查看: 840|回复: 1
。。DH 从备份服务器还没好
发表于 2012-6-21 00:31:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
This is another update on the restoration of your web server 'pagopago'. The load is holding steady and is very low at this time, and the restore of your data is proceeding as expected. The backup server drives are degraded though, so it will likely cause some instability until the restore completes. We are almost done with this restore. Our system administration team was able to recover the disks on the old hardware and we will be copying any missing data from the backups when the restore from the backup server is complete.
We are continuing to monitor the server and keep the loads as low as possible, but there have been some periods of instability still. While it is stable at the time, the load is still higher than optimal. If your site isn't working as expected, it may be due to load, but please let us know, so we can look into it for you.
10天都有了。。
发表于 2012-6-21 00:31:23 | 只看该作者
GMT+8, 2026-4-15 14:55 , Processed in 0.063154 second(s), 12 queries , Gzip On, MemCache On.
