查看: 4242|回复: 12
[美国VPS] [评测]云派网测试报告
发表于 2012-6-18 15:35:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
主机名称 CPU 内存 硬盘 带宽 系统 线路 IP地址
Yvonne 1核1G 30G 独享4M CentOS 5.5 电信 61.129.15.34
61.129.15.34 ==>> 61.129.15.34 ==>> 1031868194 ==>> 上海市 电信
内存,木有Swap哦
  1. [root@yvonne ~]# free -m
  2.              total       used       free     shared    buffers     cached
  3. Mem:          1010        153        857          0         11        113
  4. -/+ buffers/cache:         28        982
  5. Swap:            0          0          0
CPU,测试为单核E5606
  1. [root@yvonne ~]# cat /proc/cpuinfo
  2. processor       : 0
  3. vendor_id       : GenuineIntel
  4. cpu family      : 6
  5. model           : 44
  6. model name      : Intel(R) Xeon(R) CPU           E5606  @ 2.13GHz
  7. stepping        : 2
  8. cpu MHz         : 2129.176
  9. cache size      : 8192 KB
  10. physical id     : 0
  11. siblings        : 1
  12. core id         : 0
  13. cpu cores       : 1
  14. apicid          : 0
  15. fdiv_bug        : no
  16. hlt_bug         : no
  17. f00f_bug        : no
  18. coma_bug        : no
  19. fpu             : yes
  20. fpu_exception   : yes
  21. cpuid level     : 4
  22. wp              : yes
  23. flags           : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat clflush mmx fxsr sse sse2 ht lm constant_tsc up pni ssse3 cx16 sse4_1 sse4_2 popcnt lahf_lm
  24. bogomips        : 4258.35
悲催得IO~~~
  1. [root@yvonne-i386 ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  2. 4096+0 records in
  3. 4096+0 records out
  4. 268435456 bytes (268 MB) copied, 22.0871 seconds, 12.2 MB/s
  5. [root@yvonne-i386 ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  6. 4096+0 records in
  7. 4096+0 records out
  8. 268435456 bytes (268 MB) copied, 18.4806 seconds, 14.5 MB/s
  9. [root@yvonne-i386 ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  10. 4096+0 records in
  11. 4096+0 records out
  12. 268435456 bytes (268 MB) copied, 20.9882 seconds, 12.8 MB/s
依旧Wget 广东电信
  1. [root@yvonne ~]# wget http://gzct.3098.com/w2ksp4_cn.exe
  2. --2012-06-18 15:04:23--  http://gzct.3098.com/w2ksp4_cn.exe
  3. Resolving gzct.3098.com... 121.14.195.67
  4. Connecting to gzct.3098.com|121.14.195.67|:80... connected.
  5. HTTP request sent, awaiting response... 200 OK
  6. Length: 134405296 (128M) [application/octet-stream]
  7. Saving to: `w2ksp4_cn.exe'
  8. 100%[===================================================================================================================>] 134,405,296  200K/s   in 11m 5s
  9. 2012-06-18 15:15:29 (197 KB/s) - `w2ksp4_cn.exe' saved [134405296/134405296]
丽水电信
  1. [root@yvonne ~]# wget http://telecom.inlishui.com/kehu/soft/154M.rar
  2. --2012-06-18 15:15:33--  http://telecom.inlishui.com/kehu/soft/154M.rar
  3. Resolving telecom.inlishui.com... 202.96.114.172
  4. Connecting to telecom.inlishui.com|202.96.114.172|:80... connected.
  6. Length: 133036366 (127M) [application/octet-stream]
  7. Saving to: `154M.rar'
  8. 100%[===================================================================================================================>] 133,036,366  463K/s   in 4m 42s
  9. 2012-06-18 15:20:15 (461 KB/s) - `154M.rar' saved [133036366/133036366]
