查看: 2555|回复: 11
(结束)出PureVoltage双路2680v4和3.84T nvme的万兆带宽400TB流量独服
发表于 2024-6-10 19:56:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出PureVoltage纽约双路E5-2680v4和3.84T nvme的万兆带宽400TB流量独服
  1. root@purevoltage:~# smartctl -x /dev/nvme0
  2. smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.0-18-amd64] (local build)
  3. Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
  4. === START OF INFORMATION SECTION ===
  5. Model Number:                       SAMSUNG MZQLW3T8HMLP-00003
  6. Serial Number:                      S2UDNB0JA04598
  7. Firmware Version:                   CXV8501Q
  8. PCI Vendor/Subsystem ID:            0x144d
  9. IEEE OUI Identifier:                0x002538
  10. Total NVM Capacity:                 3,840,755,982,336 [3.84 TB]
  11. Unallocated NVM Capacity:           0
  12. Controller ID:                      2
  13. NVMe Version:                       1.2
  14. Number of Namespaces:               1
  15. Namespace 1 Size/Capacity:          3,840,755,982,336 [3.84 TB]
  16. Namespace 1 Utilization:            64,607,203,328 [64.6 GB]
  17. Namespace 1 Formatted LBA Size:     512
  18. Local Time is:                      Mon Jun 10 19:47:35 2024 CST
  19. Firmware Updates (0x17):            3 Slots, Slot 1 R/O, no Reset required
  20. Optional Admin Commands (0x000e):   Format Frmw_DL NS_Mngmt
  21. Optional NVM Commands (0x001f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
  22. Log Page Attributes (0x03):         S/H_per_NS Cmd_Eff_Lg
  23. Maximum Data Transfer Size:         64 Pages
  24. Warning  Comp. Temp. Threshold:     84 Celsius
  25. Critical Comp. Temp. Threshold:     85 Celsius
  26. Namespace 1 Features (0x02):        NA_Fields
  27. Supported Power States
  28. St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
  29. 0 +     9.00W       -        -    0  0  0  0        5       5
  30. Supported LBA Sizes (NSID 0x1)
  31. Id Fmt  Data  Metadt  Rel_Perf
  32. 0 +     512       0         0
  33. 1 -    4096       0         0
  34. === START OF SMART DATA SECTION ===
  35. SMART overall-health self-assessment test result: PASSED
  36. SMART/Health Information (NVMe Log 0x02)
  37. Critical Warning:                   0x00
  38. Temperature:                        24 Celsius
  39. Available Spare:                    100%
  40. Available Spare Threshold:          10%
  41. Percentage Used:                    0%
  42. Data Units Read:                    1,930,995,607 [988 TB]
  43. Data Units Written:                 34,876,912 [17.8 TB]
  44. Host Read Commands:                 46,379,770,275
  45. Host Write Commands:                324,441,505
  46. Controller Busy Time:               10,580
  47. Power Cycles:                       69
  48. Power On Hours:                     7,406
  49. Unsafe Shutdowns:                   38
  50. Media and Data Integrity Errors:    0
  51. Error Information Log Entries:      44
  52. Warning  Comp. Temperature Time:    0
  53. Critical Comp. Temperature Time:    0
  54. Temperature Sensor 1:               24 Celsius
  55. Error Information (NVMe Log 0x01, 16 of 64 entries)
  56. Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS
  57.   0         44     0  0x4012  0x4004      -            0     0     -
  58.   1         43     0  0x4016  0x4004      -            0     0     -
  59.   2         42     0  0x4016  0x4004      -            0     0     -
  60.   3         41     0  0x4012  0x4004      -            0     0     -
  61.   4         40     0  0x008f  0x4212  0x028            0     -     -
  62.   5         39     0  0x001d  0x4004  0x028            0     0     -
  63.   6         38     0  0x001c  0x4212  0x028            0     -     -
  64.   7         37     0  0x0002  0x4004  0x028            0     0     -
  65.   8         36     0  0x5005  0x4004      -            0     0     -
  66.   9         35     0  0x001b  0x4002  0x000            0     1     -
  67. 10         34     0  0x0011  0x4002  0x000            0     1     -
  68. 11         33     0  0x0014  0x4002  0x000            0     0     -
  69. 12         32     0  0x0007  0x4002  0x000            0     0     -
  70. 13         31     0  0x0006  0x4002  0x000            0     1     -
  71. 14         30     0  0x0019  0x4002  0x000            0     1     -
  72. 15         29     0  0x0003  0x4002  0x000            0     1     -
  73. ... (48 entries not read)
细节说明:
1、配置:
双路E5-2680v4(28核心56线程)
64GB内存
三星PM963 3.84TB
万兆满血带宽,月流量400TB
ISP        : PureVoltage Hosting Inc.
ASN        : AS26548 PureVoltage Hosting Inc.
Host       : PureVoltage Hosting Inc
Country    : United States
2、该机器只有1个IPV4地址和1个/64段的IPV6地址。
3、无合约,月付,每月账单日都是16号。我已缴费至7月16号。续费价115美元。
面板可以查看流量图,面板不提供一键重装功能,但提供一键重启和开关机功能。
服务商提供了不限时的IPMI远程控制。
4、每个月流量400TB双向计算,每月16号重置月流量。截止发帖时,该机器的流量只用了不到5TB。
5、我只收剩余价值。请有意者论坛内私信联系,支付方式可以详谈,买家先款。
6、本帖提供的信息就是我目前方便提供的所有信息,不熟悉我的请自行查阅我的所有发帖历史。
7、如果你私信我,默认你已接受上述所有文字提及的全部细节。
发表于 2024-6-16 16:07:04 | 只看该作者
内存太低 不然可以开小鸡了!
GMT+8, 2026-4-16 03:59 , Processed in 0.062916 second(s), 10 queries , Gzip On, MemCache On.
