查看: 1446|回复: 6
baota.sbs搭建失败
发表于 2024-5-21 21:05:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[root@iZ5ctjijetpaklZ ~]# yum install -y wget && wget -O install.sh https://new.baota.sbs/install/install_6.0.sh && sh install.sh
Loaded plugins: fastestmirror
Determining fastest mirrors
base        | 3.6 kB  00:00:00
epel        | 4.3 kB  00:00:00
extras        | 2.9 kB  00:00:00
updates        | 2.9 kB  00:00:00
(1/4): epel/x86_64/updateinfo        | 1.0 MB  00:00:00
(2/4): epel/x86_64/group        | 399 kB  00:00:00
(3/4): epel/x86_64/primary_db        | 8.7 MB  00:00:00
(4/4): updates/7/x86_64/primary_db        |  27 MB  00:00:00
Package wget-1.14-18.el7_6.1.x86_64 already installed and latest version
Nothing to do
--2024-05-21 21:03:09--  https://new.baota.sbs/install/install_6.0.sh
Resolving new.baota.sbs (new.baota.sbs)... 172.67.204.108, 104.21.90.191, 2606:4700:3031::6815:5abf, ...
Connecting to new.baota.sbs (new.baota.sbs)|172.67.204.108|:443... connected.
ERROR: cannot verify new.baota.sbs's certificate, issued by ‘/C=US/O=Let's Encrypt/CN=E1’:
  Issued certificate has expired.
To connect to new.baota.sbs insecurely, use `--no-check-certificate'.
搭建很多次都是到这一步报错 哎 求解 感谢!
发表于 2024-5-21 21:22:23 | 只看该作者
证书过期了
发表于 2024-5-21 21:23:18 | 只看该作者
 楼主| 发表于 2024-5-21 21:23:29 | 只看该作者
感谢 采用你的链接可以安装
发表于 2024-5-21 21:24:53 | 只看该作者
很简单的问题啊。
你google一下 “To connect to new.baota.sbs insecurely, use `--no-check-certificate'.” 如何解决 就ok了。
一般 是wget 配置里面修改一下 不要验证ssl 就好了。我用一开始也是这问题,解决一下就好了,
 楼主| 发表于 2024-5-21 21:35:59 | 只看该作者
shyasja 发表于 2024-5-21 21:24
很简单的问题啊。
你google一下 “To connect to new.baota.sbs insecurely, use `--no-check-certificate' ...
感谢 提醒 已解决
GMT+8, 2026-4-19 11:09 , Processed in 0.065114 second(s), 10 queries , Gzip On, MemCache On.