跑Linode不错
  1. [root@yvonne ~]# wget http://tokyo1.linode.com/100MB-tokyo.bin
  2. --2012-06-18 15:23:50--  http://tokyo1.linode.com/100MB-tokyo.bin
  3. Resolving tokyo1.linode.com... 106.187.33.12
  4. Connecting to tokyo1.linode.com|106.187.33.12|:80... connected.
  6. Length: 104857600 (100M) [application/octet-stream]
  7. Saving to: `100MB-tokyo.bin'
  8. 100%[===================================================================================================================>] 104,857,600  464K/s   in 5m 12s
  9. 2012-06-18 15:29:02 (328 KB/s) - `100MB-tokyo.bin' saved [104857600/104857600]
基于Xen全虚拟化~~
  1. [root@yvonne virt-what-1.12]# virt-what
  2. xen
  3. xen-hvm
发表于 2012-6-18 15:51:33 | 只看该作者
Viacloud 上海云主机对比一下
  1. -bash-3.2# cat /proc/cpuinfo
  2. processor       : 0
  4. cpu family      : 6
  5. model           : 44
  6. model name      : Intel(R) Xeon(R) CPU           E5620  @ 2.40GHz
  7. stepping        : 2
  8. cpu MHz         : 2393.998
  9. cache size      : 12288 KB
  10. physical id     : 0
  11. siblings        : 1
  12. core id         : 0
  13. cpu cores       : 1
  14. fpu             : yes
  15. fpu_exception   : yes
  16. cpuid level     : 11
  17. wp              : yes
  18. flags           : fpu de tsc msr pae cx8 apic sep cmov pat clflush acpi mmx fxsr sse sse2 ss ht syscall nx lm constant_tsc pni cx16 lahf_lm
  19. bogomips        : 5989.30
  20. clflush size    : 64
  21. cache_alignment : 64
  22. address sizes   : 40 bits physical, 48 bits virtual
  23. power management:
  24. processor       : 1
  25. vendor_id       : GenuineIntel
  26. cpu family      : 6
  27. model           : 44
  28. model name      : Intel(R) Xeon(R) CPU           E5620  @ 2.40GHz
  29. stepping        : 2
  30. cpu MHz         : 2393.998
  31. cache size      : 12288 KB
  32. physical id     : 1
  33. siblings        : 1
  34. core id         : 0
  35. cpu cores       : 1
  36. fpu             : yes
  37. fpu_exception   : yes
  38. cpuid level     : 11
  39. wp              : yes
  40. flags           : fpu de tsc msr pae cx8 apic sep cmov pat clflush acpi mmx fxsr sse sse2 ss ht syscall nx lm constant_tsc pni cx16 lahf_lm
  41. bogomips        : 5989.30
  42. clflush size    : 64
  43. cache_alignment : 64
  44. address sizes   : 40 bits physical, 48 bits virtual
  45. power management:
  46. processor       : 2
  47. vendor_id       : GenuineIntel
  48. cpu family      : 6
  49. model           : 44
  50. model name      : Intel(R) Xeon(R) CPU           E5620  @ 2.40GHz
  51. stepping        : 2
  52. cpu MHz         : 2393.998
  53. cache size      : 12288 KB
  54. physical id     : 2
  55. siblings        : 1
  56. core id         : 0
  57. cpu cores       : 1
  58. fpu             : yes
  59. fpu_exception   : yes
  60. cpuid level     : 11
  61. wp              : yes
  62. flags           : fpu de tsc msr pae cx8 apic sep cmov pat clflush acpi mmx fxsr sse sse2 ss ht syscall nx lm constant_tsc pni cx16 lahf_lm
  63. bogomips        : 5989.30
  64. clflush size    : 64
  65. cache_alignment : 64
  66. address sizes   : 40 bits physical, 48 bits virtual
  67. power management:
  68. processor       : 3
  69. vendor_id       : GenuineIntel
  70. cpu family      : 6
  71. model           : 44
  72. model name      : Intel(R) Xeon(R) CPU           E5620  @ 2.40GHz
  73. stepping        : 2
  74. cpu MHz         : 2393.998
  75. cache size      : 12288 KB
  76. physical id     : 3
  77. siblings        : 1
  78. core id         : 0
  79. cpu cores       : 1
  80. fpu             : yes
  81. fpu_exception   : yes
  82. cpuid level     : 11
  83. wp              : yes
  84. flags           : fpu de tsc msr pae cx8 apic sep cmov pat clflush acpi mmx fxsr sse sse2 ss ht syscall nx lm constant_tsc pni cx16 lahf_lm
  85. bogomips        : 5989.30
  86. clflush size    : 64
  87. cache_alignment : 64
  88. address sizes   : 40 bits physical, 48 bits virtual
  89. power management:
  1. -bash-3.2# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  4. 268435456 bytes (268 MB) copied, 1.82607 seconds, 147 MB/s
  5. -bash-3.2#  dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  8. 268435456 bytes (268 MB) copied, 1.80204 seconds, 149 MB/s
  9. -bash-3.2# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  12. 268435456 bytes (268 MB) copied, 1.93417 seconds, 139 MB/s
