查看: 1264|回复: 1
[不限流量] VPSMarket评测-MonoVM-欧洲荷兰无限流量VPS-月付29.9美元
发表于 2024-6-10 15:19:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天VPSMarket给大家推荐一下立陶宛商家monovm 。monovm欧洲老牌商家,从2012年开始运营,有用全球地数据中心,其中欧洲数据中心的VPS无限流量。
VPSMarket拿到了这家的荷兰高性能VPS,给大家做下评测。
具体跑分数据。
#              Yet-Another-Bench-Script              #
#                     v2024-06-09                    #
# https://github.com/masonr/yet-another-bench-script #
Mon Jun 10 02:35:55 AM EDT 2024
Basic System Information:
Uptime     : 2 days, 16 hours, 4 minutes
Processor  : AMD EPYC-Milan Processor
CPU cores  : 4 @ 3393.602 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM        : 3.8 GiB
Swap       : 1023.0 MiB
Disk       : 28.4 GiB
Distro     : Debian GNU/Linux 12 (bookworm)
Kernel     : 6.1.0-9-amd64
VM Type    : KVM
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : Hostkey BV
ASN        : AS57043 HOSTKEY B.V.
Host       : Hostkey B.V.
Country    : The Netherlands
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
Read       | 377.63 MB/s  (94.4k) | 737.79 MB/s  (11.5k)
Write      | 378.63 MB/s  (94.6k) | 741.67 MB/s  (11.5k)
Total      | 756.27 MB/s (189.0k) | 1.47 GB/s    (23.1k)
Read       | 703.95 MB/s   (1.3k) | 695.29 MB/s    (678)
Write      | 741.35 MB/s   (1.4k) | 741.60 MB/s    (724)
Total      | 1.44 GB/s     (2.8k) | 1.43 GB/s     (1.4k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 795 Mbits/sec   | 800 Mbits/sec   | 7.39 ms
Eranium         | Amsterdam, NL (100G)      | 803 Mbits/sec   | 837 Mbits/sec   | --
Uztelecom       | Tashkent, UZ (10G)        | 733 Mbits/sec   | 757 Mbits/sec   | 85.8 ms
Leaseweb        | Singapore, SG (10G)       | 559 Mbits/sec   | 566 Mbits/sec   | 274 ms
Clouvider       | Los Angeles, CA, US (10G) | 548 Mbits/sec   | 762 Mbits/sec   | 143 ms
Leaseweb        | NYC, NY, US (10G)         | 750 Mbits/sec   | 760 Mbits/sec   | 75.1 ms
Edgoo           | Sao Paulo, BR (1G)        | 665 Mbits/sec   | 742 Mbits/sec   | 188 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 805 Mbits/sec   | 823 Mbits/sec   | 7.30 ms
Eranium         | Amsterdam, NL (100G)      | busy            | busy            | --
Uztelecom       | Tashkent, UZ (10G)        | 748 Mbits/sec   | 806 Mbits/sec   | 86.2 ms
Leaseweb        | Singapore, SG (10G)       | 567 Mbits/sec   | 642 Mbits/sec   | 265 ms
Clouvider       | Los Angeles, CA, US (10G) | 540 Mbits/sec   | 748 Mbits/sec   | 143 ms
Leaseweb        | NYC, NY, US (10G)         | 710 Mbits/sec   | 769 Mbits/sec   | 75.0 ms
Edgoo           | Sao Paulo, BR (1G)        | 641 Mbits/sec   | 749 Mbits/sec   | 182 ms
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 1971
Multi Core      | 5854
Full Test       | https://browser.geekbench.com/v6/cpu/6458503
这款VPS,4vCPU,4GB内存,30GB的SSD硬盘,处理器采用的是高性能的AMD-Milan系列的处理器,性能十分彪悍,GB6跑分直接单核逼近2000.
网络上看,1Gbps的带宽,并且是无限流量,硬盘IO的数据也是非常Nice。 整体来说,这个配置这个跑分数据,基本看不到有超售的痕迹。
monovm的业务范围覆盖独立服务器,Linux-VPS,Windows-VPS,还有Email邮件系统业务,还有SSL证书,域名服务。
monovm的独立服务器最低66美元起步。16GB内存,8TB硬盘,属于大硬盘的独立服务器。
MonoVM荷兰独立服务器
CPU: Intel Xeon E3-12xx
内存:16GB
硬盘:2x4TB HDD
价格: 66美元月付
购买链接
monovm还有市面上比较少见的GPU-Server,采用英伟达的Nvidia Quadro P5000 ,月付907美元,有炼丹需求的用户可以购买。
MonoVM-USA-GPU Server 4210
CPU: Intel Xeon Silver 2 x 2.2GHz 4210
内存:32GB
硬盘:480GB SSD
GPU: Nvidia Quadro P5000
价格: 907 美元月付
购买链接
monovm还有域名业务, 最便宜的.site域名5.1美元年付起步,com域名12.46美元年付。
总结
这款荷兰VPS性能强劲,官网价格是29.9美元月付,不算便宜,这家产品丰富,主打的还是高端路线。
VPS资讯-测评-教程 https://bestcheapvps.org
群组 https://t.me/VPSTG
发表于 2024-6-10 15:39:15 | 只看该作者
4C 4G 30$,其实都可以考虑OVH 11$了。
GMT+8, 2026-4-22 16:13 , Processed in 0.061116 second(s), 9 queries , Gzip On, MemCache On.
