查看: 1261|回复: 1
[疑问] 请教公网出入口不同的NAT VPS,Nginx如何获取到真实访客IP
发表于 2024-6-8 21:45:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求大佬们指点,
买了个鸡仔云,打算穿透家里的小鸡出来做后端。
已经用frp穿透到28000端口,
已知入口IP为:1.2.3.4
通过curl 测试IP得值:4.3.2.1
应该是出入口IP不同?
通过指定hosts访问测试站点,但查看日志,获取到的IP全都是4.3.2.1
如果启用"proxy_protocol"则浏览器无法访问,就注释了。
openresty即nginx加功能版,http配置里设置了
  1.     set_real_ip_from 0.0.0.0/0;
  2.     real_ip_header X-Forwarded-For;
server配置如下
  1. server {
  2.     listen 80 ;
  3.     listen 443 ssl http2 ;
  4.     # 启用代理协议
  5.     #listen 80 proxy_protocol ;
  6.     #listen 443 ssl http2 proxy_protocol ;
  7.     server_name cq.abc.local;
  8.     index index.php index.html index.htm default.php default.htm default.html;
  9.     proxy_set_header Host $host;
  10.     proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
  11.     proxy_set_header X-Forwarded-Host $server_name;
  12.     proxy_set_header X-Real-IP $remote_addr;
  13.     proxy_http_version 1.1;
  14.     proxy_set_header Upgrade $http_upgrade;
  15.     proxy_set_header Connection "upgrade";
  16.     # 配置用于获取真实客户端IP的头信息
  17.     #real_ip_header proxy_protocol;
  18.     real_ip_recursive on;
  19.     #
  20.     access_log /www/sites/cq.abc.local/log/access.log;
  21.     error_log /www/sites/cq.abc.local/log/error.log;
  22.     location ^~ /.well-known/acme-challenge {
  23.         allow all;
  24.         root /usr/share/nginx/html;
  25.     }
  26.     root /www/sites/cq.abc.local/index;
  27.     if ($scheme = http) {
  28.         return 301 https://$host$request_uri;
  29.     }
  30.     ssl_certificate /www/sites/cq.abc.local/ssl/fullchain.pem;
  31.     ssl_certificate_key /www/sites/cq.abc.local/ssl/privkey.pem;
  32.     ssl_protocols TLSv1.3;
  33.     ssl_ciphers EECDH+CHACHA20:EECDH+CHACHA20-draft:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
  34.     ssl_prefer_server_ciphers on;
  35.     ssl_session_cache shared:SSL:10m;
  36.     ssl_session_timeout 10m;
  37.     add_header Strict-Transport-Security "max-age=31536000";
  38.     error_page 497 https://$host$request_uri;
  39.     proxy_set_header X-Forwarded-Proto https;
  40.     ssl_stapling on;
  41.     ssl_stapling_verify on;
  42.     include /www/sites/cq.abc.local/proxy/*.conf;
  43. }
反代的location如下
  1. location ^~ / {
  2.     proxy_pass https://127.0.0.1:28000;
  3.     proxy_set_header Host $host;
  4.     proxy_set_header X-Real-IP $remote_addr;
  5.     proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
  6.     proxy_set_header REMOTE-HOST $remote_addr;
  7.     proxy_set_header Upgrade $http_upgrade;
  8.     proxy_set_header Connection "upgrade";
  9.     proxy_set_header X-Forwarded-Proto $scheme;
  10.     proxy_http_version 1.1;
  11.     add_header X-Cache $upstream_cache_status;
  12.     add_header Strict-Transport-Security "max-age=31536000";
  13.     add_header Cache-Control no-cache;
  14.     # 禁用缓存
  15.     proxy_cache off;
  16.     # Disable buffering when the nginx proxy gets very resource heavy upon streaming
  17.     proxy_buffering off;
  18. }
 楼主| 发表于 2024-6-9 19:49:00 | 只看该作者
dddddddddddd
GMT+8, 2026-5-2 14:23 , Processed in 0.058800 second(s), 10 queries , Gzip On, MemCache On.