  1. -bash-3.2# wget http://gzct.3098.com/w2ksp4_cn.exe
  2. --2012-06-18 15:53:51--  http://gzct.3098.com/w2ksp4_cn.exe
  8. 2% [>                                      ] 3,546,220    218K/s  eta 9m 28s
  9. -bash-3.2# wget http://telecom.inlishui.com/kehu/soft/154M.rar
  10. --2012-06-18 15:54:09--  http://telecom.inlishui.com/kehu/soft/154M.rar
  11. Resolving telecom.inlishui.com... 202.96.114.172
  12. Connecting to telecom.inlishui.com|202.96.114.172|:80... connected.
  13. HTTP request sent, awaiting response... 200 OK
  14. Length: 133036366 (127M) [application/octet-stream]
  15. Saving to: `154M.rar'
  16. 100%[======================================>] 133,036,366 4.30M/s   in 29s
  17. 2012-06-18 15:54:37 (4.43 MB/s) - `154M.rar' saved [133036366/133036366]
  18. -bash-3.2# wget http://tokyo1.linode.com/100MB-tokyo.bin
  19. --2012-06-18 15:55:00--  http://tokyo1.linode.com/100MB-tokyo.bin
  20. Resolving tokyo1.linode.com... 106.187.33.12
  21. Connecting to tokyo1.linode.com|106.187.33.12|:80... connected.
  22. HTTP request sent, awaiting response... 200 OK
  23. Length: 104857600 (100M) [application/octet-stream]
  24. Saving to: `100MB-tokyo.bin'
  25. 100%[======================================>] 104,857,600 3.15M/s   in 45s
  26. 2012-06-18 15:55:50 (2.22 MB/s) - `100MB-tokyo.bin' saved [104857600/104857600]
  27. -bash-3.2# wget http://dl_dir.qq.com/qqfile/qq/QQ2012/QQ2012Beta2.exe
  28. --2012-06-18 15:55:57--  http://dl_dir.qq.com/qqfile/qq/QQ2012/QQ2012Beta2.exe
  29. Resolving dl_dir.qq.com... 222.73.183.34, 222.73.183.71, 183.166.191.130, ...
  30. Connecting to dl_dir.qq.com|222.73.183.34|:80... connected.
  31. HTTP request sent, awaiting response... 200 OK
  32. Length: 48997792 (47M) [application/octet-stream]
  33. Saving to: `QQ2012Beta2.exe'
  34. 100%[======================================>] 48,997,792  52.4M/s   in 0.9s
  35. 2012-06-18 15:55:58 (52.4 MB/s) - `QQ2012Beta2.exe' saved [48997792/48997792]
最后是亮点
发表于 2012-6-18 15:59:29 | 只看该作者
发表于 2012-6-18 16:00:25 | 只看该作者
没有云的路过
 楼主| 发表于 2012-6-18 16:07:57 | 只看该作者
发表于 2012-6-18 16:09:40 | 只看该作者
汗,运来是HVM啊
发表于 2012-6-18 16:11:28 | 只看该作者
Vita 发表于 2012-6-18 15:51
Viacloud 上海云主机对比一下最后是亮点
vc是vm还是xenpv?xenhvm?
发表于 2012-6-18 16:11:35 | 只看该作者
其实这个是我测试的~(敏敏经常会把我的一些东西发出来)Linux还用HVM不多见
发表于 2012-6-18 16:14:07 | 只看该作者
Linux用的pv ,Win用的HVM
发表于 2012-6-18 16:29:56 | 只看该作者
妹子换头像了,难怪都找不到你了
GMT+8, 2026-5-4 12:30 , Processed in 0.128014 second(s), 15 queries , Gzip On, MemCache On.
