[error] 502949#502949: *10085 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/user/v4/.git/config
[error] 502949#502949: *10112 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /new/.git/config
[error] 502949#502949: *10113 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /node_modules/.git/config
[error] 502948#502948: *10111 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /m/.git/config
[error] 502949#502949: *10114 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /s3/.git/config
[error] 502949#502949: *10115 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /repos/.git/config
[error] 502949#502949: *10116 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /public/.git/config
[error] 502948#502948: *10117 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /qa/.git/config
[error] 502949#502949: *10118 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /samples/.git/config
[error] 502948#502948: *10119 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /repository/.git/config
[error] 502949#502949: *10121 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /web/.git/config
[error] 502949#502949: *10122 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /static/.git/config
[error] 502948#502948: *10123 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /user/.git/config
[error] 502948#502948: *10124 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /test/.git/config
[error] 502949#502949: *10126 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /site/.git/config
[error] 502948#502948: *10127 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /wiki/.git/config
[error] 502949#502949: *10128 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /wp-content/plugins/.git/config
[error] 502948#502948: *10131 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /wp-content/.git/config
[error] 502949#502949: *10129 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /vendor/.git/config
[error] 502948#502948: *10109 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /includes/.git/config
[error] 502948#502948: *10132 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /src/.git/config
[error] 502949#502949: *10130 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /wp-content/themes/.git/config
[error] 502948#502948: *10134 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /wp-includes/js/.git/config
[error] 502948#502948: *10135 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /live/.git/config
[error] 502948#502948: *10078 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /api/.git/config
[error] 502948#502948: *10102 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /demo/.git/config
[error] 502948#502948: *10105 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /gateway/.git/config
[error] 502949#502949: *10100 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /database/.git/config
[error] 502948#502948: *10136 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /v2/.git/config
[error] 502948#502948: *10138 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /v1/.git/config
[error] 502949#502949: *10120 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /shop/.git/config
[error] 502948#502948: *10133 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /v3/.git/config
[error] 502948#502948: *10125 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /staging/.git/config
[error] 502948#502948: *10137 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /old-cuburn/.git/config
[error] 502948#502948: *10139 access forbidden by rule, client: 193.143.1.119, server: vault.usbusb.xyz, request: "GET /store/.git/config
发表于 2024-6-26 18:32:01 来自手机 | 只看该作者
没有二验吗?
发表于 2024-6-26 18:38:20 | 只看该作者
常规路径扫描,不是针对你的 vaultwarden,nginx 限制 ip 常用访问或者关闭网页访问就行了
 楼主| 发表于 2024-6-26 18:58:28 | 只看该作者
加了二验
GMT+8, 2026-4-17 00:41 , Processed in 0.064993 second(s), 10 queries , Gzip On, MemCache On.
