查看: 1736|回复: 8
[疑问] debian12 怎么使用mysql5.x(已解决)
发表于 2024-5-21 09:48:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有在用的吗?试了几个方法都不能启动
按5楼的方法可以,谢谢诸位。
  1. 2024-05-21 08:18:48 5353 [ERROR] Can't open shared library '/usr/local/mysql/lib/plugin/provider_bzip2' (errno: 0 /usr/local/mysql/lib/plugin/provider_bzip2: cannot open shared object file: No such file or directory)
  2. 2024-05-21 08:18:48 5353 [ERROR] Can't open shared library '/usr/local/mysql/lib/plugin/provider_lz4' (errno: 2 /usr/local/mysql/lib/plugin/provider_lz4: cannot open shared object file: No such file or directory)
  3. 2024-05-21 08:18:48 5353 [ERROR] Can't open shared library '/usr/local/mysql/lib/plugin/provider_lzma' (errno: 2 /usr/local/mysql/lib/plugin/provider_lzma: cannot open shared object file: No such file or directory)
  4. 2024-05-21 08:18:48 5353 [ERROR] Can't open shared library '/usr/local/mysql/lib/plugin/provider_lzo' (errno: 2 /usr/local/mysql/lib/plugin/provider_lzo: cannot open shared object file: No such file or directory)
  5. 2024-05-21 08:18:48 5353 [ERROR] Can't open shared library '/usr/local/mysql/lib/plugin/provider_snappy' (errno: 2 /usr/local/mysql/lib/plugin/provider_snappy: cannot open shared object file: No such file or directory)
  6. 2024-05-21 08:18:48 5353 [Note] InnoDB: Using atomics to ref count buffer pool pages
  7. 2024-05-21 08:18:48 5353 [Note] InnoDB: The InnoDB memory heap is disabled
  8. 2024-05-21 08:18:48 5353 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
  9. 2024-05-21 08:18:48 5353 [Note] InnoDB: Memory barrier is not used
  10. 2024-05-21 08:18:48 5353 [Note] InnoDB: Compressed tables use zlib 1.2.11
  11. 2024-05-21 08:18:48 5353 [Note] InnoDB: Using Linux native AIO
  12. 2024-05-21 08:18:48 5353 [Note] InnoDB: Using CPU crc32 instructions
  13. 2024-05-21 08:18:48 5353 [Note] InnoDB: Initializing buffer pool, size = 2.0G
  14. 2024-05-21 08:18:48 5353 [Note] InnoDB: Completed initialization of buffer pool
  15. 2024-05-21 08:18:48 5353 [Note] InnoDB: Highest supported file format is Barracuda.
  16. 2024-05-21 08:18:48 5353 [Note] InnoDB: 128 rollback segment(s) are active.
  17. 2024-05-21 08:18:48 5353 [Note] InnoDB: Waiting for purge to start
  18. 2024-05-21 08:18:48 5353 [Note] InnoDB: 5.6.51 started; log sequence number 1600647
  19. 2024-05-21 08:18:48 5353 [ERROR] /usr/local/mysql/bin/mysqld: unknown variable 'provider_bzip2=0'
  20. 2024-05-21 08:18:48 5353 [ERROR] Aborting
  21. 2024-05-21 08:18:48 5353 [Note] Binlog end
  22. 2024-05-21 08:18:48 5353 [Note] InnoDB: FTS optimize thread exiting.
  23. 2024-05-21 08:18:48 5353 [Note] InnoDB: Starting shutdown...
  24. 2024-05-21 08:18:50 5353 [Note] InnoDB: Shutdown completed; log sequence number 1600657
  25. 2024-05-21 08:18:50 5353 [Note] /usr/local/mysql/bin/mysqld: Shutdown complete
发表于 2024-5-21 09:59:08 | 只看该作者
https://blog.iks.moe/archives/Debian-10-Buster-Package-Install-MySQL-56.html
发表于 2024-5-21 09:56:06 | 只看该作者
https://dev.mysql.com/downloads/repo/apt/
 楼主| 发表于 2024-5-21 10:19:11 | 只看该作者
只能装最新版8.x
 楼主| 发表于 2024-5-21 10:22:59 | 只看该作者
这个可以。
发表于 2024-5-21 10:25:05 | 只看该作者
docker 一把梭
发表于 2024-5-21 11:03:45 | 只看该作者
能,需要有点操作
https://downloads.mysql.com/archives/community/
GMT+8, 2026-4-28 03:30 , Processed in 0.069367 second(s), 11 queries , Gzip On, MemCache On.
